ZED Link Mono on Orin Nano
This tutorial will help you set up the ZED Link Mono GMSL2 capture card, and use the StereoLabs GMSL2 cameras with the NVIDIA® Jetson™ Orin Nano Developer Kits.
NVIDIA® does not manufacture a development kit specifically for the Jetson™ Orin NX module. However, the carrier board of the Jetson™ Orin Nano Developer Kit is fully compatible with the Orin NX module. Therefore, you can use this setup to test the Orin NX module. Read more about Jetson Orin NX/Nano series adaptation.
- 1x NVIDIA® Jetson™ Orin Nano Developer Kit or NVIDIA® Jetson™ Orin Nano Developer Kit mounting an Orin NX module.
- 1x ZED Link Mono GMSL2 capture card
- 1x NVIDIA® power supply to power the Development Kit (included with the devkit)
- 1x FPC Camera Cable 22-pin 0.5mm Pitch (included in the box)
- 9V-14V (min 2W) power input (Barrel Jack 5.5 mm outer diameter, 2.5 mm inner diameter) to power the GMSL2 capture card (not included)
MIPI cables transmit video signals. As the cable length increases, the video signal becomes noisier. The maximum recommended length is 15 cm.
Connect the CSI cables at the MIPI 22-pin port of the capture card. Make sure the correct side is plugged in.
Cabling the Carrier Board
Connect the camera
Once the cables are connected, plug the power for the GMSL2 capture card (9V-14V) so that cameras will be powered through the FAKRA cable (PoC).
Setting up the software
Install the ZED Link Driver
Install the ZED SDK
Camera configurations
