ZED Link Duo on Orin Nano
This tutorial will help you set up the ZED Link Duo GMSL2 capture card, and use the StereoLabs GMSL2 cameras with the NVIDIA® Jetson™ Orin Nano Developer Kits.
NVIDIA® does not manufacture a development kit specifically for the Jetson™ Orin NX module. However, the carrier board of the Jetson™ Orin Nano Developer Kit is fully compatible with the Orin NX module. Therefore, you can use this setup to test the Orin NX module. Read more here.
- 1x NVIDIA® Jetson™ Orin Nano Developer Kit or NVIDIA® Jetson™ Orin Nano Developer Kit mounting an Orin NX module.
- 1x ZED Link Duo GMSL2 capture card
- 1x 1-to-4 GMSL2 Fakra Male to Female cable (included in the box)
- 1x NVIDIA® power supply to power the Development Kit (included with the devkit)
- 2x FPC Camera Cable 22-pin 0.5mm Pitch to 15-pin 1.0mm Pitch (not included)*
- 9V-19V (min 2W) power input (Barrel Jack 5.5 mm outer diameter, 2.5 mm inner diameter) to power the GMSL2 capture card (not included)
FPC Camera Cables transmit video signals. If the cable length exceeds 12 cm, the video signal may become noisy or corrupted. We recommend keeping the cable length within this limit.
Connect both CSI cables at each MIPI 22-pin port of the capture card. Make sure the correct side is plugged in for each port.
Both MIPI cables must be connected to have access to 2x ZED X on the capture card.
Cabling the Carrier Board
Make sure that CAM1 is connected to the centered MIPI port of the GMSL2 capture card.
CAM0 must be connected to the MIPI port close to the edge.
Once connected, the setup should look like the following picture:
Connect the camera
Connect the GMSL2 Fakra cable female end to your ZED X. When you hear a click, the cable is securely connected to the camera.
Setting up the software
Install the ZED Link Driver
Install the ZED SDK
Multi-camera configurations
- Group A: port #0 and port #1
- Group B: port #2 and port #3
