ZED Link Mono on Orin Nano
This tutorial will help you set up the ZED Link Mono GMSL2 capture card, and use the StereoLabs GMSL2 cameras with the NVIDIA® Jetson™ Orin Nano Developer Kits.
NVIDIA® does not manufacture a development kit specifically for the Jetson™ Orin NX module. However, the carrier board of the Jetson™ Orin Nano Developer Kit is fully compatible with the Orin NX module. Therefore, you can use this setup to test the Orin NX module. Read more about Jetson Orin NX/Nano series adaptation.
  • 1x NVIDIA® Jetson™ Orin Nano Developer Kit or NVIDIA® Jetson™ Orin Nano Developer Kit mounting an Orin NX module.
  • 1x ZED Link Mono GMSL2 capture card
  • 1x NVIDIA® Power supplier to power the Development Kit (included with the devkit)
  • 1x FPC Camera Cable 22-pin 0.5mm Pitch (included in the box)
  • 9V-14V (min 2W) power input (Barrel Jack 5.5 mm outer diameter, 2.5 mm inner diameter) to power the GMSL2 capture card (not included)
MIPI cables transmit video signals. If the length increases, the video signal will be noisy. Max length recommended is 15 cm.
ZED Link Mono Orin Nano material
ZED Link Mono Orin Nano power
Connect the CSI cables at the MIPI 22-pin port of the capture card. Make sure the correct side is plugged in.
ZED Link Mono Orin Nano MIPI
Cabling the Carrier Board
ZED Link Mono Orin Nano MIPI carrier board connection
Connect the camera
ZED X camera with Fakra cable connected
With the capture card still powered off, connect the female end of the cable to the capture card’s GMSL2 input. Again, a click informs you that the cable is secured.
ZED Link Mono Fakra cable connection
GMSL2 cameras must be ideally plugged before booting up. If it is not the case, you can restart the zed_x_daemon that will be installed by the driver in the next section.
Once the cables are connected, plug the power for the GMSL2 capture card (9V-14V) so that cameras will be powered through the FAKRA cable (PoC).
Power adapter connection to ZED Link Mono
Setting up the software
Install the ZED SDK
Camera configurations
MonocularZED X One GSHD1200@60fps
HD1080@60fps
SVGA@120fps
MonocularZED X One SHD1200@60fps
HD1080@60fps
SVGA@120fps
MonocularZED X One 4k4k@15fps
HD1080@60fps
SVGA@60fps
StereoZED XHD1200@60fps
HD1080@60fps
SVGA@120fps
StereoZED X MiniHD1200@60fps
HD1080@60fps
SVGA@120fps
