ZED 2
Versatile stereo camera for spatial perception
Multiple generations, infinite solutions.
With unbeatable depth sensing and ease-of-use at its core, the ZED family is the go-to choice for teams working at the edge of robotics, digital twins and immersive experiences.
$499
ZED 2i
ZED2i_front
120mm Stereo BaselineUSB 3.1Built-in IMU, barometer & magnetometer1080p @30fpsIP66
$399
ZED Mini
ZEDmini_front
A compact powerhouse, the ZED Mini is built for mixed-reality, unlocking virtual and augmented reality applications. The ZED Mini can also be used for short-range applications.
63mm Stereo BaselineUSB 3.11080p @30fps
The world’s most powerful camera for depth and AI
ZED 2i is an IP66-rated Rolling Shutter camera built for spatial analytics and immersive experiences, powered by Neural Depth Engine 2. Ready to deploy, it has a robust aluminum enclosure, high-performance IMU and USB 3.1 connection.
Wide-angle 3D AI camera
Combine long-range depth perception with AI to perceive your environment in 3D with up to a 120° (Diagonal) wide-angle field of view.
Secure USB Type-C connection
Use a highly reliable USB 3.0 type-C cable with thumbscrew locking connectors and ensure a secure interconnection for your systems.
IP66-rated enclosure
Resistant to dust, water and humidity, the ZED 2i is designed for outdoor applications and challenging medical, industrial, agricultural environments and more.
Featuring 9-DoF sensors for spatial and positional awareness. Factory calibrated on 6-axis with robotic arms.
Multiple lens selection with polarizer
Select a 2.1 mm or a 4 mm lens depending on your application. Add a built-in CPL polarizing filter when working outdoors.
Multiple mounting options
With flexible mounting options and a flat bottom, the ZED 2i can be easily integrated in any system and environment.
Unlock game changing automations, in any environment.
The ZED 2i is a 3D AI camera that brings spatial awareness to machines and spaces. Our all-in-one vision platform brings deep detail to ZED 2 cameras, adding depth, motion sensing, and spatial AI to any application.
Build smart applications with the most advanced 3D AI software stack
ZED combines advanced depth sensing with AI, making it quick and easy to build cutting-edge spatial intelligence and digital twin applications.
AI-powered depth sensing
ZED uses stereo vision and neural networks to replicate human-like vision, enabling depth perception from 0.2 to 20m.
Large-scale 3D skeleton tracking
ZED is the first-ever camera that can track multiple 3D human skeletons with a wide angle, at long range and in any environment.
One platform, Multiple applications.
The ZED 2i is a 3D AI camera that brings spatial awareness to machines and spaces. You can use it for various indoors and outdoors applications.
Digital Twins
Get actionable insights to improve operations in every space.
Mobile Robotics
Give mobile robots the ability to understand everyday environments.
Robotic Arms
Adding advanced 3D perception to robotic arms for bin picking, depalletization, packaging and more.
With flexible mounting options and a flat bottom, the ZED 2i can be easily integrated in any system and environment. Combine this with a highly reliable USB 3.0 type-C cable to ensure a secure interconnection for your systems.
Multiple lens options
The ZED 2i stereo camera comes with new lens options. Choose between a 2.1mm lens for a wide field of view or a 4mm narrow FOV lens for increased depth and image quality at long range.
No more reflections with polarizing filters
Benefit from the highest possible image quality with a built-in polarizing filter when working outdoors. This filter helps reduce glare and reflections and increases color depth and quality as well.
One camera, multiple sensors
The only stereo camera with a next-generation IMU, barometer, magnetometer and temperature sensors. Factory calibrated on 6 axis with robotic arms.
New IP66-rated enclosure
Resistant to dust, water and humidity, the ZED 2i is designed for outdoor applications and challenging industrial, agricultural environments, and more.
Which camera is right for you?
The ZED 2 family is the go-to choice for teams working at the edge of robotics, digital twins and immersive experiences. The ZED 2i enables developers to build advanced systems that understand their surroundings in outdoor applications. The ZED Mini can be used for indoor and short-range applications.
$499
ZED 2i
ZED2i_front
$399
ZED Mini
ZEDmini_front
Technical Specifications
Find the right ZED camera for your needs.
Mechanical
Dimensions
175.25 x 30.25 x 43.10 mm (6.90 x 1.19 x 1.69’’)
Weight
230 g (0.51 lb)
Baseline
120 mm (4.72’’)
Video Output
Video Output
2K at 15 FPS with Output resolution side-by-side of 2x(2208x1242)
1080p at 30 or 15 FPS with Output resolution side-by-side of 2x(1920x1080)
720p at 60, 30 or 15 FPS with Output resolution side-by-side of 2x(1280x720)
376p at 100, 60, 30 or 15 FPS with Output resolution side-by-side of 2x(672x376)
Video Recording
Native resolution video encoding in H.264, H.265 or lossless format (on host)
Video Streaming
Stream anywhere over IP using ZED SDK
Depth
Depth Resolution
Native video resolution (in Ultra mode)
Depth FPS
Up to 100Hz
Depth Range Max
0.3m to 20m (1ft to 65ft) with 2.1 mm lens
1.5m to 35m (4.9ft to 114.8ft) with 4 mm lens
Depth Technology
Neural Stereo Depth Sensing
Motion
Motion Sensors
Accelerometer
Gyroscope
Data Rate: 400Hz
Barometer
Magnetometer
Temperature sensors
Pose Update Rate
Up to 100Hz
Pose Drift
Translation: 0.35%
Rotation: 0.005°/m
(without loop correction)
Motion Technology
6-DoF visual-inertial stereo SLAM with advanced sensor fusion and thermal compensation
Object Detection
Object Types
Persons, Vehicles
Custom Objects
Object Tracking
Yes
Detection Outputs
Bounding Boxes 2D/3D
Location
Speed
Unique ID
Segmentation Masks
Detection Range
Up to 20m (3D)
Up to 40m (2D)
Skeleton Tracking
18x, 34x or 38x Body Keypoints
Up to 15m Range
Lens
Lens Type
Wide-angle 8-element all-glass dual lens with optically corrected distortion
Aperture
ƒ/2.0 (2.1mm)
ƒ/1.8 (4mm)
Focal Length
2.1mm
4mm
Field of View
110°(H) x 70°(V) x 120°(D) max. (for 2.1mm)
72°(H) x 44°(V) x 81°(D) max. (for 4mm)
Polarizing Filter
Option available
Image Sensors
Sensor Resolution
Dual 4M pixels sensors with 2-micron pixels
Sensor Format
Native 16:9 format for a greater horizontal field of view
Sensor Size
1/3” backside illumination sensors with high low-light sensitivity
Shutter Sync
Electronic Synchronized Rolling Shutter
Camera Controls
Adjust Resolution, Frame rate, Brightness, Contrast, Saturation, Gamma, Sharpness, Exposure and White Balance
Connectivity
Connector
USB 3.0 Type-C with dual locking screws
Mounting Options
1/4"-20 UNC thread mount
2x M3 threads (bottom)
4x M3 threads (back)
Connectivity Power
Power via USB 5V / 380mA
Operating Temperature
-10°C to +50°C (14°F to 122°F)
Other
Compatible OS
Tech-Spec-Logo-Windows
Windows 11, 10, 8, 7
Tech-Spec-Logo-Ubuntu
Ubuntu 22, 20, 18
Tech-Spec-Logo-Debian
Debian, CentOS (via Docker)
Jetson L4T
Third-party Integrations
Tech-Spec-Logo-Unity
Unity
Unreal
OpenCV
ROS
ROS2
PyTorch
Docker
MATLAB
Tech-Spec-Logo-PCL
PCL
C++
Python
C#
SDK System Requirements
Dual-core 2.3GHz or faster processor
4GB RAM or more
NVIDIA GPU with compute capability > 3.0
Warranty
2-year hardware warranty
Compare all Stereo Cameras
ZEDmini_front
ZED2i_front
ZEDX_front
From $399.00Order now
From $499.00Order now
From $599.00Order now
Mechanical
Dimensions
124.5 x 30.5 x 26.5 mm (4.9 x 1.2 x 1.04’’)
164 x 32 x 37 mm (6.44 x 1.26 x 1.45 in)
Baseline
63 mm (2.4’’)
120 mm (4.72’’)
120 mm (4.72 in)
Weight
60 g (0.14 lb)
230 g (0.51 lb)
240 g (0.53 lb)
0°C to +45°C (32°F to 113°F)
Lens Cover
PPMA
Video Output
Video Output
WVGA at 100 FPS with Output resolution side-by-side of 2x(672x376)
1200p at 60, 30 or 15 FPS with Output resolution side-by-side of 2x(1920x1200)
1080p at 60, 30 or 15 FPS with Output resolution side-by-side of 2x(1920x1080)
600p at 120, 60, 30 or 15 FPS with Output resolution side-by-side of 2x(960x600)
Video Recording
Native resolution video encoding in H.264, H.265, Lossless formats (on host)
Video Streaming
Video Mode
1200p @ 60 / 30 / 15 FPS Output Resolution Side-by-side 2x(1920x1200)
1080p @ 60 / 30 / 15 FPS Output Resolution Side-by-side 2x(1920x1080)
600p @ 120 / 60 / 30 / 15 FPS Output Resolution Side-by-side 2x(960x600)
Depth
Depth Resolution
Depth FPS
Up to 100Hz
Up to 100Hz
Up to 120Hz
Depth Range Max
0.1m to 15m (0.3ft to 49ft)
0.3m to 20m (1ft to 65ft) with 2.2 mm lens
1.0m to 35m (3.3ft to 115ft) with 4 mm lens
Ideal Range
0.1m to 9m (0.3ft to 29.5ft)
0.3m to 12m (1ft to 39ft) with 2.1 mm lens
1.5m to 20m (5ft to 65ft) with 4 mm lens
0.3m to 12m (1ft to 40ft) with 2.2 mm lens
1.0m 20m (3.3ft to 65ft) with 4 mm lens
Depth Technology
Motion
Motion Sensors
Accelerometer
Gyroscope
Data Rate: 800Hz
Accelerometer
Gyroscope
Data Rate: 400Hz
Barometer
Magnetometer
Temperature sensors
16-bits Accelerometer (up to 12g)
16-bits Gyroscope (up to 1000°/s)
Data Rate: 400 Hz
Pose Update Rate
Up to 100Hz
Up to 100Hz
Up to 120Hz
Motion Technology
6-DoF visual-inertial stereo SLAM with sensor fusion
Visual-inertial stereo SLAM with advanced sensor fusion and thermal compensation
Pose Drift
Translation: 1.0%
Rotation: 0.013°/m
Translation: 0.35%
Rotation: 0.005°/m
Translation: 0.3%
Rotation: 0.003°/m
Object Detection
Detection Outputs
Location
Speed
Unique ID
Segmentation Masks
Location
Speed
Unique ID
Segmentation Masks
3D Location
Speed
Unique ID
Segmentation Masks
Skeleton Tracking
Up to 15m Range
Up to 15m Range
Object Types
Persons, Vehicles
Custom Objects
Persons, Vehicles
Custom Objects
Persons, Vehicles, Vegetables, Electronic devices...
Custom Objects
Object Tracking
Yes
Yes
Yes
Detection Range
Up to 20m (3D)
Up to 40m (2D)
Up to 20m (3D)
Up to 40m (2D)
Lens
Lens Type
6-elements all-glass dual lens
Wide-angle 9-element all-glass dual lens with optically corrected distortion
Aperture
ƒ/2.0
ƒ/2.0 (2.1mm)
ƒ/1.8 (4mm)
ƒ/2.2 (2.2mm)
ƒ/1.8 (4mm)
Focal Length
2.8mm (0.11’’)
2.1mm
4mm
2.2mm (0.087")
3.8mm (0.150")
Field of View
102° (H) x 57° (V) x 118° (D) max.
110 (H) x 80 (V) x 120° (D) max. (for 2.2mm)
80 (H) x 52 (V) x 91° (D) max. (for 4mm)
Polarizing Filter
None
Option available
Option
Image Sensors
Sensor Resolution
Dual 4M pixels sensors with large 2-micron pixels
Dual 2.3M pixels sensors with 3-micron pixels
Sensor Format
Native 16:10 format for a greater vertical field of view
Sensor Size
1/2.6” sensors with high low-light sensitivity
Shutter Sync
Camera Controls
Adjust Resolution, Frame rate, Saturation, Gamma, Sharpness, White Balance, Exposure time and range, Sensor gain (Analog/dB), Digital gain (ISP), Color balance and Denoising
Connectivity
Connector
USB 3.0 Type-C port
Mounting Options
4x M2 thread mounts
2x M4 threads (bottom)
4x M4 threads (back)
Connectivity Power
Power via GMSL2 (PoC)
Capture Card
Capture Card Compatibility
Capture Card Power
Via CSI port of the Jetson Orin AGX
Other
Compatible OS
Windows 10, 8, 7
Ubuntu 20, 18, 16
Jetson L4T
Ubuntu 22, 20, 18
Jetson L4T
Jetson L4T
Unity
Unreal
OpenCV
ROS
ROS2
PyTorch
Docker
MATLAB
Tech-Spec-Logo-PCL
PCL
C++
Python
C#
Unity
Unreal
OpenCV
ROS
ROS2
PyTorch
Docker
MATLAB
Tech-Spec-Logo-PCL
PCL
C++
Python
C#
Unity
Unreal
OpenCV
ROS
ROS 2
PyTorch
Docker
MATLAB
Tech-Spec-Logo-PCL
PCL
C++
Python
C#
4 GB RAM or more
4GB RAM or more
NVIDIA Jetson AGX Orin, Orin NX
In the Box
ZED Mini Stereo camera
4m USB Type-C to Type-A cable
1.5m USB Type-C to Type-A cable
Warranty
1-year hardware warranty
ISP
New ISP tuned with machine learning for AI and vision tasks
Compliance
Country of Origin
France
France
France
HS Code
85258940
85258940
85258940
ECCN
EAR99
EAR99
EAR99
RoHS
RoHS 3
RoHS 3
RoHS 3
FROM $1899 PER KIT
Starter kits for any team
$1,434New
Single Stereo USB Kit
1x ZED 2i Stereo Camera
1x ZED Box Mini
$2,247New
Dual Autonomy Kit
2x ZED X Stereo Cameras
1x ZED Box Mini
$3,695New
Hybrid Autonomy Kit
1x ZED Box Orin NX 16GB
2 x ZED X One Mono Cameras
1x 4-in-1 GMSL2 cables
Get your ZED 2 today.
