IMUData Class Reference
Contains inertial positional tracking data which gives the orientation of the ZED-M. More...
General Functions
 IMUData ()
 Default constructor which creates an empty IMUData (identity). More...
 IMUData (const IMUData &pose)
 IMUData constructor with deep copy. More...
 IMUData (const Transform &pose_data, unsigned long long timestamp=0, int confidence=0)
 ~IMUData ()
 IMUData destructor. More...
Translation getTranslation ()
 Returns the translation from the pose. More...
Orientation getOrientation ()
 Returns the orientation from the pose. More...
Rotation getRotationMatrix ()
 Returns the rotation (3x3) from the pose. More...
Rotation getRotation ()
float3 getRotationVector ()
 Returns the rotation (3x1 rotation vector obtained from 3x3 rotation matrix using Rodrigues formula) from the pose. More...
float3 getEulerAngles (bool radian=true)
 Convert the Rotation of the Transform as Euler angles. More...
Attributes
sl::Matrix3f orientation_covariance
sl::float3 angular_velocity
sl::float3 linear_acceleration
sl::Matrix3f angular_velocity_convariance
sl::Matrix3f linear_acceleration_convariance
int image_sync_trigger
Transform pose_data
sl::timeStamp timestamp
int pose_confidence
float pose_covariance [36]
 6x6 Pose covariance of translation (the first 3 values) and rotation in so3 (the last 3 values) More...
bool valid
float twist [6]
float twist_covariance [36]
Note
This data will not be filled if you are using a ZED camera
Different representations of orientation can be retrieved, along with timestamp and pose confidence. Raw data (linear acceleration and angular velocity) are also given along with the calculated orientation.
Constructor and Destructor
◆ IMUData() [1/3]
IMUData ( )
◆ IMUData() [2/3]
IMUData ( const IMUData &  pose)
◆ IMUData() [3/3]
IMUData ( const Transform &  pose_data,
unsigned long long  timestamp = 0,
int  confidence = 0
◆ ~IMUData()
~IMUData ( )
IMUData destructor.
◆ getTranslation()
Translation getTranslation ( )
inherited
Returns
The (3x1) translation vector.
◆ getOrientation()
Orientation getOrientation ( )
inherited
Returns
The (4x1) orientation vector.
◆ getRotationMatrix()
Rotation getRotationMatrix ( )
inherited
Returns
The (3x3) rotation matrix.
◆ getRotation()
Rotation getRotation ( )
inlineinherited
Returns
Deprecated:
See getRotationMatrix
◆ getRotationVector()
float3 getRotationVector ( )
inherited
Returns
The (3x1) rotation vector.
◆ getEulerAngles()
float3 getEulerAngles ( bool  radian = true)
inherited
Parameters
radian: Define if the angle in is radian or degree. default : true.
Returns
The Euler angles, as a float3 representing the rotations around the X, Y and Z axes. (YZX convention)
Variables
◆ orientation_covariance
(3x3) 3x3 Covariance matrix for orientation (x,y,z axes)
◆ angular_velocity
(3x1) Vector for angular velocity of the IMU, given in deg/s. In other words, the current velocity at which the sensor is rotating around the x, y, and z axes.
◆ linear_acceleration
(3x1) Vector for linear acceleration of the IMU, given in m/s^2. In other words, the current acceleration of the sensor, along with the x, y, and z axes.
◆ angular_velocity_convariance
(3x3) 3x3 Covariance matrix for the angular velocity
◆ linear_acceleration_convariance
(3x3) 3x3 Covariance matrix for the linear acceleration
◆ image_sync_trigger
Indicates if the IMUData has been taken during a frame capture on sensor. If value is 1, IMUData has been taken during the same time than a frame has been acquired by the left sensor (the time precision is linked to the IMU rate, therefore 800Hz == 1.3ms) If value is 0, the data has not been taken during a frame acquisition.
◆ pose_data
Transform pose_data
inherited
4x4 Matrix which contains the rotation (3x3) and the translation. Orientation is extracted from this transform as well.
◆ timestamp
inherited
Timestamp of the pose. This timestamp should be compared with the camera timestamp for synchronization.
◆ pose_confidence
int pose_confidence
inherited
Confidence/Quality of the pose estimation for the target frame.
A confidence metric of the tracking [0-100], 0 means that the tracking is lost, 100 means that the tracking can be fully trusted.
◆ pose_covariance
float pose_covariance[36]
inherited
Note
Computed only if sl::TrackingParameters::enable_spatial_memory is disabled.
◆ valid
bool valid
inherited
boolean that indicates if tracking is activated or not. You should check that first if something wrong.
◆ twist
float twist[6]
inherited
twist and twist covariance of the camera available in reference camera
◆ twist_covariance
float twist_covariance[36]
inherited
