Designed to contain translation data of the positional tracking. More...
General Functions | |
| Translation () | |
| empty Translation default constructor. More... | |
| Translation (const Translation &translation) | |
| Translation copy constructor (deep copy). More... | |
| Translation (float t1, float t2, float t3) | |
| Translation constructor. More... | |
| Translation (float3 in) | |
| Translation | operator* (const Orientation &mat) const |
| Multiplication operator by an Orientation. More... | |
| void | normalize () |
| Normalizes the current translation. More... | |
| float & | operator() (int x) |
| Get the value at specific position in the Translation. More... | |
| _FCT_CPU_GPU_ int | size () const |
| _FCT_CPU_GPU_ const float * | ptr () const |
| _FCT_CPU_GPU_ Vector3< float > & | setValues (const float *b) |
| _FCT_CPU_GPU_ float & | operator[] (int i) |
| _FCT_CPU_GPU_ float | norm () |
| returns the norm of the vector More... | |
| _FCT_CPU_GPU_ float | square () |
| returns the squared norm of the vector More... | |
| _FCT_CPU_GPU_ float | sum () |
| returns the sum of the vector More... | |
Static Functions | |
| static Translation | normalize (const Translation &tr) |
| Get the normalized version of a given Translation. More... | |
| static _FCT_CPU_GPU_ float | dot (const Vector3< float > &a, const Vector3< float > &b) |
| returns the dot product of two vector More... | |
| static _FCT_CPU_GPU_ float | distance (const Vector3< float > &a, const Vector3< float > &b) |
| returns the distance between two vector More... | |
| static _FCT_CPU_GPU_ Vector3< float > | cross (const Vector3< float > &a, const Vector3< float > &b) |
| returns the cross product between two vector More... | |
Translation is a vector as [tx, ty, tz]. You can access the data with the 't' ptr or by element name as : tx, ty, tz <-> | 0 1 2 |
| Translation | ( | ) |
| Translation | ( | const Translation & | translation | ) |
| translation | : the Translation to copy. |
| Translation | ( | float | t1, |
| float | t2, | ||
| float | t3 | ||
| t1 | : the x translation. |
| t2 | : the y translation. |
| t3 | : the z translation. |
| Translation | ( | float3 | in | ) |
| in | : vector. |
| Translation operator* | ( | const Orientation & | mat | ) | const |
| mat | : Orientation. |
| void normalize | ( | ) |
static |
| tr | : the Translation to be used. |
| float& operator() | ( | int | x | ) |
| x | : the position of the value |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlinestaticinherited |
