Designed to contain orientation (quaternion) data of the positional tracking. More...
General Functions | |
| Orientation () | |
| empty Orientation default constructor. More... | |
| Orientation (const Orientation &orientation) | |
| Orientation copy constructor (deep copy). More... | |
| Orientation (const float4 &in) | |
| Orientation (const Rotation &rotation) | |
| Orientation constructor from an Rotation. More... | |
| Orientation (const Translation &tr1, const Translation &tr2) | |
| Orientation constructor from a vector represented by two Translation. More... | |
| float | operator() (int x) |
| Returns the value at specific position in the Orientation. More... | |
| Orientation | operator* (const Orientation &orientation) const |
| Multiplication operator by an Orientation. More... | |
| void | setRotationMatrix (const Rotation &rotation) |
| Sets the orientation from a Rotation. More... | |
| Rotation | getRotationMatrix () const |
| Returns the current orientation as a Rotation. More... | |
| void | setRotation (const Rotation &rotation) |
| Rotation | getRotation () const |
| void | setIdentity () |
| Sets the current Orientation to identity. More... | |
| void | setZeros () |
| Fills the current Orientation with zeros. More... | |
| void | normalise () |
| Normalizes the current Orientation. More... | |
| _FCT_CPU_GPU_ int | size () const |
| _FCT_CPU_GPU_ const T * | ptr () const |
| _FCT_CPU_GPU_ Vector4< T > & | setValues (const T *b) |
| _FCT_CPU_GPU_ T & | operator[] (int i) |
| _FCT_CPU_GPU_ const T & | operator[] (int i) const |
| _FCT_CPU_GPU_ float | norm () |
| returns the norm of the vector More... | |
| _FCT_CPU_GPU_ float | square () |
| returns the squared norm of the vector More... | |
| _FCT_CPU_GPU_ float | sum () |
| returns the sum of the vector More... | |
Static Functions | |
| static Orientation | identity () |
| Creates an Orientation initialized to identity. More... | |
| static Orientation | zeros () |
| Creates an Orientation filled with zeros. More... | |
| static Orientation | normalise (const Orientation &orient) |
| Creates the normalized version of an existing Orientation. More... | |
| static _FCT_CPU_GPU_ float | dot (const Vector4< T > &a, const Vector4< T > &b) |
| returns the dot product of two vector More... | |
| static _FCT_CPU_GPU_ float | distance (const Vector4< T > &a, const Vector4< T > &b) |
| returns the distance between two vector More... | |
Orientation is a vector defined as [ox, oy, oz, ow].
| Orientation | ( | ) |
| Orientation | ( | const Orientation & | orientation | ) |
| orientation | : the Orientation to copy. |
| Orientation | ( | const float4 & | in | ) |
| in | : the vector to copy. |
Set in the following order : [ox, oy, oz, ow].
| Orientation | ( | const Rotation & | rotation | ) |
It converts the Rotation representation to the Orientation one.
| rotation | : the Rotation to be used. |
| Orientation | ( | const Translation & | tr1, |
| const Translation & | tr2 | ||
| tr1 | : the first point of the vector. |
| tr2 | : the second point of the vector. |
| float operator() | ( | int | x | ) |
| x | : the position of the value |
| Orientation operator* | ( | const Orientation & | orientation | ) | const |
| orientation | : the orientation. |
| void setRotationMatrix | ( | const Rotation & | rotation | ) |
| Rotation getRotationMatrix | ( | ) | const |
inline |
inline |
| void setIdentity | ( | ) |
static |
| void setZeros | ( | ) |
static |
| void normalise | ( | ) |
static |
| orient | : the Orientation to be used. |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlinestaticinherited |
