Positional Tracking Module
Classes
class  TrackingParameters
 Parameters for positional tracking initialization. More...
class  Rotation
 Designed to contain rotation data of the positional tracking. It inherits from the generic Matrix3f. More...
class  Translation
 Designed to contain translation data of the positional tracking. More...
class  Orientation
 Designed to contain orientation (quaternion) data of the positional tracking. More...
class  Transform
 Designed to contain translation and rotation data of the positional tracking. More...
class  Pose
 Contains positional tracking data which gives the position and orientation of the ZED in 3D space. More...
class  IMUData
 Contains inertial positional tracking data which gives the orientation of the ZED-M. More...
Enumerations
enum  TRACKING_STATE
 Lists the different states of positional tracking. More...
enum  REFERENCE_FRAME
 Defines which type of position matrix is used to store camera path and pose. More...
String toString (const TRACKING_STATE &track_state)
 Converts the given enumerated value into readable text. More...
String toString (const REFERENCE_FRAME &ref_frame)
String trackingState2str (TRACKING_STATE state)
 Converts the given TRACKING_STATE into a string. More...
◆ TRACKING_STATE
Enumerator
TRACKING_STATE_SEARCHING
The camera is searching for a previously known position to locate itself.
TRACKING_STATE_OK
Positional tracking is working normally.
TRACKING_STATE_OFF
Positional tracking is not enabled.
TRACKING_STATE_FPS_TOO_LOW
Effective FPS is too low to give proper results for motion tracking. Consider using PERFORMANCES parameters (DEPTH_MODE_PERFORMANCE, low camera resolution (VGA,HD720))
TRACKING_STATE_LAST
◆ REFERENCE_FRAME
Enumerator
REFERENCE_FRAME_WORLD
The transform of sl::Pose will contains the motion with reference to the world frame (previously called PATH).
REFERENCE_FRAME_CAMERA
The transform of sl::Pose will contains the motion with reference to the previous camera frame (previously called POSE).
REFERENCE_FRAME_LAST
Function Documentation
◆ toString() [1/2]
String sl::toString ( const TRACKING_STATE &  track_state)
Returns
The enumerated value as a string.
◆ toString() [2/2]
String sl::toString ( const REFERENCE_FRAME &  ref_frame)
Returns
◆ trackingState2str()
String sl::trackingState2str ( TRACKING_STATE  state)
Parameters
state: a specific TRACKING_STATE
Returns
The corresponding string
Deprecated:
See toString.
