Contains positional tracking data which gives the position and orientation of the ZED in 3D space. More...
General Functions | |
| Pose () | |
| Default constructor which creates an empty Pose (identity). More... | |
| Pose (const Pose &pose) | |
| Pose constructor with deep copy. More... | |
| Pose (const Transform &pose_data, unsigned long long timestamp=0, int confidence=0) | |
| ~Pose () | |
| Pose destructor. More... | |
| Translation | getTranslation () |
| Returns the translation from the pose. More... | |
| Orientation | getOrientation () |
| Returns the orientation from the pose. More... | |
| Rotation | getRotationMatrix () |
| Returns the rotation (3x3) from the pose. More... | |
| Rotation | getRotation () |
| float3 | getRotationVector () |
| Returns the rotation (3x1 rotation vector obtained from 3x3 rotation matrix using Rodrigues formula) from the pose. More... | |
| float3 | getEulerAngles (bool radian=true) |
| Convert the Rotation of the Transform as Euler angles. More... | |
Attributes | |
| Transform | pose_data |
| sl::timeStamp | timestamp |
| int | pose_confidence |
| float | pose_covariance [36] |
| 6x6 Pose covariance of translation (the first 3 values) and rotation in so3 (the last 3 values) More... | |
| bool | valid |
| float | twist [6] |
| float | twist_covariance [36] |
Different representations of position and orientation can be retrieved, along with timestamp and pose confidence.
| Translation getTranslation | ( | ) |
| Orientation getOrientation | ( | ) |
| Rotation getRotationMatrix | ( | ) |
inline |
| float3 getRotationVector | ( | ) |
| float3 getEulerAngles | ( | bool | radian = true | ) |
| Transform pose_data |
4x4 Matrix which contains the rotation (3x3) and the translation. Orientation is extracted from this transform as well.
| sl::timeStamp timestamp |
Timestamp of the pose. This timestamp should be compared with the camera timestamp for synchronization.
| int pose_confidence |
Confidence/Quality of the pose estimation for the target frame.
A confidence metric of the tracking [0-100], 0 means that the tracking is lost, 100 means that the tracking can be fully trusted.
| float pose_covariance[36] |
| bool valid |
boolean that indicates if tracking is activated or not. You should check that first if something wrong.
| float twist[6] |
twist and twist covariance of the camera available in reference camera
| float twist_covariance[36] |
