Designed to contain translation and rotation data of the positional tracking. More...
General Functions | |
| Transform () | |
| Transform default constructor. More... | |
| Transform (const Transform &motion) | |
| Transform copy constructor (deep copy). More... | |
| Transform (const Matrix4f &mat) | |
| Transform (const Rotation &rotation, const Translation &translation) | |
| Transform constructor from a Rotation and a Translation. More... | |
| Transform (const Orientation &orientation, const Translation &translation) | |
| Transform constructor from an Orientation and a Translation. More... | |
| void | setRotationMatrix (const Rotation &rotation) |
| Sets the rotation of the current Transform from an Rotation. More... | |
| Rotation | getRotationMatrix () const |
| Returns the Rotation of the current Transform. More... | |
| void | setRotation (const Rotation &rotation) |
| Rotation | getRotation () const |
| void | setTranslation (const Translation &translation) |
| Sets the translation of the current Transform from an Translation. More... | |
| Translation | getTranslation () const |
| Returns the Translation of the current Transform. More... | |
| void | setOrientation (const Orientation &orientation) |
| Sets the orientation of the current Transform from an Orientation. More... | |
| Orientation | getOrientation () const |
| Returns the Orientation of the current Transform. More... | |
| float3 | getRotationVector () |
| Returns the 3x1 rotation vector obtained from 3x3 rotation matrix using Rodrigues formula. More... | |
| void | setRotationVector (const float3 &vec_rot) |
| Sets the Rotation 3x3 of the Transform with a 3x1 rotation vector (using Rodrigues' transformation). More... | |
| float3 | getEulerAngles (bool radian=true) const |
| Convert the Rotation of the Transform as Euler angles. More... | |
| void | setEulerAngles (const float3 &euler_angles, bool radian=true) |
| Sets the Rotation of the Transform from the Euler angles. More... | |
| Matrix4f | operator* (const Matrix4f &mat) const |
| Matrix4f | operator* (const Vector4< float > &vect) const |
| Matrix4f | operator* (const float &scalar) const |
| Matrix4f | operator+ (const Matrix4f &mat) const |
| Matrix4f | operator+ (const float &scalar) const |
| Matrix4f | operator- (const Matrix4f &mat) const |
| Matrix4f | operator- (const float &scalar) const |
| bool | operator== (const Matrix4f &mat) const |
| bool | operator!= (const Matrix4f &mat) const |
| float & | operator() (int u, int v) |
| Gets access to a specific point in the Matrix4f (read / write). More... | |
| ERROR_CODE | inverse () |
| Sets the Matrix4f to its inverse. More... | |
| void | transpose () |
| Sets the Matrix4f to its transpose. More... | |
| void | setIdentity () |
| Sets the Matrix4f to identity. More... | |
| void | setZeros () |
| Sets the Matrix4f to zero. More... | |
| ERROR_CODE | setSubMatrix3f (Matrix3f input, int row=0, int column=0) |
| Sets a 3x3 Matrix inside the Matrix4f. More... | |
| ERROR_CODE | setSubVector3f (Vector3< float > input, int column=3) |
| Sets a 3x1 Vector inside the Matrix4f at the specified column index. More... | |
| ERROR_CODE | setSubVector4f (Vector4< float > input, int column=3) |
| Sets a 4x1 Vector inside the Matrix4f at the specified column index. More... | |
| String | getInfos () |
| Returns the components of the Matrix4f in a String. More... | |
Static Functions | |
| static Matrix4f | inverse (const Matrix4f &mat) |
| Creates the inverse of a Matrix4f. More... | |
| static Matrix4f | transpose (const Matrix4f &mat) |
| Creates the transpose of a Matrix4f. More... | |
| static Matrix4f | identity () |
| Creates an identity Matrix4f. More... | |
| static Matrix4f | zeros () |
| Creates a Matrix4f filled with zeros. More... | |
Attributes | |
| String | matrix_name |
| Name of the matrix (optional). More... | |
It contains the orientation as well. It can be used to create any type of Matrix4x4 or Matrix4f that must be specifically used for handling a rotation and position information (OpenGL, Tracking...) It inherits from the generic Matrix4f
| Transform | ( | const Rotation & | rotation, |
| const Translation & | translation | ||
| rotation | : the Rotation to copy. |
| translation | : the Translation to copy. |
| Transform | ( | const Orientation & | orientation, |
| orientation | : the Orientation to copy. |
| void setRotationMatrix | ( | const Rotation & | rotation | ) |
| Rotation getRotationMatrix | ( | ) | const |
inline |
inline |
| void setTranslation | ( | const Translation & | translation | ) |
| translation | : the Translation to be used. |
| Translation getTranslation | ( | ) | const |
| void setOrientation | ( | const Orientation & | orientation | ) |
| orientation | : the Orientation to be used. |
| Orientation getOrientation | ( | ) | const |
| float3 getRotationVector | ( | ) |
| void setRotationVector | ( | const float3 & | vec_rot | ) |
| float3 getEulerAngles | ( | bool | radian = true | ) | const |
| void setEulerAngles | ( | const float3 & | euler_angles, |
brief Gives the result of the multiplication between two Matrix4f.
brief Gives the result of the multiplication between a Matrix4f and a float4.
inherited |
brief Gives the result of the multiplication between a Matrix4f and a scalar.
brief Gives the result of the addition between two Matrix4f.
inherited |
brief Gives the result of the addition between a Matrix4f and a scalar.
brief Gives the result of the subtraction between two Matrix4f.
inherited |
brief Gives the result of the subtraction between a Matrix4f and a scalar.
inherited |
| u | : specify the row. |
| v | : specify the column. |
inherited |
inherited |
inherited |
staticinherited |
inherited |
staticinherited |
inherited |
| input | : sub matrix to put inside the Matrix4f. |
| row | : index of the row to start the 3x3 block. Must be 0 or 1. |
| column | : index of the column to start the 3x3 block. Must be 0 or 1. |
inherited |
| input | : sub vector to put inside the Matrix4f. |
| column | : index of the column to start the 3x3 block. By default, it is the last column (translation for a Pose). |
inherited |
inherited |
inherited |
