Core Module
Classes
struct  CameraOneConfiguration
 Structure containing information about the camera sensor. More...
struct  CameraOneInformation
 Structure containing information of a single camera (serial number, model, input type, etc.). More...
class  String
 Class defining a string. More...
struct  Resolution
 Structure containing the width and height of an image. More...
class  Rect
 Class defining a 2D rectangle with top-left corner coordinates and width/height in pixels. More...
class  Mat
 Class representing 1 to 4-channel matrix of float or uchar, stored on CPU and/or GPU side. More...
struct  CameraConfiguration
struct  CameraInformation
Enumerations
enum class  SERIALIZATION_FORMAT
 Lists available serialization format. More...
enum class  UNIT
 Lists available units for measures. More...
enum class  COORDINATE_SYSTEM
 Lists available coordinates systems for positional tracking and 3D measures. More...
enum class  ERROR_CODE
 Lists error codes in the ZED SDK. More...
enum class  MEM
 Lists available memory type. More...
enum class  COPY_TYPE
 Lists available copy operation on sl::Mat. More...
enum class  MAT_TYPE
 Lists available sl::Mat formats. More...
enum class  MODULE
 Lists available modules. More...
int getZEDSDKRuntimeVersion (int &major, int &minor, int &patch)
 Returns the ZED SDK version currently installed on the computer. More...
const void getZEDSDKBuildVersion (int &major, int &minor, int &patch)
 Returns the ZED SDK version which the current program has been compiled with. More...
String toVerbose (const ERROR_CODE &errorCode)
 Provide a concise sl::ERROR_CODE string. More...
◆ SERIALIZATION_FORMAT
enum SERIALIZATION_FORMAT
strong
Enumerator
LEGACY
JSON
AUTO
◆ UNIT
enum UNIT
strong
Enumerator
MILLIMETER
International System (1/1000 meters)
CENTIMETER
International System (1/100 meters)
METER
International System (1 meter)
INCH
Imperial Unit (1/12 feet)
FOOT
Imperial Unit (1 foot)
◆ COORDINATE_SYSTEM
enum COORDINATE_SYSTEM
strong
Enumerator
Standard coordinates system in computer vision.
Used in OpenCV: see here.
LEFT_HANDED_Y_UP
Left-handed with Y up and Z forward.
Used in Unity with DirectX.
RIGHT_HANDED_Y_UP
Right-handed with Y pointing up and Z backward.
Used in OpenGL.
RIGHT_HANDED_Z_UP
Right-handed with Z pointing up and Y forward.
Used in 3DSMax.
LEFT_HANDED_Z_UP
Left-handed with Z axis pointing up and X forward.
Used in Unreal Engine.
RIGHT_HANDED_Z_UP_X_FWD
Right-handed with Z pointing up and X forward.
Used in ROS (REP 103).
◆ ERROR_CODE
enum ERROR_CODE
strong
Enumerator
CONFIGURATION_FALLBACK
The operation could not proceed with the target configuration but did success with a fallback.
SENSORS_DATA_REQUIRED
The input data does not contains the high frequency sensors data, this is usually because it requires newer SVO/Streaming. In order to work this modules needs inertial data present in it input.
CORRUPTED_FRAME
The image could be corrupted (enabled with the parameter InitParameters::enable_image_validity_check).
CAMERA_REBOOTING
The camera is currently rebooting.
SUCCESS
Standard code for successful behavior.
FAILURE
Standard code for unsuccessful behavior.
NO_GPU_COMPATIBLE
No GPU found or CUDA capability of the device is not supported.
NOT_ENOUGH_GPU_MEMORY
Not enough GPU memory for this depth mode, try a different mode (such as PERFORMANCE), or increase the minimum depth value (see InitParameters::depth_minimum_distance).
CAMERA_NOT_DETECTED
No camera was detected.
SENSORS_NOT_INITIALIZED
The MCU that controls the sensors module has an invalid serial number. You can try to recover it by launching the ZED Diagnostic tool from the command line with the option -r.
SENSORS_NOT_AVAILABLE
A camera with sensor is detected but the sensors (IMU, barometer, ...) cannot be opened. Only the MODEL::ZED does not has sensors. Unplug/replug is required.
INVALID_RESOLUTION
In case of invalid resolution parameter, such as an upsize beyond the original image size in Camera::retrieveImage.
LOW_USB_BANDWIDTH
Insufficient bandwidth for the correct use of the camera. This issue can occur when you use multiple cameras or a USB 2.0 port.
CALIBRATION_FILE_NOT_AVAILABLE
The calibration file of the camera is not found on the host machine. Use ZED Explorer or ZED Calibration to download the factory calibration file.
INVALID_CALIBRATION_FILE
The calibration file is not valid. Try to download the factory calibration file or recalibrate your camera using ZED Calibration.
INVALID_SVO_FILE
The provided SVO file is not valid.
SVO_RECORDING_ERROR
An error occurred while trying to record an SVO (not enough free storage, invalid file, ...).
SVO_UNSUPPORTED_COMPRESSION
An SVO related error, occurs when NVIDIA based compression cannot be loaded.
END_OF_SVOFILE_REACHED
SVO end of file has been reached.
No frame will be available until the SVO position is reset.
INVALID_COORDINATE_SYSTEM
The requested coordinate system is not available.
INVALID_FIRMWARE
The firmware of the camera is out of date. Update to the latest version.
INVALID_FUNCTION_PARAMETERS
Invalid parameters have been given for the function.
CUDA_ERROR
A CUDA error has been detected in the process, in Camera.grab() or Camera.retrieveXXX() only. Activate verbose in Camera.open() for more info.
CAMERA_NOT_INITIALIZED
The ZED SDK is not initialized. Probably a missing call to Camera.open().
NVIDIA_DRIVER_OUT_OF_DATE
Your NVIDIA driver is too old and not compatible with your current CUDA version.
INVALID_FUNCTION_CALL
The call of the function is not valid in the current context. Could be a missing call of Camera.open().
CORRUPTED_SDK_INSTALLATION
The ZED SDK was not able to load its dependencies or some assets are missing. Reinstall the ZED SDK or check for missing dependencies (cuDNN, TensorRT).
INCOMPATIBLE_SDK_VERSION
The installed ZED SDK is incompatible with the one used to compile the program.
INVALID_AREA_FILE
The given area file does not exist. Check the path.
INCOMPATIBLE_AREA_FILE
The area file does not contain enough data to be used or the DEPTH_MODE used during the creation of the area file is different from the one currently set.
CAMERA_FAILED_TO_SETUP
Failed to open the camera at the proper resolution. Try another resolution or make sure that the UVC driver is properly installed.
CAMERA_DETECTION_ISSUE
Your camera can not be opened. Try replugging it to another port or flipping the USB-C connector (if there is one).
CANNOT_START_CAMERA_STREAM
Cannot start the camera stream. Make sure your camera is not already used by another process or blocked by firewall or antivirus.
NO_GPU_DETECTED
No GPU found. CUDA is unable to list it. Can be a driver/reboot issue.
PLANE_NOT_FOUND
Plane not found. Either no plane is detected in the scene, at the location or corresponding to the floor, or the floor plane doesn't match the prior given.
MODULE_NOT_COMPATIBLE_WITH_CAMERA
The module you try to use is not compatible with your camera MODEL.
Note
MODEL::ZED does not has an IMU and does not support the AI modules.
MOTION_SENSORS_REQUIRED
The module needs the sensors to be enabled (see InitParameters::sensors_required).
MODULE_NOT_COMPATIBLE_WITH_CUDA_VERSION
The module needs a newer version of CUDA.
◆ MEM
enum MEM
strong
Enumerator
CPU
Data will be stored on the CPU (processor side).
GPU
Data will be stored on the GPU (graphic card side).
◆ COPY_TYPE
enum COPY_TYPE
strong
Enumerator
CPU_CPU
Copy data from CPU to CPU.
CPU_GPU
Copy data from CPU to GPU.
GPU_GPU
Copy data from GPU to GPU.
GPU_CPU
Copy data from GPU to CPU.
◆ MAT_TYPE
enum MAT_TYPE
strong
Note
sl::Mat type depends on image or measure type.
For the dependencies, see sl::VIEW and sl::MEASURE.
Enumerator
F32_C1
1-channel matrix of float
F32_C2
2-channel matrix of float
F32_C3
3-channel matrix of float
F32_C4
U8_C1
1-channel matrix of unsigned char
U8_C2
2-channel matrix of unsigned char
U8_C3
3-channel matrix of unsigned char
U8_C4
4-channel matrix of unsigned char
U16_C1
1-channel matrix of unsigned short
S8_C4
4-channel matrix of signed char
◆ MODULE
enum MODULE
strong
Enumerator
ALL
All modules
DEPTH
POSITIONAL_TRACKING
OBJECT_DETECTION
BODY_TRACKING
SPATIAL_MAPPING
LAST
Function Documentation
◆ getZEDSDKRuntimeVersion()
int getZEDSDKRuntimeVersion ( int &  major,
int &  minor,
int &  patch
Parameters
major[out]: Major variable to be filled.
minor[out]: Minor variable to be filled.
patch[out]: Patch variable to be filled.
Returns
-1 if the ZED SDK was not found
-2 if the ZED SDK version wasn't found
0 if success
◆ getZEDSDKBuildVersion()
const void getZEDSDKBuildVersion ( int &  major,
int &  minor,
int &  patch
inline
Parameters
◆ toVerbose()
String sl::toVerbose ( const ERROR_CODE &  errorCode)
Returns
A concise sl::ERROR_CODE string for the user.
