Rect Class Reference
Class defining a 2D rectangle with top-left corner coordinates and width/height in pixels. More...
 Rect (size_t x_=0, size_t y_=0, size_t w_=0, size_t h_=0)
 Default constructor. More...
size_t area ()
 Returns the area of the rectangle. More...
bool operator== (const Rect &that) const
 Tests if the given sl::Rect has the same properties. More...
bool operator!= (const Rect &that) const
 Tests if the given sl::Rect has different properties. More...
bool isEmpty () const
 Tests if the given sl::Rect is empty (width or/and height is null). More...
bool contains (const Rect &target, bool proper=false) const
 Tests if this sl::Rect contains the target sl::Rect. More...
bool isContained (const Rect &target, bool proper=false) const
 Tests if this sl::Rect is contained inside the given target sl::Rect. More...
bool isContained (const Resolution &resolution, bool proper=false) const
 Overloaded method of isContained(). Tests if this sl::Rect is contained inside a given sl::Resolution. More...
Attributes
size_t x
 x coordinates of top-left corner. More...
size_t y
 y coordinates of top-left corner. More...
size_t width
 Width of the rectangle in pixels. More...
size_t height
 Height of the rectangle in pixels. More...
Constructor and Destructor
◆ Rect()
Rect ( size_t  x_ = 0,
size_t  y_ = 0,
size_t  w_ = 0,
size_t  h_ = 0
inline
◆ area()
size_t area ( )
inline
◆ operator==()
bool operator== ( const Rect &  that) const
inline
Returns
True if all the components matches.
◆ operator!=()
bool operator!= ( const Rect &  that) const
inline
Returns
True if one of the components does not match.
◆ isEmpty()
bool isEmpty ( ) const
inline
◆ contains()
bool contains ( const Rect &  target,
bool  proper = false
) const
inline
Returns
true if this rectangle contains the target rectangle, otherwise false.
Note
This method only returns true if the target rectangle is entirely inside this rectangle (not on the edge).
◆ isContained() [1/2]
bool isContained ( const Rect &  target,
bool  proper = false
) const
inline
Returns
true if this rectangle is inside the current target sl::Rect, otherwise false.
Note
This method only returns true if this rectangle is entirely inside the <target> rectangle (not on the edge).
◆ isContained() [2/2]
bool isContained ( const Resolution &  resolution,
bool  proper = false
) const
inline
It tests if the current rectangle is contained inside a sl::Rect defined by Rect(0, 0, resolution.width, resolution.height).
Returns
true if this rectangle is inside the rectangle defined by Rect(0, 0, resolution.width, resolution.height), otherwise false.
Note
This method only returns true if this rectangle is entirely inside the rectangle defined by the resolution (not on the edge).
Variables
◆ x
size_t x
Referenced by Rect::contains(), Rect::isContained(), Rect::operator!=(), and Rect::operator==().
◆ y
size_t y
◆ width
size_t width
◆ height
size_t height
