Resolution Struct Reference
Structure containing the width and height of an image. More...
 Resolution (size_t w_=0, size_t h_=0)
 Default constructor. More...
size_t area () const
 Returns the area (width * height) of the image. More...
bool operator== (const Resolution &that) const
 Tests if the given sl::Resolution has the same properties. More...
bool operator!= (const Resolution &that) const
 Tests if the given sl::Resolution has different properties. More...
Attributes
size_t width
 Width of the image in pixels. More...
size_t height
 Height of the image in pixels. More...
Constructor and Destructor
◆ Resolution()
Resolution ( size_t  w_ = 0,
size_t  h_ = 0
inline
◆ area()
size_t area ( ) const
inline
◆ operator==()
bool operator== ( const Resolution &  that) const
inline
Returns
True if the sizes matches.
◆ operator!=()
bool operator!= ( const Resolution &  that) const
inline
Returns
True if the sizes are not equal.
◆ encode()
) const
Parameters
Returns
◆ decode()
Parameters
Returns
Variables
◆ width
◆ height
size_t height
