Mat Class Reference
Class representing 1 to 4-channel matrix of float or uchar, stored on CPU and/or GPU side. More...
 Mat ()
 Default constructor. More...
 Mat (size_t width, size_t height, MAT_TYPE mat_type, MEM memory_type=MEM::CPU)
 Constructor. More...
 Mat (size_t width, size_t height, MAT_TYPE mat_type, sl::uchar1 *ptr, size_t step, MEM memory_type=MEM::CPU)
 Constructor from an existing data pointer. More...
 Mat (size_t width, size_t height, MAT_TYPE mat_type, sl::uchar1 *ptr_cpu, size_t step_cpu, sl::uchar1 *ptr_gpu, size_t step_gpu)
 Constructor from two existing data pointers, CPU and GPU. More...
 Mat (Resolution resolution, MAT_TYPE mat_type, MEM memory_type=MEM::CPU)
 Constructor from an sl::Resolution. More...
 Mat (Resolution resolution, MAT_TYPE mat_type, sl::uchar1 *ptr, size_t step, MEM memory_type=MEM::CPU)
 Mat (Resolution resolution, MAT_TYPE mat_type, sl::uchar1 *ptr_cpu, size_t step_cpu, sl::uchar1 *ptr_gpu, size_t step_gpu)
 Mat (const Mat &mat)
 Copy constructor (shallow copy). More...
void alloc (size_t width, size_t height, MAT_TYPE mat_type, MEM memory_type=MEM::CPU)
 Allocates the sl::Mat memory. More...
void alloc (Resolution resolution, MAT_TYPE mat_type, MEM memory_type=MEM::CPU)
 ~Mat ()
 Destructor. More...
void free (MEM memory_type=MEM::CPU|MEM::GPU)
 Free the owned memory. More...
Mat & operator= (const Mat &that)
 Performs a shallow copy. More...
ERROR_CODE updateCPUfromGPU (cudaStream_t stream=0)
 Downloads data from DEVICE (GPU) to HOST (CPU), if possible. More...
ERROR_CODE updateGPUfromCPU (cudaStream_t stream=0, int GPU_id=0)
 Uploads data from HOST (CPU) to DEVICE (GPU), if possible. More...
ERROR_CODE copyTo (Mat &dst, COPY_TYPE cpyType=COPY_TYPE::CPU_CPU, cudaStream_t stream=0) const
 Copies data an other sl::Mat (deep copy). More...
ERROR_CODE setFrom (const Mat &src, COPY_TYPE cpyType=COPY_TYPE::CPU_CPU, cudaStream_t stream=0)
 Copies data from an other sl::Mat (deep copy). More...
ERROR_CODE read (const String &filePath)
 Reads an image from a file. More...
ERROR_CODE write (const String &filePath, sl::MEM memory_type=sl::MEM::CPU, int compression_level=-1)
 Writes the sl::Mat (only if sl::MEM::CPU is available) into a file defined by its extension. More...
template<typename T >
ERROR_CODE setTo (const T &value, const sl::MEM memory_type=MEM::CPU, cudaStream_t stream=0)
 Fills the sl::Mat with the given value. More...
template<typename N >
ERROR_CODE setValue (const size_t x, const size_t y, const N &value, const sl::MEM memory_type=MEM::CPU)
 Sets a value to a specific point in the matrix. More...
ERROR_CODE getValue (const size_t x, const size_t y, N *value, const MEM memory_type=MEM::CPU) const
 Returns the value of a specific point in the matrix. More...
size_t getWidth () const
 Returns the width of the matrix. More...
size_t getHeight () const
 Returns the height of the matrix. More...
Resolution getResolution () const
 Returns the resolution (width and height) of the matrix. More...
size_t getChannels () const
 Returns the number of values stored in one pixel. More...
MAT_TYPE getDataType () const
 Returns the format of the matrix. More...
MEM getMemoryType () const
 Returns the type of memory (CPU and/or GPU). More...
N * getPtr (const MEM memory_type=MEM::CPU) const
 Returns the CPU or GPU data pointer. More...
size_t getStepBytes (const MEM memory_type=MEM::CPU) const
 Returns the memory step in bytes (size of one pixel row). More...
size_t getStep (MEM memory_type=MEM::CPU) const
 Returns the memory step in number of elements (size in one pixel row). More...
size_t getPixelBytes () const
 Returns the size of one pixel in bytes. More...
size_t getWidthBytes () const
 Returns the size of a row in bytes. More...
String getInfos ()
 Returns the information about the sl::Mat into a sl::String. More...
bool isInit () const
 Returns whether the sl::Mat is initialized or not. More...
bool isMemoryOwner () const
 Returns whether the sl::Mat is the owner of the memory it accesses. More...
ERROR_CODE clone (const Mat &src)
 Duplicates a sl::Mat by copy (deep copy). More...
ERROR_CODE move (Mat &dst)
 Moves the data of the sl::Mat to another sl::Mat. More...
Static Functions
static void swap (Mat &mat1, Mat &mat2)
 Swaps the content of the provided sl::Mat (only swaps the pointers, no data copy). More...
Attributes
String name = "n/a"
 Variable used in verbose mode to indicate which sl::Mat is printing informations. More...
bool verbose = false
 Whether the sl::Mat can display informations. More...
Timestamp timestamp = 0
 Timestamp of the last manipulation of the data of the matrix by a method/function. More...
This class is defined in a row-major order, meaning that for an image buffer, the rows are stored consecutively from top to bottom.
The CPU and GPU buffer aren't automatically synchronized for performance reasons, you can use updateCPUfromGPU / updateGPUfromCPU to do it.
If you are using the GPU side of the sl::Mat object, you need to make sure to call free before destroying the sl::Camera object.
The destruction of the sl::Camera object deletes the CUDA context needed to free the GPU sl::Mat memory.
Constructor and Destructor
◆ Mat() [1/8]
Mat ( )
The sl::Mat is empty (width = height = 0).
◆ Mat() [2/8]
Mat ( size_t  width,
size_t  height,
MAT_TYPE  mat_type,
MEM  memory_type = MEM::CPU
Constructor.
Initializes the sl::Mat and allocates the requested memory by calling alloc().
Parameters
width: Width of the matrix in pixels.
height: Height of the matrix in pixels.
mat_type: Type of the matrix (sl::MAT_TYPE::F32_C1, sl::MAT_TYPE::U8_C4, etc.).
memory_type: Where the buffer will be stored (sl::MEM::CPU and/or sl::MEM::GPU).
◆ Mat() [3/8]
Mat ( size_t  width,
size_t  height,
MAT_TYPE  mat_type,
sl::uchar1 *  ptr,
size_t  step,
Initializes the sl::Mat but does not allocate the memory.
Parameters
ptr: Pointer to the data array (CPU or GPU).
step: Step of the data array (bytes size of one pixel row).
◆ Mat() [4/8]
Mat ( size_t  width,
size_t  height,
MAT_TYPE  mat_type,
sl::uchar1 *  ptr_cpu,
size_t  step_cpu,
sl::uchar1 *  ptr_gpu,
size_t  step_gpu
Parameters
ptr_cpu: CPU pointer to the data array.
step_cpu: Step of the CPU data array (bytes size of one pixel row).
ptr_gpu: GPU pointer to the data array.
step_gpu: Step of the GPU data array (bytes size of one pixel row).
◆ Mat() [5/8]
Mat ( Resolution  resolution,
MAT_TYPE  mat_type,
Parameters
resolution: Size of the matrix in pixels.
◆ Mat() [6/8]
MAT_TYPE  mat_type,
sl::uchar1 *  ptr,
size_t  step,
Parameters
◆ Mat() [7/8]
MAT_TYPE  mat_type,
size_t  step_cpu,
size_t  step_gpu
Parameters
◆ Mat() [8/8]
Mat ( const Mat &  mat)
Parameters
mat: Reference to the sl::Mat to copy.
◆ ~Mat()
~Mat ( )
Destructor.
This method calls free to release owned memory.
◆ alloc() [1/2]
void alloc ( size_t  width,
size_t  height,
MAT_TYPE  mat_type,
Parameters
Warning
It erases previously allocated memory.
◆ alloc() [2/2]
void alloc ( Resolution  resolution,
MAT_TYPE  mat_type,
Parameters
Warning
◆ free()
void free ( MEM  memory_type = MEM::CPU|MEM::GPU)
Parameters
memory_type: Specifies whether you want to free the sl::MEM::CPU and/or sl::MEM::GPU memory.
◆ operator=()
Mat& operator= ( const Mat &  that)
This method does not copy the data array, it only copies the pointer.
Parameters
that: sl::Mat to be copied.
Returns
The new sl::Mat object which point to the same data as that.
◆ updateCPUfromGPU()
ERROR_CODE updateCPUfromGPU ( cudaStream_t  stream = 0)
Parameters
stream: Specifies the GPU stream to be used to enable asynchronous overlapping. Default: 0 (synchronous)
Returns
sl::ERROR_CODE::SUCCESS if everything went well, sl::ERROR_CODE::FAILURE otherwise.
Note
If no CPU or GPU memory are available for this sl::Mat, some are directly allocated.
If verbose is set to true, you have information in case of failure.
◆ updateGPUfromCPU()
ERROR_CODE updateGPUfromCPU ( cudaStream_t  stream = 0,
int  GPU_id = 0
Parameters
Returns
Note
◆ copyTo()
ERROR_CODE copyTo ( Mat &  dst,
COPY_TYPE  cpyType = COPY_TYPE::CPU_CPU,
) const
Parameters
dst: sl::Mat where the data will be copied.
cpyType: Specifies the memory that will be used for the copy.
Returns
Note
If the destination is not allocated or or doesn't have a compatible sl::MAT_TYPE or sl::Resolution, current memory is freed and new memory is directly allocated.
◆ setFrom()
ERROR_CODE setFrom ( const Mat &  src,
Parameters
src: sl::Mat where the data will be copied from.
Returns
Note
◆ read()
ERROR_CODE read ( const String &  filePath)
Parameters
filePath: Path of the file to read (including the name and extension).
Returns
Note
This method only support images such as JPG or PNG, and can't load float format such as PCD, PLY, etc.
◆ write()
ERROR_CODE write ( const String &  filePath,
sl::MEM  memory_type = sl::MEM::CPU,
int  compression_level = -1
Parameters
filePath: Path of the file to write in (including the name and extension).
memory_type: Memory type (CPU or GPU) of the sl::Mat.
compression_level: Level of compression between 0 (lowest compression == highest size == highest quality(jpg)) and 100 (highest compression == lowest size == lowest quality(jpg)).
Note
Specific/default value for compression_level = -1 : This will set the default quality for PNG(30) or JPEG(5).
compression_level is only supported for U8_Cx sl::MAT_TYPE.
Returns
Note
Supported sl::MAT_TYPE are:
◆ setTo()
ERROR_CODE setTo ( const T &  value,
const sl::MEM  memory_type = MEM::CPU,
This method overwrites all the matrix.
Parameters
value: Value to be copied all over the matrix.
memory_type: Which buffer to fill, CPU and/or GPU.
stream: a cuda stream to put the compute to (default 0).
Returns
Note
This method is templated for sl::uchar1, sl::uchar2, sl::uchar3, sl::uchar4, sl::float1, sl::float2, sl::float3, sl::float4, sl::char4, sl::ushort1.
◆ setValue()
ERROR_CODE setValue ( const size_t  x,
const size_t  y,
const N &  value,
Parameters
x: Column of the point to change.
y: Row of the point to change.
value: Value to be set.
memory_type: Which memory will be updated.
Returns
Note
Warning
Not efficient for sl::MEM::GPU, use it on sparse data.
◆ getValue()
ERROR_CODE getValue ( const size_t  x,
const size_t  y,
N *  value,
const MEM  memory_type = MEM::CPU
) const
Parameters
x: Column of the point to get the value from.
y: Row of the point to get the value from.
memory_type: Which memory should be read.
Returns
Note
Warning
◆ getWidth()
size_t getWidth ( ) const
inline
Returns
◆ getHeight()
size_t getHeight ( ) const
inline
Returns
◆ getResolution()
Resolution getResolution ( ) const
inline
Returns
Resolution of the matrix in pixels.
◆ getChannels()
size_t getChannels ( ) const
inline
Returns
Number of values in a pixel.
◆ getDataType()
MAT_TYPE getDataType ( ) const
inline
Returns
Format of the current sl::Mat.
◆ getMemoryType()
MEM getMemoryType ( ) const
inline
Returns
Type of allocated memory.
◆ getPtr()
N* getPtr ( const MEM  memory_type = MEM::CPU) const
Parameters
memory_type: Specifies whether you want sl::MEM::CPU or sl::MEM::GPU.
Returns
The pointer of the Mat data.
◆ getStepBytes()
size_t getStepBytes ( const MEM  memory_type = MEM::CPU) const
Parameters
memory_type: Specifies whether you want sl::MEM::CPU or sl::MEM::GPU step.
Returns
The step in bytes of the specified memory.
◆ getStep() [1/2]
size_t getStep ( MEM  memory_type = MEM::CPU) const
inline
Parameters
Returns
The step in number of elements.
◆ getStep() [2/2]
inline
Parameters
Returns
◆ getPixelBytes()
size_t getPixelBytes ( ) const
inline
Returns
Size of a pixel in bytes.
◆ getWidthBytes()
size_t getWidthBytes ( ) const
inline
Returns
Size of a row in bytes.
◆ getInfos()
String getInfos ( )
Returns
String containing the sl::Mat information.
◆ isInit()
bool isInit ( ) const
inline
Returns
True if current sl::Mat has been allocated (by the constructor or therefore).
◆ isMemoryOwner()
bool isMemoryOwner ( ) const
inline
If not, the memory won't be freed if the sl::Mat is destroyed.
Returns
True if the sl::Mat is owning its memory, else false.
◆ clone()
ERROR_CODE clone ( const Mat &  src)
Parameters
src: Reference of the sl::Mat to copy.
This method copies the data array(s) and it marks the new sl::Mat as the memory owner.
◆ move()
ERROR_CODE move ( Mat &  dst)
This method gives the attribute of the current s::Mat to the specified one. (No copy.)
Parameters
dst: Reference to the sl::Mat to move to.
Note
: The current sl::Mat is then no more usable since its loose its attributes.
◆ swap()
static void swap ( Mat &  mat1,
Mat &  mat2
static
This method swaps the pointers of the given sl::Mat.
Parameters
mat1: First matrix to swap.
mat2: Second matrix to swap.
Variables
◆ name
String name = "n/a"
Default set to "n/a" to avoid empty string if not filled.
◆ verbose
◆ timestamp
