Structure containing the intrinsic parameters of a camera. More...
Functions | |
| CameraParameters | scale (sl::Resolution const &output_resolution) const |
| Return the sl::CameraParameters for another resolution. More... | |
Attributes | |
| float | fx |
| Focal length in pixels along x axis. More... | |
| float | fy |
| Focal length in pixels along y axis. More... | |
| float | cx |
| Optical center along x axis, defined in pixels (usually close to width / 2). More... | |
| float | cy |
| Optical center along y axis, defined in pixels (usually close to height / 2). More... | |
| double | disto [12] |
| Distortion factor : [k1, k2, p1, p2, k3, k4, k5, k6, s1, s2, s3, s4]. More... | |
| float | v_fov |
| Vertical field of view, in degrees. More... | |
| float | h_fov |
| Horizontal field of view, in degrees. More... | |
| float | d_fov |
| Diagonal field of view, in degrees. More... | |
| Resolution | image_size |
| Size in pixels of the images given by the camera. More... | |
| float | focal_length_metric |
| Real focal length in millimeters. More... | |
That information about the camera will be returned by sl::Camera.getCameraInformation().
inline |
| output_resolution | : Resolution in which to get the new sl::CameraParameters. |
Referenced by CalibrationParameters::scale().
| float fx |
Referenced by CameraParameters::scale().
| float fy |
| float cx |
| float cy |
| double disto[12] |
Radial (k1, k2, k3, k4, k5, k6), Tangential (p1,p2) and Prism (s1, s2, s3, s4) distortion.
| float v_fov |
| float h_fov |
| float d_fov |
| Resolution image_size |
| float focal_length_metric |
