Holds the options used to initialize the Camera object.
Once passed to the Camera::open() function, these settings will be set for the entire execution life time of the Camera.
You can get further information in the detailed description bellow.
More...
General Functions | |
| InitParameters (RESOLUTION camera_resolution_=RESOLUTION_HD720, int camera_fps_=0, int camera_linux_id_=0, String svo_input_filename_=String(), bool svo_real_time_mode_=false, DEPTH_MODE depth_mode_=DEPTH_MODE_PERFORMANCE, UNIT coordinate_units_=UNIT_MILLIMETER, COORDINATE_SYSTEM coordinate_system_=COORDINATE_SYSTEM_IMAGE, bool sdk_verbose_=false, int sdk_gpu_id_=-1, float depth_minimum_distance_=-1., bool camera_disable_self_calib_=false, bool camera_image_flip_=false, bool enable_right_side_measure_=false, int camera_buffer_count_linux_=4, String sdk_verbose_log_file_=String(), int depth_stabilization_=1, CUcontext sdk_cuda_ctx_=CUcontext(), InputType input_type=InputType(), String optional_settings_path_=String(), bool camera_disable_imu_=false) | |
| Default constructor. All the parameters are set to their default and optimized values. More... | |
| bool | save (String filename) |
| bool | load (String filename) |
Attributes | |
| RESOLUTION | camera_resolution |
| int | camera_fps |
| int | camera_image_flip |
| bool | camera_disable_self_calib |
| bool | enable_right_side_measure |
| int | camera_buffer_count_linux |
| int | camera_linux_id |
| String | svo_input_filename |
| bool | svo_real_time_mode |
| DEPTH_MODE | depth_mode |
| int | depth_stabilization |
| float | depth_minimum_distance |
| UNIT | coordinate_units |
| COORDINATE_SYSTEM | coordinate_system |
| CUdevice | sdk_gpu_id |
| bool | sdk_verbose |
| String | sdk_verbose_log_file |
| CUcontext | sdk_cuda_ctx |
| InputType | input |
| String | optional_settings_path |
| bool | camera_disable_imu |
This structure allows you to select multiple parameters for the Camera such as the selected camera, its resolution, depth mode, coordinate system, and unit, of measurement. Once filled with the desired options, it should be passed to the Camera::open function.
With its default values, it opens the ZED camera in live mode at RESOLUTION_HD720 and sets the depth mode to DEPTH_MODE_PERFORMANCE.
You can customize it to fit your application. The parameters can also be saved and reloaded using its save() and load() functions.
inline |
| bool save | ( | String | filename | ) |
This function saves the current set of parameters into a file to be reloaded with the load() function.
| filename | : the path to the file in which the parameters will be stored. |
| bool load | ( | String | filename | ) |
This function set the other parameters from the values contained in a previously saved file.
| filename | : the path to the file from which the parameters will be loaded. |
| RESOLUTION camera_resolution |
Define the chosen camera resolution. Small resolutions offer higher framerate and lower computation time.
In most situations, the RESOLUTION_HD720 at 60 fps is the best balance between image quality and framerate.
Available resolutions are listed here: RESOLUTION.
default : RESOLUTION_HD720
| int camera_fps |
Requested camera frame rate. If set to 0, the highest FPS of the specified camera_resolution will be used.
See RESOLUTION for a list of supported framerates.
default : 0
| int camera_image_flip |
If you are using the camera upside down, setting this parameter to true will cancel its rotation. The images will be horizontally flipped.
default : false
| bool camera_disable_self_calib |
At initialization, the Camera runs a self-calibration process that corrects small offsets from the device's factory calibration.
A drawback is that calibration parameters will sligtly change from one run to another, which can be an issue for repeatability.
If set to true, self-calibration will be disabled and calibration parameters won't be optimized.
default : false
| bool enable_right_side_measure |
By default, the SDK only computes a single depth map, aligned with the left camera image.
This parameter allows you to enable the MEASURE_DEPTH_RIGHT and other MEASURE_<XXX>_RIGHT at the cost of additional computation time.
For example, mixed reality passthrough applications require one depth map per eye, so this parameter can be activated.
default : false
| int camera_buffer_count_linux |
Images coming from the camera will be saved in a FIFO buffer waiting for the program to call the Camera::grab() function.
On Linux Desktop : This parameter sets the buffer size between 2 and 5. Low values will reduce the latency but can also produce more corrupted frames.
On Jetson Boards : This parameter is fixed to 2 for memory and performance optimizations.
On Windows Desktop : The images aren't buffered, so this parameter won't be interpreted.
default: 4 on Linux Desktop, 2 on Jetson.
| int camera_linux_id |
Only for Linux : This parameter allows you to select the ZED device to be opened when multiple cameras are connected. This ID matches the system ID found in /dev/videoX.
default : 0
| String svo_input_filename |
The Camera object can be used with a live ZED or a recorded sequence saved in an SVO file.
This parameter allows you to specify the path to the recorded sequence to be played back.
default : (empty)
| bool svo_real_time_mode |
When playing back an SVO file, each call to Camera::grab() will extract a new frame and use it.
However, this ignores the real capture rate of the images saved in the SVO file.
Enabling this parameter will bring the SDK closer to a real simulation when playing back a file by using the images' timestamps. However, calls to Camera::grab() will return an error when trying to play to fast, and frames will be dropped when playing too slowly.
default : false
| DEPTH_MODE depth_mode |
The SDK offers several DEPTH_MODE options offering various level of performance and accuracy.
This parameter allows you to set the DEPTH_MODE that best matches your needs.
default : DEPTH_MODE_PERFORMANCE
| int depth_stabilization |
Regions of the generated depth map can oscillate from one frame to another. These oscillations result from a lack of texture (too homogeneous) on an object and by image noise.
This parameter enables a stabilization filter that reduces these oscilations.
default : true
| float depth_minimum_distance |
This parameter allows you to specify the minimum depth value (from the camera) that will be computed, measured in the UNIT you define.
In stereovision (the depth technology used by the camera), looking for closer depth values can have a slight impact on performance. However, this difference is almost invisible on modern GPUs.
In cases of limited computation power, increasing this value can provide better performance.
default : (-1) corresponding to 700 mm for a ZED and 200 mm for ZED Mini.
| UNIT coordinate_units |
This parameter allows you to select the unit to be used for all metric values of the SDK. (depth, point cloud, tracking, mesh, and others).
default : UNIT_MILLIMETER
| COORDINATE_SYSTEM coordinate_system |
Positional tracking, point clouds and many other features require a given COORDINATE_SYSTEM to be used as reference. This parameter allows you to select the COORDINATE_SYSTEM use by the Camera to return its measures.
default : COORDINATE_SYSTEM_IMAGE
| CUdevice sdk_gpu_id |
By default the SDK will use the most powerful NVIDIA graphics card found. However, when running several applications, or using several cameras at the same time, splitting the load over available GPUs can be useful. This parameter allows you to select the GPU used by the Camera using an ID from 0 to n-1 GPUs in your PC.
default : -1
| bool sdk_verbose |
This parameters allows you to enable the verbosity of the SDK to get a variety of runtime information in the console. When developing an application, enabling verbose mode can help you understand the current SDK behavior.
However, this might not be desirable in a shipped version.
default : false
| String sdk_verbose_log_file |
When sdk_verbose is enabled, this parameter allows you to redirect both the SDK verbose messages and your own application messages to a file.
default : (empty) Should contain the path to the file to be written. A file will be created if missing.
| CUcontext sdk_cuda_ctx |
If your application uses another CUDA-capable library, giving its CUDA context to the SDK can be useful when sharing GPU memories.
This parameter allows you to set the CUDA context to be used by the SDK.
Leaving this parameter empty asks the SDK to create its own context.
default : (empty)
| InputType input |
The SDK can handle different input types:
This parameter allows you to select to desired input. It should be used like this:
Available cameras and their ID/serial can be listed using Camera::getDeviceList and Camera::getStreamingDeviceList.
Each Camera will create its own memory (CPU and GPU), therefore the number of ZED used at the same time can be limited by the configuration of your computer. (GPU/CPU memory and capabilities)
default : (empty)
See InputType for complementary information.
| String optional_settings_path |
Set the optional path where the SDK has to search for the settings files (SN<XXXX>.conf files). Those file contains the calibration of the camera.
default : (empty). The SNXXX.conf file will be searched in the default directory (/usr/local/zed/settings/ for Linux or C:/ProgramData/stereolabs/settings for Windows)
| bool camera_disable_imu |
Disable the IMU of the ZED-M.
default : false.
If set to true, the SDK will not try to open and use the IMU (second USB device on USB2.0) of the ZED-M. This is an advanced control and must be used only if IMU is not needed.
This can be used for example when using a USB3.0 only extension cable (some fiber extension for example).
This parameter only impacts the LIVE mode.
