This is the complete list of members for InitParameters, including all inherited members.
| camera_buffer_count_linux | InitParameters | |
| camera_disable_imu | InitParameters | |
| camera_disable_self_calib | InitParameters | |
| camera_fps | InitParameters | |
| camera_image_flip | InitParameters | |
| camera_linux_id | InitParameters | |
| camera_resolution | InitParameters | |
| coordinate_system | InitParameters | |
| coordinate_units | InitParameters | |
| depth_minimum_distance | InitParameters | |
| depth_mode | InitParameters | |
| depth_stabilization | InitParameters | |
| enable_right_side_measure | InitParameters | |
| InitParameters(RESOLUTION camera_resolution_=RESOLUTION_HD720, int camera_fps_=0, int camera_linux_id_=0, String svo_input_filename_=String(), bool svo_real_time_mode_=false, DEPTH_MODE depth_mode_=DEPTH_MODE_PERFORMANCE, UNIT coordinate_units_=UNIT_MILLIMETER, COORDINATE_SYSTEM coordinate_system_=COORDINATE_SYSTEM_IMAGE, bool sdk_verbose_=false, int sdk_gpu_id_=-1, float depth_minimum_distance_=-1., bool camera_disable_self_calib_=false, bool camera_image_flip_=false, bool enable_right_side_measure_=false, int camera_buffer_count_linux_=4, String sdk_verbose_log_file_=String(), int depth_stabilization_=1, CUcontext sdk_cuda_ctx_=CUcontext(), InputType input_type=InputType(), String optional_settings_path_=String(), bool camera_disable_imu_=false) | InitParameters | inline |
| input | InitParameters | |
| load(String filename) | InitParameters | |
| optional_settings_path | InitParameters | |
| save(String filename) | InitParameters | |
| sdk_cuda_ctx | InitParameters | |
| sdk_gpu_id | InitParameters | |
| sdk_verbose | InitParameters | |
| sdk_verbose_log_file | InitParameters | |
| svo_input_filename | InitParameters | |
| svo_real_time_mode | InitParameters |
