Classes | |
| class | InitParameters |
| Holds the options used to initialize the Camera object. Once passed to the Camera::open() function, these settings will be set for the entire execution life time of the Camera. You can get further information in the detailed description bellow. . More... | |
| class | StreamingParameters |
| Sets the streaming parameters. More... | |
| class | Camera |
| This class is the main interface with the camera and the SDK features, suche as: video, depth, tracking, mapping, and more. Find more information in the detailed description below. . More... | |
| struct | CameraInformation |
| Structure containing information of a signle camera (serial number, model, calibration, etc.) More... | |
| struct | RecordingState |
| Recording structure that contains information about SVO. More... | |
Enumerations | |
| enum | RESOLUTION |
| Represents the available resolution defined in the cameraResolution list. More... | |
| enum | CAMERA_SETTINGS |
| Lists available camera settings for the ZED camera (contrast, hue, saturation, gain...). More... | |
| enum | SELF_CALIBRATION_STATE |
| Status for asynchrnous self-calibration. More... | |
| enum | VIEW |
| Lists available views. More... | |
| enum | TIME_REFERENCE |
| Lists specific and particular timestamps. More... | |
| enum | SVO_COMPRESSION_MODE |
| Lists available compression modes for SVO recording. More... | |
Functions | |
| String | toString (const RESOLUTION &resolution) |
| Converts the given enumerated value into readable text. More... | |
| String | toString (const CAMERA_SETTINGS &camSettings) |
| String | toString (const SELF_CALIBRATION_STATE &selfCalibState) |
| String | toString (const VIEW &view) |
| String | toString (const TIME_REFERENCE &time_reference) |
| String | toString (const SVO_COMPRESSION_MODE &svo_compression) |
| String | resolution2str (RESOLUTION res) |
| Converts the given RESOLUTION into a string. More... | |
| String | statusCode2str (SELF_CALIBRATION_STATE state) |
| Converts the given SELF_CALIBRATION_STATE into a string. More... | |
ZED Camera Resolution | |
| static const std::vector< std::pair< int, int > > | cameraResolution |
| Lists available video modes for the ZED camera. std::vector<std::pair(width, height)> More... | |
| enum RESOLUTION |
| enum CAMERA_SETTINGS |
| Enumerator | |
| CAMERA_SETTINGS_BRIGHTNESS | Defines the brightness control. Affected value should be between 0 and 8. |
| CAMERA_SETTINGS_CONTRAST | Defines the contrast control. Affected value should be between 0 and 8. |
| CAMERA_SETTINGS_HUE | Defines the hue control. Affected value should be between 0 and 11. |
| CAMERA_SETTINGS_SATURATION | Defines the saturation control. Affected value should be between 0 and 8. |
| CAMERA_SETTINGS_GAIN | Defines the gain control. Affected value should be between 0 and 100 for manual control. |
| CAMERA_SETTINGS_EXPOSURE | Defines the exposure control. Affected value should be between 0 and 100 for manual control.
| CAMERA_SETTINGS_WHITEBALANCE | Defines the color temperature control. Affected value should be between 2800 and 6500 with a step of 100. |
| CAMERA_SETTINGS_AUTO_WHITEBALANCE | Defines the status of white balance (automatic or manual). A value of 0 disable the AWB, while 1 activate it. |
| CAMERA_SETTINGS_LED_STATUS | Defines the status of the camera front LED. Set to 0 to disable the light, 1 to enable the light. Default value is on. Requires Camera FW 1523 at least. |
| CAMERA_SETTINGS_LAST | |
| Enumerator | |
| SELF_CALIBRATION_STATE_NOT_STARTED | Self calibration has not run yet (no sl::Camera::open or sl::Camera::resetSelfCalibration called). |
| SELF_CALIBRATION_STATE_RUNNING | Self calibration is currently running. |
| SELF_CALIBRATION_STATE_FAILED | Self calibration has finished running but did not manage to get accurate values. Old parameters are taken instead. |
| SELF_CALIBRATION_STATE_SUCCESS | Self calibration has finished running and did manage to get accurate values. New parameters are set. |
| SELF_CALIBRATION_STATE_LAST | |
| enum VIEW |
| Enumerator | |
| VIEW_LEFT | Left RGBA image. Each pixel contains 4 usigned char (R,G,B,A). sl::MAT_TYPE_8U_C4. |
| VIEW_RIGHT | Right RGBA image. Each pixel contains 4 usigned char (R,G,B,A). sl::MAT_TYPE_8U_C4. |
| VIEW_LEFT_GRAY | Left GRAY image. Each pixel contains 1 usigned char. sl::MAT_TYPE_8U_C1. |
| VIEW_RIGHT_GRAY | Right GRAY image. Each pixel contains 1 usigned char. sl::MAT_TYPE_8U_C1. |
| VIEW_LEFT_UNRECTIFIED | Left RGBA unrectified image. Each pixel contains 4 usigned char (R,G,B,A). sl::MAT_TYPE_8U_C4. |
| VIEW_RIGHT_UNRECTIFIED | Right RGBA unrectified image. Each pixel contains 4 usigned char (R,G,B,A). sl::MAT_TYPE_8U_C4. |
| VIEW_LEFT_UNRECTIFIED_GRAY | Left GRAY unrectified image. Each pixel contains 1 usigned char. sl::MAT_TYPE_8U_C1. |
| VIEW_RIGHT_UNRECTIFIED_GRAY | Right GRAY unrectified image. Each pixel contains 1 usigned char. sl::MAT_TYPE_8U_C1. |
| VIEW_SIDE_BY_SIDE | Left and right image (the image width is therefore doubled). Each pixel contains 4 usigned char (R,G,B,A). sl::MAT_TYPE_8U_C4. |
| VIEW_DEPTH | Color rendering of the depth. Each pixel contains 4 usigned char (R,G,B,A). sl::MAT_TYPE_8U_C4. Use MEASURE_DEPTH with Camera::retrieveMeasure() to get depth values. |
| VIEW_CONFIDENCE | Color rendering of the depth confidence. Each pixel contains 4 usigned char (R,G,B,A). sl::MAT_TYPE_8U_C4. |
| VIEW_NORMALS | Color rendering of the normals. Each pixel contains 4 usigned char (R,G,B,A). sl::MAT_TYPE_8U_C4. |
| VIEW_DEPTH_RIGHT | Color rendering of the right depth mapped on right sensor, sl::MAT_TYPE_8U_C4. |
| VIEW_NORMALS_RIGHT | Color rendering of the normals mapped on right sensor. Each pixel contains 4 usigned char (R,G,B,A). sl::MAT_TYPE_8U_C4. |
| VIEW_LAST | |
| enum TIME_REFERENCE |
| enum SVO_COMPRESSION_MODE |
sl::SVO_COMPRESSION_MODE_LOSSLESS is an improvement of previous lossless compression (used in ZED Explorer), even if size may be bigger, compression time is much faster.
| Enumerator | |
| SVO_COMPRESSION_MODE_RAW | RAW images, no compression.
| SVO_COMPRESSION_MODE_LOSSLESS | PNG/ZSTD (lossless) CPU based compression : avg size = 42% (of RAW). |
| SVO_COMPRESSION_MODE_LOSSY | JPEG (lossy) CPU based compression : avg size = 22% (of RAW). More compressed but can introduce compression artifacts. |
| SVO_COMPRESSION_MODE_AVCHD | H264(AVCHD) GPU based compression : avg size = 1% (of RAW). Requires a NVIDIA GPU |
| SVO_COMPRESSION_MODE_HEVC | H265(HEVC) GPU based compression: avg size = 1% (of raw). Requires a NVIDIA GPU |
| SVO_COMPRESSION_MODE_LAST | |
| String sl::toString | ( | const RESOLUTION & | resolution | ) |
| String sl::toString | ( | const CAMERA_SETTINGS & | camSettings | ) |
| String sl::toString | ( | const SELF_CALIBRATION_STATE & | selfCalibState | ) |
| String sl::toString | ( | const TIME_REFERENCE & | time_reference | ) |
| String sl::toString | ( | const SVO_COMPRESSION_MODE & | svo_compression | ) |
| String sl::resolution2str | ( | RESOLUTION | res | ) |
| res | : a specific RESOLUTION |
| String sl::statusCode2str | ( | SELF_CALIBRATION_STATE | state | ) |
| state | : a specific SELF_CALIBRATION_STATE |
static |
