Spatial Mapping Module
Classes
class  MeshFilterParameters
 Defines the behavior of the sl::Mesh::filter function. More...
class  Texture
 Contains information about texture image associated to a Mesh. More...
class  Chunk
 Represents a sub-mesh, it contains local vertices and triangles. More...
class  Mesh
 A mesh contains the geometric (and optionally texture) data of the scene captured by spatial mapping. More...
class  PointCloudChunk
 Represents a sub fused point cloud, it contains local vertices and colors. More...
class  FusedPointCloud
 A fused point cloud contains both geometric and color data of the scene captured by spatial mapping. More...
class  SpatialMappingParameters
 Sets the spatial mapping parameters. More...
Enumerations
enum  MESH_FILE_FORMAT
 Lists available mesh file formats. More...
enum  MESH_TEXTURE_FORMAT
 Lists available mesh texture formats. More...
enum  SPATIAL_MAP_TYPE
 Lists the types of spatial maps that can be created. More...
enum  MAPPING_RESOLUTION
 List the spatial mapping resolution presets. More...
enum  MAPPING_RANGE
 Lists the spatial mapping depth range presets. More...
enum  AREA_EXPORT_STATE
 Lists the different states of spatial memory area export. More...
enum  SPATIAL_MAPPING_STATE
 Gives the spatial mapping state. More...
String toString (const MESH_FILE_FORMAT &mesh_frmt)
 Converts the given enumerated value into readable text. More...
String toString (const MESH_TEXTURE_FORMAT &text_frmt)
String toString (const MeshFilterParameters::MESH_FILTER &mesh_filter)
String toString (const SpatialMappingParameters::MAPPING_RESOLUTION &resolution)
String toString (const SpatialMappingParameters::MAPPING_RANGE &range)
String toString (const SpatialMappingParameters::SPATIAL_MAP_TYPE &map_type)
String toString (const AREA_EXPORT_STATE &area_export)
String toString (const SPATIAL_MAPPING_STATE &mapping_state)
String spatialMappingState2str (SPATIAL_MAPPING_STATE state)
 Converts the given SPATIAL_MAPPING_STATE into a string. More...
◆ MESH_FILE_FORMAT
Enumerator
MESH_FILE_PLY
Contains only vertices and faces.
MESH_FILE_PLY_BIN
Contains only vertices and faces, encoded in binary.
MESH_FILE_OBJ
Contains vertices, normals, faces and textures informations if possible.
MESH_FILE_LAST
◆ MESH_TEXTURE_FORMAT
Enumerator
MESH_TEXTURE_RGB
The texture has 3 channels.
MESH_TEXTURE_RGBA
The texture has 4 channels.
MESH_TEXTURE_LAST
◆ SPATIAL_MAP_TYPE
Enumerator
SPATIAL_MAP_TYPE_MESH
Represent a surface with faces, 3D points are linked by edges, no color information.
SPATIAL_MAP_TYPE_FUSED_POINT_CLOUD
Geometry is represented by a set of 3D colored points.
◆ MAPPING_RESOLUTION
Enumerator
MAPPING_RESOLUTION_HIGH
Create a detail geometry, requires lots of memory.
MAPPING_RESOLUTION_MEDIUM
Smalls variations in the geometry will disappear, useful for big object
MAPPING_RESOLUTION_LOW
Keeps only huge variations of the geometry , useful outdoor.
◆ MAPPING_RANGE
Deprecated:
Since SDK 2.6, range is computed from the requested resolution and internal parameters to best fit the current application.
Enumerator
MAPPING_RANGE_NEAR
Only depth close to the camera will be used during spatial mapping.
MAPPING_RANGE_MEDIUM
Medium depth range.
MAPPING_RANGE_FAR
Takes into account objects that are far, useful outdoor.
MAPPING_RANGE_AUTO
Depth range will be computed based on current Camera states and parameters.
◆ AREA_EXPORT_STATE
Enumerator
AREA_EXPORT_STATE_SUCCESS
The spatial memory file has been successfully created.
AREA_EXPORT_STATE_RUNNING
The spatial memory is currently written.
AREA_EXPORT_STATE_NOT_STARTED
The spatial memory file exportation has not been called.
AREA_EXPORT_STATE_FILE_EMPTY
The spatial memory contains no data, the file is empty.
AREA_EXPORT_STATE_FILE_ERROR
The spatial memory file has not been written because of a wrong file name.
AREA_EXPORT_STATE_SPATIAL_MEMORY_DISABLED
The spatial memory learning is disable, no file can be created.
AREA_EXPORT_STATE_LAST
◆ SPATIAL_MAPPING_STATE
Enumerator
SPATIAL_MAPPING_STATE_INITIALIZING
The spatial mapping is initializing.
SPATIAL_MAPPING_STATE_OK
The depth and tracking data were correctly integrated in the fusion algorithm.
SPATIAL_MAPPING_STATE_NOT_ENOUGH_MEMORY
The maximum memory dedicated to the scanning has been reach, the mesh will no longer be updated.
SPATIAL_MAPPING_STATE_NOT_ENABLED
Camera::enableSpatialMapping() wasn't called (or the scanning was stopped and not relaunched).
SPATIAL_MAPPING_STATE_FPS_TOO_LOW
Effective FPS is too low to give proper results for spatial mapping. Consider using PERFORMANCES parameters (DEPTH_MODE_PERFORMANCE, low camera resolution (VGA,HD720), spatial mapping low resolution)
SPATIAL_MAPPING_STATE_LAST
Function Documentation
◆ toString() [1/8]
String sl::toString ( const MESH_FILE_FORMAT &  mesh_frmt)
Returns
The enumerated value as a string.
◆ toString() [2/8]
String sl::toString ( const MESH_TEXTURE_FORMAT &  text_frmt)
Returns
◆ toString() [3/8]
String sl::toString ( const MeshFilterParameters::MESH_FILTER &  mesh_filter)
Returns
◆ toString() [4/8]
String sl::toString ( const SpatialMappingParameters::MAPPING_RESOLUTION &  resolution)
Returns
◆ toString() [5/8]
String sl::toString ( const SpatialMappingParameters::MAPPING_RANGE &  range)
Returns
◆ toString() [6/8]
String sl::toString ( const SpatialMappingParameters::SPATIAL_MAP_TYPE &  map_type)
Returns
◆ toString() [7/8]
String sl::toString ( const AREA_EXPORT_STATE &  area_export)
Returns
◆ toString() [8/8]
String sl::toString ( const SPATIAL_MAPPING_STATE &  mapping_state)
Returns
◆ spatialMappingState2str()
String sl::spatialMappingState2str ( SPATIAL_MAPPING_STATE  state)
Parameters
state: a specific SPATIAL_MAPPING_STATE
Returns
The corresponding string
Deprecated:
See toString.
