SpatialMappingParameters Class Reference
Sets the spatial mapping parameters. More...
Types
enum  SPATIAL_MAP_TYPE
 Lists the types of spatial maps that can be created. More...
enum  MAPPING_RESOLUTION
 List the spatial mapping resolution presets. More...
enum  MAPPING_RANGE
 Lists the spatial mapping depth range presets. More...
typedef std::pair< float, float > interval
General Functions
 SpatialMappingParameters (MAPPING_RESOLUTION resolution=MAPPING_RESOLUTION_MEDIUM, MAPPING_RANGE range=MAPPING_RANGE_AUTO, int max_memory_usage_=2048, bool save_texture_=false, bool use_chunk_only_=false, bool reverse_vertex_order_=false, SPATIAL_MAP_TYPE map_type=SPATIAL_MAP_TYPE_MESH)
 Default constructor. Sets all parameters to their default and optimized values. More...
void set (MAPPING_RESOLUTION mapping_resolution=MAPPING_RESOLUTION_MEDIUM)
 Sets the resolution corresponding to the given RESOLUTION preset. More...
void set (MAPPING_RANGE mapping_range=MAPPING_RANGE_MEDIUM)
 Sets the maximum value of the depth corresponding to the given RANGE preset. More...
bool save (String filename)
 Saves the current set of parameters into a file. More...
bool load (String filename)
 Loads the values of the parameters contained in a file. More...
Static Functions
static float get (MAPPING_RESOLUTION mapping_resolution=MAPPING_RESOLUTION_MEDIUM)
 Returns the resolution corresponding to the given RESOLUTION preset. More...
static float getRecommendedRange (MAPPING_RESOLUTION mapping_resolution, Camera &camera)
 Returns the recommended maximum depth value for the given MAPPING_RESOLUTION preset. More...
static float getRecommendedRange (float resolution_meters, Camera &camera)
static float get (MAPPING_RANGE mapping_range=MAPPING_RANGE_MEDIUM)
 Returns the maximum value of depth corresponding to the given RANGE presets. More...
Attributes
float resolution_meter = 0.05f
 Spatial mapping resolution in meters. Should fit allowed_resolution. More...
const interval allowed_resolution = std::make_pair(0.01f, 0.2f)
 The resolutions allowed by the spatial mapping.
allowed_resolution.first is the minimum value allowed.
allowed_resolution.second is the maximum value allowed. More...
float range_meter = 0.f
 Depth range in meters. Can be different from the value set by setDepthMaxRangeValue.
Set to 0 by default. In this case, the range is computed from resolution_meter and from the current internal parameters to fit your application. More...
const interval allowed_range = std::make_pair(2.f, 20.f)
 Range of the maximum depth value allowed by spatial mapping.
allowed_range.first is the minimum value allowed.
allowed_range.second is the maximum value allowed. More...
bool save_texture = false
 Set to true if you want to be able to apply the texture to your mesh after its creation. More...
bool use_chunk_only = false
 Set to false if you want to ensure consistency between the mesh and its inner chunk data. More...
int max_memory_usage = 2048
 The maximum CPU memory (in megabytes) allocated for the meshing process. More...
bool reverse_vertex_order = false
 Specify if the order of the vertices of the triangles needs to be inverted. If your display process does not handle front and back face culling, you can use this to correct it. More...
SPATIAL_MAP_TYPE map_type = SPATIAL_MAP_TYPE_MESH
 The type of spatial map to be created. This dictates the format that will be used for the mapping(e.g. mesh, point cloud). See SPATIAL_MAP_TYPE. More...
Instantiating with the default constructor sets all parameters to their default values.
You can customize these values to fit your application, and then save them to a preset to be loaded in future executions.
Note
Users can adjust these parameters as they see fit.
Member Typedef Documentation
◆ interval
typedef std::pair<float, float> interval
Constructor and Destructor
◆ SpatialMappingParameters()
SpatialMappingParameters ( MAPPING_RESOLUTION  resolution = MAPPING_RESOLUTION_MEDIUM,
MAPPING_RANGE  range = MAPPING_RANGE_AUTO,
int  max_memory_usage_ = 2048,
bool  save_texture_ = false,
bool  use_chunk_only_ = false,
bool  reverse_vertex_order_ = false,
◆ get() [1/2]
static float get ( MAPPING_RESOLUTION  mapping_resolution = MAPPING_RESOLUTION_MEDIUM)
static
Parameters
mapping_resolutionThe desired RESOLUTION. Default: RESOLUTION_HIGH.
Returns
The resolution in meters.
◆ set() [1/2]
void set ( MAPPING_RESOLUTION  mapping_resolution = MAPPING_RESOLUTION_MEDIUM)
Parameters
◆ getRecommendedRange() [1/2]
static float getRecommendedRange ( MAPPING_RESOLUTION  mapping_resolution,
Camera &  camera
static
Parameters
mapping_resolutionThe desired MAPPING_RESOLUTION.
cameraThe Camera object that will run the spatial mapping.
Returns
The maximum value of the depth in meters.
◆ getRecommendedRange() [2/2]
static float getRecommendedRange ( float  resolution_meters,
Camera &  camera
static
Parameters
resolution_metersThe desired resolution in meters.
Returns
◆ get() [2/2]
static float get ( MAPPING_RANGE  mapping_range = MAPPING_RANGE_MEDIUM)
static
Parameters
mapping_rangeThe desired RANGE. Default: RANGE_MEDIUM.
Returns
The maximum value of the depth.
Deprecated:
Since SDK 2.6, the range is computed from the requested resolution and internal parameters to best fit the current application.
◆ set() [2/2]
void set ( MAPPING_RANGE  mapping_range = MAPPING_RANGE_MEDIUM)
Parameters
Deprecated:
◆ save()
bool save ( String  filename)
Parameters
filenamethe path to the file in which the parameters will be stored.
Returns
Ttrue if the file was successfully saved. false otherwise.
◆ load()
bool load ( String  filename)
Parameters
filenamethe path to the file from which the parameters will be loaded.
Returns
true if the file was successfully loaded. false otherwise.
Variables
◆ resolution_meter
◆ allowed_resolution
◆ range_meter
Deprecated:
Since SDK 2.6, we recommend leaving this to 0.
◆ allowed_range
◆ save_texture
Note
This option will consume more memory.
This option is only available for SPATIAL_MAP_TYPE_MESH
◆ use_chunk_only
Note
Updating the mesh is time-consuming. Setting this to true results in better performance.
◆ max_memory_usage
◆ reverse_vertex_order
Note
◆ map_type
