SpatialMappingParameters Member List
This is the complete list of members for SpatialMappingParameters, including all inherited members.
allowed_rangeSpatialMappingParameters
allowed_resolutionSpatialMappingParameters
get(MAPPING_RESOLUTION mapping_resolution=MAPPING_RESOLUTION_MEDIUM)SpatialMappingParametersstatic
get(MAPPING_RANGE mapping_range=MAPPING_RANGE_MEDIUM)SpatialMappingParametersstatic
getRecommendedRange(MAPPING_RESOLUTION mapping_resolution, Camera &camera)SpatialMappingParametersstatic
getRecommendedRange(float resolution_meters, Camera &camera)SpatialMappingParametersstatic
interval typedefSpatialMappingParameters
load(String filename)SpatialMappingParameters
map_typeSpatialMappingParameters
MAPPING_RANGE enum nameSpatialMappingParameters
MAPPING_RANGE_AUTO enum valueSpatialMappingParameters
MAPPING_RANGE_FAR enum valueSpatialMappingParameters
MAPPING_RANGE_MEDIUM enum valueSpatialMappingParameters
MAPPING_RANGE_NEAR enum valueSpatialMappingParameters
MAPPING_RESOLUTION enum nameSpatialMappingParameters
MAPPING_RESOLUTION_HIGH enum valueSpatialMappingParameters
MAPPING_RESOLUTION_LOW enum valueSpatialMappingParameters
MAPPING_RESOLUTION_MEDIUM enum valueSpatialMappingParameters
max_memory_usageSpatialMappingParameters
range_meterSpatialMappingParameters
resolution_meterSpatialMappingParameters
reverse_vertex_orderSpatialMappingParameters
save(String filename)SpatialMappingParameters
save_textureSpatialMappingParameters
set(MAPPING_RESOLUTION mapping_resolution=MAPPING_RESOLUTION_MEDIUM)SpatialMappingParameters
set(MAPPING_RANGE mapping_range=MAPPING_RANGE_MEDIUM)SpatialMappingParameters
SPATIAL_MAP_TYPE enum nameSpatialMappingParameters
SPATIAL_MAP_TYPE_FUSED_POINT_CLOUD enum valueSpatialMappingParameters
SPATIAL_MAP_TYPE_MESH enum valueSpatialMappingParameters
SpatialMappingParameters(MAPPING_RESOLUTION resolution=MAPPING_RESOLUTION_MEDIUM, MAPPING_RANGE range=MAPPING_RANGE_AUTO, int max_memory_usage_=2048, bool save_texture_=false, bool use_chunk_only_=false, bool reverse_vertex_order_=false, SPATIAL_MAP_TYPE map_type=SPATIAL_MAP_TYPE_MESH)SpatialMappingParameters
use_chunk_onlySpatialMappingParameters
