A fused point cloud contains both geometric and color data of the scene captured by spatial mapping. More...
Types | |
| typedef std::vector< size_t > | chunkList |
General Functions | |
| FusedPointCloud () | |
| Default constructor which creates an empty FusedPointCloud. More... | |
| ~FusedPointCloud () | |
| FusedPointCloud destructor. More... | |
| PointCloudChunk & | operator[] (int index) |
| Defines the [] operator to directly access the desired chunk. More... | |
| size_t | getNumberOfPoints () |
| Computes the total number of triangles stored in all chunks. More... | |
| void | updateFromChunkList (chunkList IDs=chunkList(0)) |
| Updates vertices / normals / colors from chunks' data pointed by the given chunkList. More... | |
| bool | save (String filename, MESH_FILE_FORMAT type=MESH_FILE_OBJ, chunkList IDs=chunkList(0)) |
| Saves the current fused point cloud into a file. More... | |
| bool | load (String filename, bool update_chunk_only=false) |
| Loads the fused point cloud from a file. More... | |
| void | clear () |
| Clears all the data. More... | |
Attributes | |
| std::vector< PointCloudChunk > | chunks |
| std::vector< float4 > | vertices |
| std::vector< float3 > | normals |
By default the fused point cloud is defined as a set of point cloud chunks, this way we update only the required data, avoiding a time consuming remapping process every time a small part of the fused point cloud is changed.
| typedef std::vector<size_t> chunkList |
| FusedPointCloud | ( | ) |
| ~FusedPointCloud | ( | ) |
| PointCloudChunk& operator[] | ( | int | index | ) |
| size_t getNumberOfPoints | ( | ) |
| bool save | ( | String | filename, |
| MESH_FILE_FORMAT | type = MESH_FILE_OBJ, |
| chunkList | IDs = chunkList(0) |
| filename | : the path and filename of the mesh. |
| type | : defines the file type (extension). default : MESH_FILE_OBJ. |
| IDs | : (by default empty) Specify a set of chunks to be saved, if none provided alls chunks are saved. default : (empty). |
| bool load | ( | String | filename, |
| bool | update_chunk_only = false |
| filename | : the path and filename of the fused point cloud (do not forget the extension). |
| update_chunk_only | : if set to false the fused point cloud data (vertices/normals) are updated otherwise only the chunk's data are updated. default : false. |
| void clear | ( | ) |
| std::vector<PointCloudChunk> chunks |
contains the list of chunks
| std::vector<float4> vertices |
Vertices are defined by colored 3D points {x, y, z, rgba}.
| std::vector<float3> normals |
Normals are defined by three components, {nx, ny, nz}. Normals are defined for each vertices.
