Represents a sub-mesh, it contains local vertices and triangles. More...
General Functions | |
| Chunk () | |
| Default constructor which creates an empty Chunk. More... | |
| ~Chunk () | |
| Chunk destructor. More... | |
| void | clear () |
| Clears all chunk data. More... | |
Attributes | |
| std::vector< float3 > | vertices |
| std::vector< uint3 > | triangles |
| std::vector< float3 > | normals |
| std::vector< float2 > | uv |
| unsigned long long | timestamp |
| float3 | barycenter |
| bool | has_been_updated |
Vertices and normals have the same size and are linked by id stored in triangles.
| void clear | ( | ) |
| std::vector<float3> vertices |
Vertices are defined by a 3D point {x,y,z}.
| std::vector<uint3> triangles |
Triangles (or faces) contains the index of its three vertices. It corresponds to the 3 vertices of the triangle {v1, v2, v3}.
| std::vector<float3> normals |
Normals are defined by three components, {nx, ny, nz}. Normals are defined for each vertices.
| std::vector<float2> uv |
UVs defines the 2D projection of each vertices onto the Texture.
Values are normalized [0;1], starting from the bottom left corner of the texture (as requested by opengl).
In order to display a textured mesh you need to bind the Texture and then draw each triangles by picking its uv values.
| unsigned long long timestamp |
Timestamp of the latest update.
| float3 barycenter |
3D centroid of the chunk.
| bool has_been_updated |
True if the chunk has been updated by an inner process.
