News
May 23, 2022.
Introducing Next-Generation Stereo Depth Sensing Technology
Revolutionary Neural Depth Mapping
Bringing ZED SDK to a new level
Enabling new applications
Optimized for NVIDIA Jetson AGX Orin
How to use the NEURAL depth mode
Download the ZED SDK 3.7
The NEURAL depth mode is available starting from the ZED SDK v3.7
Introducing Next-Generation Stereo Depth Sensing Technology | Stereolabs
