FusionConfiguration Class Reference
Useful struct to store the Fusion configuration, can be read from /write to a JSON file. More...
bool operator== (const FusionConfiguration &param1) const
bool operator!= (const FusionConfiguration &param1) const
Attributes
int serial_number
 The serial number of the used ZED camera. More...
CommunicationParameters communication_parameters
 The communication parameters to connect this camera to the Fusion. More...
Transform pose
 The WORLD Pose of the camera for Fusion in the unit and coordinate system defined by the user in the InitFusionParameters. More...
InputType input_type
 The input type for the current camera. More...
bool override_gravity = false
 Indicates the behavior of the fusion with respect to given calibration pose. If true : The calibration pose directly specifies the camera's absolute pose relative to a global reference frame. If false : The calibration pose (Pose_rel) is defined relative to the camera's IMU rotational pose. To determine the true absolute position, the Fusion process will compute Pose_abs = Pose_rel * Rot_IMU_camera. More...
◆ save()
bool save ( String  filename,
) const
Parameters
Returns
Warning
◆ load()
bool load ( String  filename,
Parameters
Returns
◆ encode()
) const
Parameters
Returns
◆ decode()
Parameters
Returns
◆ operator==()
bool operator== ( const FusionConfiguration &  param1) const
Parameters
FusionConfigurationto compare
Returns
◆ operator!=()
bool operator!= ( const FusionConfiguration &  param1) const
Parameters
Returns
Variables
◆ serial_number
int serial_number
◆ communication_parameters
◆ pose
Transform pose
◆ input_type
◆ override_gravity
