InitFusionParameters Class Reference
Holds the options used to initialize the Fusion object. More...
 InitFusionParameters (UNIT coordinate_units_=UNIT::MILLIMETER, COORDINATE_SYSTEM coordinate_system_=COORDINATE_SYSTEM::IMAGE, bool output_performance_metrics=true, int verbose_=0, unsigned timeout_period_number_=5, SynchronizationParameter synchronization_parameters_=SynchronizationParameter())
 Default constructor. More...
bool operator== (const InitFusionParameters &param1) const
bool operator!= (const InitFusionParameters &param1) const
Attributes
 This parameter allows you to select the unit to be used for all metric values of the SDK (depth, point cloud, tracking, mesh, and others). More...
 Positional tracking, point clouds and many other features require a given COORDINATE_SYSTEM to be used as reference. This parameter allows you to select the COORDINATE_SYSTEM used by the Camera to return its measures. More...
 It allows users to extract some stats of the Fusion API like drop frame of each camera, latency, etc... More...
int verbose
 Enable the verbosity mode of the SDK. More...
 If specified change the number of period necessary for a source to go in timeout without data. For example, if you set this to 5 then, if any source do not receive data during 5 period, these sources will go to timeout and will be ignored. More...
 Specifies the parameters used for data synchronization during fusion. More...
Constructor and Destructor
◆ InitFusionParameters()
InitFusionParameters ( UNIT  coordinate_units_ = UNIT::MILLIMETER,
COORDINATE_SYSTEM  coordinate_system_ = COORDINATE_SYSTEM::IMAGE,
bool  output_performance_metrics = true,
int  verbose_ = 0,
unsigned  timeout_period_number_ = 5,
SynchronizationParameter  synchronization_parameters_ = SynchronizationParameter()
◆ save()
bool save ( String  filename,
) const
Parameters
Returns
Warning
◆ load()
bool load ( String  filename,
Parameters
Returns
◆ encode()
) const
Parameters
Returns
◆ decode()
Parameters
Returns
◆ operator==()
bool operator== ( const InitFusionParameters &  param1) const
Parameters
InitFusionParametersto compare
Returns
◆ operator!=()
bool operator!= ( const InitFusionParameters &  param1) const
Parameters
Returns
Variables
◆ coordinate_units
Default : UNIT::MILLIMETER
◆ coordinate_system
Default : COORDINATE_SYSTEM::IMAGE
◆ output_performance_metrics
◆ verbose
int verbose
◆ timeout_period_number
Note
This parameter is deprecated. Use data_source_timeout present in synchronization_parameters instead.
◆ synchronization_parameters
The SynchronizationParameter struct encapsulates the synchronization parameters that control the data fusion process.
