SynchronizationParameter Struct Reference
Configuration parameters for data synchronization. More...
bool operator== (const SynchronizationParameter &param1) const
bool operator!= (const SynchronizationParameter &param1) const
Attributes
double windows_size = 0
 Size of synchronization windows in milliseconds. More...
double data_source_timeout = 1000
 Duration in milliseconds before considering a camera as inactive if no more data is present (for example camera disconnection). More...
bool keep_last_data = false
 Determines whether to include the last data returned by a source in the final synchronized data. More...
double maximum_lateness = 50
 Maximum duration in milliseconds allowed for data to be considered as the last data. More...
The SynchronizationParameter struct represents the configuration parameters used by the synchronizer. It allows customization of the synchronization process based on specific requirements.
◆ save()
bool save ( String  filename,
) const
Parameters
Returns
Warning
◆ load()
bool load ( String  filename,
Parameters
Returns
◆ encode()
) const
Parameters
Returns
◆ decode()
Parameters
Returns
◆ operator==()
bool operator== ( const SynchronizationParameter &  param1) const
Parameters
SynchronizationParameterto compare
Returns
◆ operator!=()
bool operator!= ( const SynchronizationParameter &  param1) const
Parameters
Returns
Variables
◆ windows_size
The synchronization window is used by the synchronizer to return all data present inside the current synchronization window. For efficient fusion, the synchronization window size is expected to be equal to the mean grab() duration of the camera at the lowest FPS. If not provided, the fusion SDK will compute it from the data's sources.
Default value: 0
◆ data_source_timeout
The data_source_timeout parameter specifies the duration to wait before considering a camera as inactive if no new data is received within the specified time frame.
Default value: 1000
◆ keep_last_data
If the keep_last_data parameter is set to true and no data is present in the current synchronization window, the last data returned by the source will be included in the final synchronized data. This ensures continuity even in the absence of fresh data.
Default value: false
◆ maximum_lateness
The maximum_lateness parameter sets the maximum duration within which data can be considered as the last available data. If the duration between the last received data and the current synchronization window exceeds this value, the data will not be included as the last data in the final synchronized output.
Default value: 50
