Pose Class Reference
Class containing positional tracking data giving the position and orientation of the camera in 3D space. More...
 Pose ()
 Default constructor. More...
 Pose (const Pose &pose)
 Copy constructor (deep copy). More...
 Pose (const Transform &pose_data, unsigned long long timestamp=0, int confidence=0)
 Constructor. More...
 ~Pose ()
 Default destructor. More...
Translation getTranslation () const
 Returns the sl::Translation corresponding to the current sl::Pose. More...
Orientation getOrientation () const
 Returns the sl::Orientation corresponding to the current sl::Pose. More...
Rotation getRotationMatrix () const
 Returns the sl::Rotation corresponding to the current sl::Pose. More...
float3 getRotationVector () const
 Returns the 3x1 rotation vector (obtained from 3x3 rotation matrix using Rodrigues formula) corresponding to the current sl::Pose. More...
float3 getEulerAngles (bool radian=true) const
 Converts the rotation component of the sl::Pose into Euler angles. More...
Attributes
Transform pose_data
 sl::Transform containing the rotation and translation data of the sl::Pose. More...
sl::Timestamp timestamp
 sl::Timestamp of the sl::Pose. More...
int pose_confidence
 Confidence/quality of the pose estimation for the target frame. More...
float pose_covariance [36]
 6x6 pose covariance matrix of translation (the first 3 values) and rotation in so3 (the last 3 values). More...
bool valid
 Whether the tracking is activated or not. More...
float twist [6]
 Twist of the camera available in reference camera. More...
float twist_covariance [36]
 Row-major representation of the 6x6 twist covariance matrix of the camera. More...
Different representations of position and orientation can be retrieved, along with timestamp and pose confidence.
Constructor and Destructor
◆ Pose() [1/3]
Pose ( )
Creates an empty sl::Pose (identity).
◆ Pose() [2/3]
Pose ( const Pose &  pose)
◆ Pose() [3/3]
Pose ( const Transform &  pose_data,
unsigned long long  timestamp = 0,
int  confidence = 0
Constructor.
Initializes the transform of the sl::Pose with a sl::Transform (deep copy).
◆ ~Pose()
~Pose ( )
Default destructor.
◆ getTranslation()
Translation getTranslation ( ) const
Returns
sl::Translation created from the sl::Pose values.
◆ getOrientation()
Orientation getOrientation ( ) const
Returns
sl::Orientation created from the sl::Pose values.
◆ getRotationMatrix()
Rotation getRotationMatrix ( ) const
Returns
sl::Rotation created from the sl::Pose values.
◆ getRotationVector()
float3 getRotationVector ( ) const
Returns
Rotation vector created from the sl::Pose values.
◆ getEulerAngles()
float3 getEulerAngles ( bool  radian = true) const
Parameters
radian: Whether the angle will be returned in radian or degree.
Returns
Euler angles created from the sl::Pose values as a sl::float3 representing the rotations around the X, Y and Z axes using YZX convention.
Variables
◆ pose_data
Transform pose_data
◆ timestamp
This timestamp should be compared with the camera timestamp for synchronization.
◆ pose_confidence
int pose_confidence
A confidence metric of the tracking [0-100] with:
  • 0: tracking is lost
  • 100: tracking can be fully trusted
◆ pose_covariance
float pose_covariance[36]
◆ valid
bool valid
Note
You should check that first if something is wrong.
◆ twist
float twist[6]
This expresses velocity in free space, broken into its linear and angular parts.
◆ twist_covariance
float twist_covariance[36]
This expresses the uncertainty of the twist.
