Translation Class Reference
Class representing a translation for the positional tracking module. More...
 Translation ()
 Default constructor. More...
 Translation (const Translation &translation)
 Copy constructor (deep copy). More...
 Translation (float t1, float t2, float t3)
 Constructor. More...
 Translation (float3 in)
 Constructor from an sl::float3. More...
Translation operator* (const Orientation &mat) const
 Multiplication operator by an Orientation. More...
void normalize ()
 Normalizes the current sl::Translation. More...
float & operator() (int x)
 Gets the value at specific position in the sl::Translation. More...
_FCT_CPU_GPU_ int size () const
 Return the size of the sl::Vector3. More...
_FCT_CPU_GPU_ const float * ptr () const
 Returns a pointer of the first component. More...
_FCT_CPU_GPU_ Vector3< float > & setValues (const float *b)
 Sets the components of the sl::Vector3 to the values of the argument. More...
_FCT_CPU_GPU_ float & operator[] (const unsigned int i)
 Returns the i-th component. More...
_FCT_CPU_GPU_ const float & operator[] (const unsigned int i) const
_FCT_CPU_GPU_ void operator[] (const unsigned int i) &&=delete
 Prevent operator from being called by temporaries (such as rvalue) More...
_FCT_CPU_GPU_ float norm ()
 Returns the norm of the sl::Vector3. More...
_FCT_CPU_GPU_ float square ()
 Returns the squared norm of the sl::Vector3. More...
_FCT_CPU_GPU_ float sum ()
 Returns the sum of the components of the sl::Vector3. More...
Static Functions
static Translation normalize (const Translation &tr)
 Gets the normalized sl::Translation of a given sl::Translation. More...
static _FCT_CPU_GPU_ float dot (const Vector3< float > &a, const Vector3< float > &b)
 Returns the dot product of two sl::Vector3. More...
static _FCT_CPU_GPU_ float distance (const Vector3< float > &a, const Vector3< float > &b)
 Returns the distance between two sl::Vector3. More...
static _FCT_CPU_GPU_ Vector3< float > cross (const Vector3< float > &a, const Vector3< float > &b)
 Returns the cross product between two sl::Vector3. More...
sl::Translation is a vector as [tx, ty, tz].
You can access the data with the 't' ptr or by element name as : tx, ty, tz <-> | 0 1 2 |
Constructor and Destructor
◆ Translation() [1/4]
Creates a null translation.
◆ Translation() [2/4]
Translation ( const Translation &  translation)
Parameters
translation: sl::Translation to copy.
◆ Translation() [3/4]
Translation ( float  t1,
float  t2,
float  t3
Constructor.
Parameters
t1: x component of the translation.
t2: y component of the translation.
t3: z component of the translation.
◆ Translation() [4/4]
Translation ( float3  in)
Parameters
in: sl::float3 to copy.
◆ operator*()
Translation operator* ( const Orientation &  mat) const
Parameters
mat: Orientation.
Returns
The current Translation after being multiplied by the orientation.
◆ normalize() [1/2]
void normalize ( )
◆ normalize() [2/2]
static Translation normalize ( const Translation &  tr)
static
Parameters
tr: sl::Translation to be get the normalized translation from.
Returns
Another sl::Translation object equal to tr.normalize().
◆ operator()()
float& operator() ( int  x)
Parameters
x: Position of the value.
Returns
Value at the x position.
◆ size()
_FCT_CPU_GPU_ int size ( ) const
inlineinherited
Returns
3
◆ ptr()
_FCT_CPU_GPU_ const float * ptr ( ) const
inlineinherited
◆ setValues()
_FCT_CPU_GPU_ Vector3<float >& setValues ( const float *  b)
inlineinherited
◆ operator[]() [1/3]
_FCT_CPU_GPU_ float & operator[] ( const unsigned int  i)
inlineinherited
◆ operator[]() [2/3]
_FCT_CPU_GPU_ const float & operator[] ( const unsigned int  i) const
inlineinherited
◆ operator[]() [3/3]
_FCT_CPU_GPU_ void operator[] ( const unsigned int  i) &&
deleteinherited
◆ norm()
_FCT_CPU_GPU_ float norm ( )
inlineinherited
◆ square()
_FCT_CPU_GPU_ float square ( )
inlineinherited
◆ sum()
_FCT_CPU_GPU_ float sum ( )
inlineinherited
◆ dot()
static _FCT_CPU_GPU_ float dot ( const Vector3< float > &  a,
const Vector3< float > &  b
inlinestaticinherited
◆ distance()
static _FCT_CPU_GPU_ float distance ( const Vector3< float > &  a,
◆ cross()
static _FCT_CPU_GPU_ Vector3<float > cross ( const Vector3< float > &  a,
