Orientation Class Reference
Class representing an orientation/quaternion for the positional tracking module. More...
 Orientation ()
 Default constructor. More...
 Orientation (const Orientation &orientation)
 Copy constructor (deep copy). More...
 Orientation (const float4 &in)
 Orientation (const Rotation &rotation)
 Constructor from an sl::Rotation. More...
 Orientation (const Translation &tr1, const Translation &tr2)
 Constructor from a vector represented by two sl::Translation. More...
float operator() (int x)
 Gets the value at specific position in the sl::Orientation. More...
Orientation operator* (const Orientation &orientation) const
 Multiplication operator by an sl::Orientation. More...
void setRotationMatrix (const Rotation &rotation)
 Sets the sl::Orientation from an sl::Rotation. More...
Rotation getRotationMatrix () const
 Returns the current sl::Orientation as an sl::Rotation. More...
void setIdentity ()
 Sets the current sl::Orientation to identity. More...
void setZeros ()
 Fills the current sl::Orientation with zeros. More...
void normalise ()
 Normalizes the current sl::Orientation. More...
_FCT_CPU_GPU_ int size () const
 Return the size of the sl::Vector4. More...
_FCT_CPU_GPU_ const float * ptr () const
 Returns a pointer of the first component. More...
_FCT_CPU_GPU_ Vector4< float > & setValues (const float *b)
 Sets the components of the sl::Vector1 to the values of the argument. More...
_FCT_CPU_GPU_ float & operator[] (const unsigned int i)
 Returns the i-th component. More...
_FCT_CPU_GPU_ const float & operator[] (const unsigned int i) const
_FCT_CPU_GPU_ void operator[] (const unsigned int i) &&=delete
 Prevent operator from being called by temporaries (such as rvalue) More...
_FCT_CPU_GPU_ float norm ()
 Returns the norm of the sl::Vector4. More...
_FCT_CPU_GPU_ float square ()
 Returns the squared norm of the sl::Vector4. More...
_FCT_CPU_GPU_ float sum ()
 Returns the sum of the components of the sl::Vector4. More...
Static Functions
static Orientation identity ()
 Creates an sl::Orientation initialized to identity. More...
static Orientation zeros ()
 Creates an sl::Orientation filled with zeros. More...
static Orientation normalise (const Orientation &orient)
 Gets the normalized sl::Orientation of a given sl::Orientation. More...
static _FCT_CPU_GPU_ float dot (const Vector4< float > &a, const Vector4< float > &b)
 Returns the dot product of two sl::Vector4. More...
static _FCT_CPU_GPU_ float distance (const Vector4< float > &a, const Vector4< float > &b)
 Returns the distance between two sl::Vector4. More...
sl::Orientation is a vector defined as [ox, oy, oz, ow].
Constructor and Destructor
◆ Orientation() [1/5]
Creates an identity orientation.
◆ Orientation() [2/5]
Orientation ( const Orientation &  orientation)
Parameters
orientation: sl::Orientation to copy.
◆ Orientation() [3/5]
Orientation ( const float4 &  in)
Parameters
in: sl::float4 to copy.
◆ Orientation() [4/5]
Orientation ( const Rotation &  rotation)
It converts the sl::Rotation representation to the sl::Orientation one.
Parameters
rotation: sl::Rotation to be used.
◆ Orientation() [5/5]
Orientation ( const Translation &  tr1,
const Translation &  tr2
Parameters
tr1: First point of the vector.
tr2: Second point of the vector.
◆ operator()()
float operator() ( int  x)
Parameters
x: Position of the value.
Returns
Value at the x position.
◆ operator*()
Orientation operator* ( const Orientation &  orientation) const
Parameters
orientation: sl.Orientation to multiply the current one with.
Returns
The result of the multiplication between current sl.Orientation and the one given as input.
◆ setRotationMatrix()
void setRotationMatrix ( const Rotation &  rotation)
Parameters
◆ getRotationMatrix()
Rotation getRotationMatrix ( ) const
Returns
The rotation computed from the orientation data.
◆ setIdentity()
void setIdentity ( )
◆ identity()
static Orientation identity ( )
static
Returns
Identity sl::Orientation.
◆ setZeros()
void setZeros ( )
◆ zeros()
static Orientation zeros ( )
static
Returns
◆ normalise() [1/2]
void normalise ( )
◆ normalise() [2/2]
static Orientation normalise ( const Orientation &  orient)
static
Parameters
orient: sl::Orientation to be get the normalized orientation from.
Returns
Another sl::Orientation object equal to orient.normalize().
◆ size()
_FCT_CPU_GPU_ int size ( ) const
inlineinherited
Returns
4
◆ ptr()
_FCT_CPU_GPU_ const float * ptr ( ) const
inlineinherited
◆ setValues()
_FCT_CPU_GPU_ Vector4<float >& setValues ( const float *  b)
inlineinherited
◆ operator[]() [1/3]
_FCT_CPU_GPU_ float & operator[] ( const unsigned int  i)
inlineinherited
◆ operator[]() [2/3]
_FCT_CPU_GPU_ const float & operator[] ( const unsigned int  i) const
inlineinherited
◆ operator[]() [3/3]
_FCT_CPU_GPU_ void operator[] ( const unsigned int  i) &&
deleteinherited
◆ norm()
_FCT_CPU_GPU_ float norm ( )
inlineinherited
◆ square()
_FCT_CPU_GPU_ float square ( )
inlineinherited
◆ sum()
_FCT_CPU_GPU_ float sum ( )
inlineinherited
◆ dot()
static _FCT_CPU_GPU_ float dot ( const Vector4< float > &  a,
const Vector4< float > &  b
inlinestaticinherited
◆ distance()
static _FCT_CPU_GPU_ float distance ( const Vector4< float > &  a,
