Rotation Class Reference
Class representing a rotation for the positional tracking module. More...
 Rotation ()
 Default constructor. More...
 Rotation (const Rotation &rotation)
 Copy constructor (deep copy). More...
 Rotation (const Matrix3f &mat)
 sl::Rotation constructor from an sl::Matrix3f. More...
 Rotation (const Orientation &orientation)
 sl::Rotation constructor from an sl::Orientation. More...
 Rotation (const float angle, const Translation &axis)
 sl::Rotation constructor from an angle and an axis. More...
void setOrientation (const Orientation &orientation)
 Sets the sl::Rotation from an sl::Orientation. More...
Orientation getOrientation () const
 Returns the sl::Orientation corresponding to the current sl::Rotation. More...
float3 getRotationVector ()
 Returns the 3x1 rotation vector obtained from 3x3 rotation matrix using Rodrigues formula. More...
void setRotationVector (const float3 &vec_rot)
 Sets the sl::Rotation from a rotation vector (using Rodrigues' transformation). More...
float3 getEulerAngles (bool radian=true) const
 Converts the sl::Rotation into Euler angles. More...
void setEulerAngles (const float3 &euler_angles, bool radian=true)
 Sets the sl::Rotation from Euler angles. More...
Matrix3f operator* (const Matrix3f &mat) const
 Gives the result of the multiplication between two sl::Matrix3f. More...
Matrix3f operator* (const float &scalar) const
 Gives the result of the multiplication between a sl::Matrix3f and a scalar. More...
Matrix3f operator+ (const Matrix3f &mat) const
 Gives the result of the addition between two sl::Matrix3f. More...
Matrix3f operator+ (const float &scalar) const
 Gives the result of the addition between a sl::Matrix3f and a scalar. More...
Matrix3f operator- (const Matrix3f &mat) const
 Gives the result of the subtraction between two sl::Matrix3f. More...
Matrix3f operator- (const float &scalar) const
 Gives the result of the subtraction between a sl::Matrix3f and a scalar. More...
bool operator== (const Matrix3f &mat) const
 Test two sl::Matrix3f equality. More...
bool operator!= (const Matrix3f &mat) const
 Test two sl::Matrix3f inequality. More...
float & operator() (int u, int v)
 Gets access to a specific point in the sl::Matrix3f (read/write). More...
void inverse ()
 Sets the sl::Matrix3f to its inverse. More...
void transpose ()
 Sets the sl::Matrix3f to its transpose. More...
void setIdentity ()
 Sets the sl::Matrix3f to identity. More...
void setZeros ()
 Sets the sl::Matrix3f to zero. More...
String getInfos ()
 Returns the components of the sl::Matrix3f in a sl::String. More...
Static Functions
static Matrix3f inverse (const Matrix3f &rotation)
 Returns the inverse of a sl::Matrix3f. More...
static Matrix3f transpose (const Matrix3f &rotation)
 Returns the transpose of a sl::Matrix3f. More...
static Matrix3f identity ()
 Creates an identity sl::Matrix3f. More...
static Matrix3f zeros ()
 Creates a sl::Matrix3f filled with zeros. More...
Attributes
String matrix_name
 Name of the matrix (optional). More...
It inherits from the generic sl::Matrix3f class.
Constructor and Destructor
◆ Rotation() [1/5]
Rotation ( )
Creates a null rotation.
◆ Rotation() [2/5]
Rotation ( const Rotation &  rotation)
Parameters
rotation: sl::Rotation to copy.
◆ Rotation() [3/5]
Rotation ( const Matrix3f &  mat)
Copies the sl::Matrix3f (deep copy).
Parameters
mat: sl::Matrix3f to copy.
◆ Rotation() [4/5]
Rotation ( const Orientation &  orientation)
It converts the Orientation representation to the Rotation one.
Parameters
orientation: the Orientation to be used.
◆ Rotation() [5/5]
Rotation ( const float  angle,
const Translation &  axis
Parameters
angle: Rotation angle in radian.
axis: 3D axis to rotate around.
◆ setOrientation()
void setOrientation ( const Orientation &  orientation)
Parameters
orientation: sl::Orientation containing the rotation to set.
◆ getOrientation()
Orientation getOrientation ( ) const
Returns
Rotation of the current orientation.
◆ getRotationVector()
float3 getRotationVector ( )
Returns
Rotation vector created from the sl::Orientation values.
◆ setRotationVector()
void setRotationVector ( const float3 &  vec_rot)
Parameters
vec_rot: Vector containing the rotation value for each axis (rx, ry, rz).
◆ getEulerAngles()
float3 getEulerAngles ( bool  radian = true) const
Parameters
radian: Whether the angle will be returned in radian or degree.
Returns
Euler angles created from the sl::Rotation values representing the rotations around the X, Y and Z axes using YZX convention.
◆ setEulerAngles()
void setEulerAngles ( const float3 &  euler_angles,
bool  radian = true
Parameters
euler_angles: Euler angles (as a sl::float3) to update the sl::Rotation.
radian: Whether the angle is in radian or degree.
◆ operator*() [1/2]
Matrix3f operator* ( const Matrix3f &  mat) const
inherited
◆ operator*() [2/2]
Matrix3f operator* ( const float &  scalar) const
inherited
◆ operator+() [1/2]
Matrix3f operator+ ( const Matrix3f &  mat) const
inherited
◆ operator+() [2/2]
Matrix3f operator+ ( const float &  scalar) const
inherited
◆ operator-() [1/2]
Matrix3f operator- ( const Matrix3f &  mat) const
inherited
◆ operator-() [2/2]
Matrix3f operator- ( const float &  scalar) const
inherited
◆ operator==()
bool operator== ( const Matrix3f &  mat) const
inherited
◆ operator!=()
bool operator!= ( const Matrix3f &  mat) const
inherited
◆ operator()()
float& operator() ( int  u,
int  v
inherited
Parameters
u: Row to get the value from.
v: Column to get the value from.
Returns
The value at the u, v coordinates.
◆ inverse() [1/2]
void inverse ( )
inherited
◆ inverse() [2/2]
static Matrix3f inverse ( const Matrix3f &  rotation)
staticinherited
Parameters
rotation: sl::Matrix3f to compute the inverse from.
Returns
The inverse of the sl::Matrix3f given as input.
◆ transpose() [1/2]
void transpose ( )
inherited
◆ transpose() [2/2]
static Matrix3f transpose ( const Matrix3f &  rotation)
staticinherited
Parameters
rotation: sl::Matrix3f to compute the transpose from.
Returns
The transpose of the sl::Matrix3f given as input.
◆ setIdentity()
void setIdentity ( )
inherited
◆ identity()
static Matrix3f identity ( )
staticinherited
Returns
A sl::Matrix3f set to identity.
◆ setZeros()
void setZeros ( )
inherited
◆ zeros()
static Matrix3f zeros ( )
staticinherited
Returns
A sl::Matrix3f filled with zeros.
◆ getInfos()
String getInfos ( )
inherited
Returns
A sl::String containing the components of the current sl::Matrix3f.
Variables
◆ matrix_name
String matrix_name
inherited
