CommunicationParameters Class Reference
Holds the communication parameter to configure the connection between senders and receiver. More...
Types
enum class  COMM_TYPE
 Lists the different types of communications available for Fusion module. More...
 CommunicationParameters ()
 Default constructor. All the parameters are set to their default and optimized values. More...
void setForSharedMemory ()
 Setup the communication to used shared memory for intra process workflow, senders and receiver in different threads. More...
void setForLocalNetwork (int port)
 Setup local Network connection information, sender side, only the port is required. More...
void setForLocalNetwork (std::string ip_address, int port)
 Setup local Network connection information, receiver side, need the edge device IP and the port. More...
int getPort () const
 This function returns the comm port used for streaming the data. More...
std::string getIpAddress () const
 This function returns the IP address of the sender. More...
COMM_TYPE getType () const
 This function returns the type of the used communication. More...
bool operator== (const CommunicationParameters &param1) const
bool operator!= (const CommunicationParameters &param1) const
Enumeration
◆ COMM_TYPE
enum COMM_TYPE
strong
Enumerator
LOCAL_NETWORK
The sender and receiver are on the same local network and communicate by RTP.
The communication can be affected by the local network load.
INTRA_PROCESS
Both sender and receiver are declared by the same process and can be in different threads.
This type of communication is optimized.
Constructor and Destructor
◆ CommunicationParameters()
◆ setForSharedMemory()
void setForSharedMemory ( )
◆ setForLocalNetwork() [1/2]
void setForLocalNetwork ( int  port)
◆ setForLocalNetwork() [2/2]
void setForLocalNetwork ( std::string  ip_address,
int  port
◆ getPort()
int getPort ( ) const
inline
Returns
the port
◆ getIpAddress()
std::string getIpAddress ( ) const
inline
Returns
the IP address
◆ getType()
COMM_TYPE getType ( ) const
inline
Returns
the COMM_TYPE of the communication used
◆ save()
bool save ( String  filename,
) const
Parameters
Returns
Warning
◆ load()
bool load ( String  filename,
Parameters
Returns
◆ encode()
) const
Parameters
Returns
◆ decode()
Parameters
Returns
◆ operator==()
bool operator== ( const CommunicationParameters &  param1) const
Parameters
CommunicationParametersto compare
Returns
◆ operator!=()
bool operator!= ( const CommunicationParameters &  param1) const
Parameters
Returns
