Class containing data of a detected body/person such as its bounding_box, id and its 3D position. More...
Functions | |
| BodyData () | |
| Default constructor. More... | |
| ~BodyData () | |
| Default destructor. More... | |
Attributes | |
| int | id |
| Body/person identification number. More... | |
| String | unique_object_id |
| Unique id to help identify and track AI detections. More... | |
| OBJECT_TRACKING_STATE | tracking_state |
| Body/person tracking state. More... | |
| OBJECT_ACTION_STATE | action_state |
| Body/person action state. More... | |
| sl::float3 | position |
| Body/person 3D centroid. More... | |
| sl::float3 | velocity |
| Body/person 3D velocity. More... | |
| float | position_covariance [6] |
| Covariance matrix of the 3D position. More... | |
| std::vector< sl::uint2 > | bounding_box_2d |
| 2D bounding box of the body/person represented as four 2D points starting at the top left corner and rotation clockwise. More... | |
| sl::Mat | mask |
| Mask defining which pixels which belong to the body/person (in bounding_box_2d and set to 255) and those of the background (set to 0). More... | |
| float | confidence |
| Detection confidence value of the body/person. More... | |
| std::vector< sl::float3 > | bounding_box |
| 3D bounding box of the body/person represented as eight 3D points. More... | |
| sl::float3 | dimensions |
| 3D body/person dimensions: width, height, length. More... | |
| std::vector< sl::float2 > | keypoint_2d |
| Set of useful points representing the human body in 2D. More... | |
| std::vector< sl::float3 > | keypoint |
| Set of useful points representing the human body in 3D. More... | |
| std::vector< sl::uint2 > | head_bounding_box_2d |
| 2D bounding box of the head of the body/person represented as four 2D points starting at the top left corner and rotation clockwise. More... | |
| std::vector< sl::float3 > | head_bounding_box |
| 3D bounding box of the head of the body/person represented as eight 3D points. More... | |
| sl::float3 | head_position |
| 3D centroid of the head of the body/person. More... | |
| std::vector< float > | keypoint_confidence |
| Vector of detection confidences for each keypoint. More... | |
| std::vector< std::array< float, 6 > > | keypoint_covariances |
| Vector of detection covariance for each keypoint. More... | |
| std::vector< sl::float3 > | local_position_per_joint |
| Vector of local position (position of the child keypoint with respect to its parent expressed in its parent coordinate frame) for each keypoint. More... | |
| std::vector< sl::float4 > | local_orientation_per_joint |
| Vector of local orientation for each keypoint. More... | |
| sl::float4 | global_root_orientation |
| Global root orientation of the skeleton. More... | |
| BodyData | ( | ) |
| ~BodyData | ( | ) |
Default destructor.
| int id |
It is used as a reference when tracking the body through the frames.
| String unique_object_id |
It can be either generated externally, or by using generate_unique_id() or left empty.
| OBJECT_TRACKING_STATE tracking_state |
| OBJECT_ACTION_STATE action_state |
| sl::float3 position |
| sl::float3 velocity |
sl::InitParameters.coordinate_units / s and expressed in sl::RuntimeParameters.measure3D_reference_frame. | float position_covariance[6] |
position_covariance[i] | std::vector<sl::uint2> bounding_box_2d |
[0, 0] is the top left corner. | sl::Mat mask |
mask.isInit() == false). | float confidence |
From 0 to 100, a low value means the body might not be localized perfectly.
| std::vector<sl::float3> bounding_box |
| sl::float3 dimensions |
| std::vector<sl::float2> keypoint_2d |
[0, 0] is the top left corner. | std::vector<sl::float3> keypoint |
| std::vector<sl::uint2> head_bounding_box_2d |
[0, 0] is the top left corner. | std::vector<sl::float3> head_bounding_box |
| sl::float3 head_position |
| std::vector<float> keypoint_confidence |
| std::vector<std::array<float, 6 > > keypoint_covariances |
| std::vector<sl::float3> local_position_per_joint |
| std::vector<sl::float4> local_orientation_per_joint |
sl::float4 q = sl::float4(qx, qy, qz, qw);) | sl::float4 global_root_orientation |
The orientation is also represented by a quaternion with the same format as local_orientation_per_joint.
