BodyTrackingParameters Struct Reference
Structure containing a set of parameters for the body tracking module. More...
 BodyTrackingParameters (bool enable_tracking_=true, bool enable_segmentation_=false, BODY_TRACKING_MODEL detection_model=BODY_TRACKING_MODEL::HUMAN_BODY_ACCURATE, bool enable_body_fitting_=false, float max_range_=-1.f, BODY_FORMAT body_format_=BODY_FORMAT::BODY_18, BODY_KEYPOINTS_SELECTION body_selection=BODY_KEYPOINTS_SELECTION::FULL, float prediction_timeout_s=0.2f, bool allow_reduced_precision_inference=false, unsigned int instance_id=0)
 Default constructor. More...
bool operator== (const BodyTrackingParameters &param1) const
bool operator!= (const BodyTrackingParameters &param1) const
Attributes
unsigned int instance_module_id = 0
 Id of the module instance. More...
bool enable_tracking = true
 Whether the body tracking system includes body/person tracking capabilities across a sequence of images. More...
bool enable_segmentation = false
 Whether the body/person masks will be computed. More...
BODY_TRACKING_MODEL detection_model = BODY_TRACKING_MODEL::HUMAN_BODY_ACCURATE
 sl::BODY_TRACKING_MODEL to use. More...
bool enable_body_fitting = false
 Whether to apply the body fitting. More...
BODY_FORMAT body_format = BODY_FORMAT::BODY_18
 Body format to be outputted by the ZED SDK with sl::Camera.retrieveBodies(). More...
BODY_KEYPOINTS_SELECTION body_selection = BODY_KEYPOINTS_SELECTION::FULL
 Selection of keypoints to outputted by the ZED SDK with sl::Camera.retrieveBodies(). More...
float max_range = -1.f
 Upper depth range for detections. More...
 Prediction duration of the ZED SDK when an object is not detected anymore before switching its state to sl::OBJECT_TRACKING_STATE::SEARCHING. More...
 Whether to allow inference to run at a lower precision to improve runtime and memory usage. More...
Note
Constructor and Destructor
◆ BodyTrackingParameters()
BodyTrackingParameters ( bool  enable_tracking_ = true,
bool  enable_segmentation_ = false,
BODY_TRACKING_MODEL  detection_model = BODY_TRACKING_MODEL::HUMAN_BODY_ACCURATE,
bool  enable_body_fitting_ = false,
float  max_range_ = -1.f,
BODY_FORMAT  body_format_ = BODY_FORMAT::BODY_18,
BODY_KEYPOINTS_SELECTION  body_selection = BODY_KEYPOINTS_SELECTION::FULL,
float  prediction_timeout_s = 0.2f,
bool  allow_reduced_precision_inference = false,
unsigned int  instance_id = 0
All the parameters are set to their default values.
◆ save()
bool save ( String  filename,
) const
Parameters
Returns
Warning
◆ load()
bool load ( String  filename,
Parameters
Returns
◆ encode()
) const
Parameters
Returns
◆ decode()
Parameters
Returns
◆ operator==()
bool operator== ( const BodyTrackingParameters &  param1) const
Comparison operator ==
Parameters
BodyTrackingParametersto compare
Returns
◆ operator!=()
bool operator!= ( const BodyTrackingParameters &  param1) const
Comparison operator !=
Parameters
Returns
Variables
◆ instance_module_id
This is used to identify which body tracking module instance is used.
◆ enable_tracking
◆ enable_segmentation
◆ detection_model
◆ enable_body_fitting
◆ body_format
◆ body_selection
◆ max_range
Default: -1.f (value set in sl::InitParameters.depth_maximum_distance)
Note
The value cannot be greater than sl::InitParameters.depth_maximum_distance and its unit is defined in sl::InitParameters.coordinate_units.
◆ prediction_timeout_s
It prevents the jittering of the object state when there is a short misdetection.
The user can define their own prediction time duration.
Note
During this time, the object will have sl::OBJECT_TRACKING_STATE::OK state even if it is not detected.
The duration is expressed in seconds.
Warning
prediction_timeout_s will be clamped to 1 second as the prediction is getting worse with time.
Setting this parameter to 0 disables the ZED SDK predictions.
◆ allow_reduced_precision_inference
It might increase the initial optimization time and could include downloading calibration data or calibration cache and slightly reduce the accuracy.
Note
The fp16 is automatically enabled if the GPU is compatible and provides a speed up of almost x2 and reduce memory usage by almost half, no precision loss.
This setting allow int8 precision which can speed up by another x2 factor (compared to fp16, or x4 compared to fp32) and half the fp16 memory usage, however some accuracy could be lost.
The accuracy loss should not exceed 1-2% on the compatible models.
The current compatible models are all sl::AI_MODELS::HUMAN_BODY_XXXX.
