RuntimeParameters Struct Reference
Structure containing parameters that defines the behavior of sl::Camera::grab(). More...
 RuntimeParameters (bool enable_depth_=true, bool enable_fill_mode_=false, int confidence_threshold_=95, int texture_confidence_threshold_=100, REFERENCE_FRAME measure3D_reference_frame_=REFERENCE_FRAME::CAMERA, bool remove_saturated_areas_=true)
 Default constructor. More...
bool save (String filename, SERIALIZATION_FORMAT format=SERIALIZATION_FORMAT::LEGACY) const
bool load (String filename, SERIALIZATION_FORMAT format=SERIALIZATION_FORMAT::AUTO)
bool operator== (const RuntimeParameters &param1) const
bool operator!= (const RuntimeParameters &param1) const
Attributes
 Reference frame in which to provides the 3D measures (point cloud, normals, etc.). More...
bool enable_depth
 Defines if the depth map should be computed. More...
bool enable_fill_mode = false
 Defines if the depth map should be completed or not. More...
int confidence_threshold = 95
 Threshold to reject depth values based on their confidence. More...
int texture_confidence_threshold = 100
 Threshold to reject depth values based on their texture confidence. More...
bool remove_saturated_areas = true
 Defines if the saturated area (luminance>=255) must be removed from depth map estimation. More...
Note
Constructor and Destructor
◆ RuntimeParameters()
RuntimeParameters ( bool  enable_depth_ = true,
bool  enable_fill_mode_ = false,
int  confidence_threshold_ = 95,
int  texture_confidence_threshold_ = 100,
REFERENCE_FRAME  measure3D_reference_frame_ = REFERENCE_FRAME::CAMERA,
bool  remove_saturated_areas_ = true
All the parameters are set to their default values.
◆ save()
bool save ( String  filename,
SERIALIZATION_FORMAT  format = SERIALIZATION_FORMAT::LEGACY
) const
Parameters
Returns
Warning
◆ load()
bool load ( String  filename,
SERIALIZATION_FORMAT  format = SERIALIZATION_FORMAT::AUTO
Parameters
Returns
◆ encode()
) const
Parameters
Returns
◆ decode()
Parameters
Returns
◆ operator==()
bool operator== ( const RuntimeParameters &  param1) const
Comparison operator ==
Parameters
RuntimeParametersto compare
Returns
◆ operator!=()
bool operator!= ( const RuntimeParameters &  param1) const
Comparison operator !=
Parameters
Returns
Variables
◆ measure3D_reference_frame
Default: sl::REFERENCE_FRAME::CAMERA
◆ enable_depth
bool enable_depth
Default: true
Note
If set to false, only the images are available.
◆ enable_fill_mode
Default: false
Note
It is similar to the removed sl::SENSING_MODE::FILL.
Warning
Enabling this will override the confidence values confidence_threshold and texture_confidence_threshold as well as remove_saturated_areas.
◆ confidence_threshold
Each depth pixel has a corresponding confidence (sl::MEASURE::CONFIDENCE) in the range [1, 100].
Decreasing this value will remove depth data from both objects edges and low textured areas, to keep only confident depth estimation data.
Default: 95
Note
Pixels with a value close to 100 are not to be trusted. Accurate depth pixels tends to be closer to lower values.
It can be seen as a probability of error, scaled to 100.
◆ texture_confidence_threshold
The texture confidence range is [1, 100].
Decreasing this value will remove depth data from image areas which are uniform.
Default: 100 (no depth pixel will be rejected)
Note
◆ remove_saturated_areas
Default: true
Note
It is recommended to keep this parameter at true because saturated area can create false detection.
