BodyTrackingRuntimeParameters Struct Reference
Structure containing a set of runtime parameters for the body tracking module. More...
 BodyTrackingRuntimeParameters (float detection_confidence_threshold=20.f, int minimum_keypoints_threshold=0, float skeleton_smoothing=0.f)
 Default constructor. More...
bool operator== (const BodyTrackingRuntimeParameters &param1) const
bool operator!= (const BodyTrackingRuntimeParameters &param1) const
Attributes
 Confidence threshold. More...
 Minimum threshold for the keypoints. More...
float skeleton_smoothing = 0.f
 Control of the smoothing of the fitted fused skeleton. More...
Note
Constructor and Destructor
◆ BodyTrackingRuntimeParameters()
BodyTrackingRuntimeParameters ( float  detection_confidence_threshold = 20.f,
int  minimum_keypoints_threshold = 0,
All the parameters are set to their default values.
◆ save()
bool save ( String  filename,
) const
Parameters
Returns
Warning
◆ load()
bool load ( String  filename,
Parameters
Returns
◆ encode()
) const
Parameters
Returns
◆ decode()
Parameters
Returns
◆ operator==()
bool operator== ( const BodyTrackingRuntimeParameters &  param1) const
Comparison operator ==
Parameters
BodyTrackingRuntimeParametersto compare
Returns
◆ operator!=()
bool operator!= ( const BodyTrackingRuntimeParameters &  param1) const
Comparison operator !=
Parameters
Returns
Variables
◆ detection_confidence_threshold
From 1 to 100, with 1 meaning a low threshold, more uncertain objects and 99 very few but very precise objects.
Default: 20.f
Note
If the scene contains a lot of objects, increasing the confidence can slightly speed up the process, since every object instance is tracked.
◆ minimum_keypoints_threshold
The ZED SDK will only output the keypoints of the skeletons with threshold greater than this value.
Default: 0
Note
It is useful, for example, to remove unstable fitting results when a skeleton is partially occluded.
◆ skeleton_smoothing
It is ranged from 0 (low smoothing) and 1 (high smoothing).
