  • NewsTutorials
    Nov 17, 2015.
    Stereo Video Passthrough for Oculus Rift
    Note: This is for ZED SDK 1.0 only. Please see the latest SDK guides and documentation here.
    • Oculus Rift DK2
    • Windows 7 64 bits or later
    • ZED SDK and its dependencies (CUDA, OpenCV 3.1)
    • Oculus SDK 1.3.0 or later
    • GLEW
    • SDL
    Overview
    Code
    Don’t forget to:
    • Set the CMake variable OCULUS_PATH with the path of your SDK (eg: “C:\ovr_sdk_win_0.8.0.0\OculusSDK”)
    • Set the CMake variable SDL_PATH with the path of the SDL2 library (eg: “C:\SDL2-2.0.3”)
    • Copy SDL2 and GLEW dll to the folder where the executable of the project has been generated.
    Explanation
    #include <iostream>
    #include <Windows.h>
    #include <GL/glew.h>
    #include <stddef.h>
    #include <SDL.h>
    #include <SDL_syswm.h>
    #include <OVR.h>
    #include <OVR_CAPI.h>
    #include <OVR_CAPI_GL.h>
    #include <zed/Camera.hpp>
    #include "Shader.hpp"
    #define MAX_FPS 75
    GLchar* OVR_ZED_VS =
    	"#version 330 core
    	uniform float hit;
    	out vec2 b_coordTexture;
    	void main()
    		b_coordTexture = in_texCoord;
    GLchar* OVR_ZED_FS =
    	"#version 330 core
    	in vec2 b_coordTexture;
    	out vec4 out_color;
    	void main()
    1. Initialize SDL2, Oculus and OpenGL
    // Initialize SDL2 context
    SDL_Init(SDL_INIT_VIDEO);
    // Initialize Oculus context
    if (OVR_FAILURE(result))
    	SDL_Quit();
    	return -1;
    ovrSession hmd;
    ovrGraphicsLuid luid;
    	ovr_Shutdown();
    	SDL_Quit();
    	return -1;
    int winWidth = 1280;
    int winHeight = 720;
    // Create SDL2 Window
    // Create OpenGL context
    // Initialize GLEW
    glewInit();
    SDL_GL_SetSwapInterval(0);
    2. Initialize the ZED camera
    // Initialize the ZED Camera
    sl::zed::Camera* zed = 0;
    	ovr_Destroy(hmd);
    	ovr_Shutdown();
    	SDL_DestroyWindow(window);
    	SDL_Quit();
    	delete zed;
    	return -1;
    GLuint zedTextureID_L, zedTextureID_R;
    // Generate OpenGL texture for left images of the ZED camera
    glGenTextures(1, &zedTextureID_L);
    glBindTexture(GL_TEXTURE_2D, zedTextureID_L);
    glTexImage2D(GL_TEXTURE_2D, 0, GL_RGBA, zedWidth, zedHeight, 0, GL_BGRA, GL_UNSIGNED_BYTE, NULL);
    glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MAG_FILTER, GL_LINEAR);
    glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MIN_FILTER, GL_NEAREST);
    glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_S, GL_REPEAT);
    glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_T, GL_REPEAT);
    // Generate OpenGL texture for right images of the ZED camera
    glGenTextures(1, &zedTextureID_R);
    glBindTexture(GL_TEXTURE_2D, zedTextureID_R);
    3. Create an Oculus swap texture set and frame buffer
    ovrSizei bufferSize;
    else
    	ovr_Destroy(hmd);
    	ovr_Shutdown();
    	SDL_Quit();
    	delete zed;
    	return -1;
    GLuint fboID;
    glGenFramebuffers(1, &fboID);
    GLuint depthBuffID;
    4. Create a mirror frame buffer for SDL2 window
    if (!OVR_SUCCESS(result))
    GLuint mirrorFBOID;
    glBindFramebuffer(GL_READ_FRAMEBUFFER, 0);
    5. Configure the variables used by the Oculus compositor
    ovrLayerEyeFov ld;
    ld.Header.Flags = ovrLayerFlag_TextureOriginAtBottomLeft | ovrLayerFlag_HeadLocked;   // Because OpenGL | Disable head tracking
    	// Set the field of view
    	// Set the pose matrix
    viewScaleDesc.HmdToEyeViewOffset[1] = viewOffset[1];
    6. Initialize the shader and its variables
    6.1. Create the shader
    // Create and compile the shader's sources
    Shader shader(OVR_ZED_VS, OVR_ZED_FS);
    6.2. Convert ZED frames to Oculus frames
    // Compute the ZED image field of view with the ZED parameters
    float zedFovH = atanf(zed->getImageSize().width / (zed->getParameters()->LeftCam.fx * 2.f)) * 2.f;
    // Compute the Oculus' field of view with its parameters
    float ovrFovH = (atanf(hmdDesc.DefaultEyeFov[0].LeftTan) + atanf(hmdDesc.DefaultEyeFov[0].RightTan));
    // Compute the useful part of the ZED image
    unsigned int usefulWidth = zed->getImageSize().width * ovrFovH / zedFovH;
    // Compute the size of the final image displayed in the headset with the ZED image's aspect-ratio kept
    unsigned int widthFinal = bufferSize.w / 2; unsigned int heightFinal = zed->getImageSize().height * widthFinal / usefulWidth;
    // Convert this size to OpenGL viewport's frame's coordinates
    float heightGL = (heightFinal) / (float)(bufferSize.h);
    float widthGL = ((zed->getImageSize().width * (heightFinal / (float)zed->getImageSize().height)) / (float)widthFinal);
    GLuint rectVBO[3];
    glGenBuffers(1, &rectVBO[0]);
    glGenBuffers(1, &rectVBO[1]);
    glGenBuffers(1, &rectVBO[2]);
    7. Create the render loop
    // Initialize hit value
    float hit = 0.02f;
    // Initialize a boolean that will be used to stop the application’s loop and another one to pause/unpause rendering
    bool end = false;
    bool refresh = true;
    // SDL variable that will be used to store input events
    SDL_Event events;
    // Initialize time variables. They will be used to limit the number of frames rendered per second.
    int time1 = 0, timePerFrame = 0;
    int frameRate = (int)(1000 / MAX_FPS);
    // Enable the shader
    glUseProgram(shader.getProgramId());
    // Bind the Vertex Buffer Objects of the rectangle that displays ZED images
    // vertices
    glEnableVertexAttribArray(Shader::ATTRIB_VERTICES_POS);
    glVertexAttribPointer(Shader::ATTRIB_VERTICES_POS, 3, GL_FLOAT, GL_FALSE, 0, 0);
    // indices
    // texture coordinates
    glEnableVertexAttribArray(Shader::ATTRIB_TEXTURE2D_POS);
    glVertexAttribPointer(Shader::ATTRIB_TEXTURE2D_POS, 2, GL_FLOAT, GL_FALSE, 0, 0);
    // Main loop
    while (!end)
         // code...
    // Disable all OpenGL buffer
    glUseProgram(0);
    glBindVertexArray(0);
    glDeleteBuffers(3, rectVBO);
    ovr_Destroy(hmd);
    ovr_Shutdown();
    SDL_Quit();
    delete zed;
    // quit
    return 0;
    8. Manage render timing
    if (timePerFrame < frameRate)
    	timePerFrame = frameRate;
    // Frame counter
    static unsigned int c = 0;
    // Chronometer
    static unsigned int time = 0;
    if (time > 1000)
    	// Display FPS
    	// Reset chronometer
    	time = 0;
    	// Reset frame counter
    	c = 0;
    time += timePerFrame;
    c++;
    // Start frame chronometer
    time1 = SDL_GetTicks();
    9. Manage input events
    • Key Q released: set end to true to exit the application
    • Key R released: reset hit to zero
    • Key C released: pause/unpause rendering
    • Mouse wheel: increase/decrease hit
    	// If a key is released
    	if (events.type == SDL_KEYUP)
    		// If Q quit the application
    			end = true;
    		// If R reset the hit value
    			hit = 0.0f;
    			refresh = !refresh;
    	// If the mouse wheel is used
    		float s;
    		hit += 0.005f * s;
    10. Render to the Oculus
    10.1. Grab ZED image and bind the frame buffer
    // successful grab ZED image
    // Increment the CurrentIndex to point to the next texture within the output swap texture set.
    // CurrentIndex must be advanced round-robin fashion every time we draw a new frame
    ptextureSet->CurrentIndex = (ptextureSet->CurrentIndex + 1) % ptextureSet->TextureCount;
    // Get the current swap texture pointer
    auto tex = reinterpret_cast<ovrGLTexture*>(&ptextureSet->Textures[ptextureSet->CurrentIndex]);
    // Bind the frame buffer
    glBindFramebuffer(GL_FRAMEBUFFER, fboID);
    // Set its color layer 0 as the current swap texture
    glFramebufferTexture2D(GL_FRAMEBUFFER, GL_COLOR_ATTACHMENT0, GL_TEXTURE_2D, tex->OGL.TexId, 0);
    // Set its depth layer as our depth buffer
    glFramebufferTexture2D(GL_FRAMEBUFFER, GL_DEPTH_ATTACHMENT, GL_TEXTURE_2D, depthBuffID, 0);
    // Clear the frame buffer
    glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT);
    glClearColor(0, 0, 0, 1);
    10.2. Render to each Oculus eye a ZED image
    for (int eye = 0; eye &amp;amp;amp;amp;lt; 2; eye++)
    	// Bind the hit value
    	// Draw the ZED image
    10.3. Optimizing stereo visual comfort
    • Synchronization: Left and right images need to be perfectly synchronized
    • Image Matching: Left and right images need to be matched in terms of alignment, color, and optical characteristics
    • Depth Budget: This is the maximum amount of 3D depth in-front and behind the display that our eyes can support. If the depth budget is exceeded then viewers will find it increasingly uncomfortable to view the stereoscopic images.
    10.4. Submit the frame buffer to the Rift
    } // if (refresh)
    	ovr_Destroy(hmd);
    	ovr_Shutdown();
    	SDL_Quit();
    	delete zed;
    	return -1;
    11. Render to the SDL2 window
    // Copy the frame to the mirror buffer
    // which will be drawn in the SDL2 image
    glBindFramebuffer(GL_DRAW_FRAMEBUFFER, 0);
    GLint w = mirrorTexture->OGL.Header.TextureSize.w;
    GLint h = mirrorTexture->OGL.Header.TextureSize.h;
    glBlitFramebuffer(0, h, w, 0,
    			0, 0, w, h,
    			GL_COLOR_BUFFER_BIT, GL_NEAREST);
    // Swap the SDL2 window
    SDL_GL_SwapWindow(window);
    12. Your application is ready
