  • News
    May 23, 2022.
    Introducing Next-Generation Stereo Depth Sensing Technology
    Revolutionary Neural Depth Mapping
    Bringing ZED SDK to a new level
    Enabling new applications
    Optimized for NVIDIA Jetson AGX Orin
    How to use the NEURAL depth mode
    Download the ZED SDK 3.7
    The NEURAL depth mode is available starting from the ZED SDK v3.7
