Required:
Optional:
“Standard” mixed reality composites three layers: the VR stuff in back, the real stuff, and the VR stuff in front.
The SDK installation ends by restarting your computer. Once you’re back in Windows, download the (ZED Unity plugin, open up your Unity project and import the plugin. To do this, go to Assets -> Import Package -> Custom Package.
Note: One way to get a feel for the ZED is to import the package into a new Unity project and open the example scene in the ZED -> Examples -> Greenscreen ->
Note: This section will help you keep the real and virtual cameras in sync, but they won’t be perfectly aligned until you calibrate them in the next section. Keep this in mind as you run tests in this section. It may be best to use the Scene view, rather than the Game view, to validate your work.
Also if using Oculus, you’ll also have to add a custom precompiler directive to your project, which is easier than it sounds. Go to Edit -> Project Settings -> Player. In the Inspector, open Other Settings and under Scripting Define Symbols, add “ZED_OCULUS.” This tells Unity that it’s safe to use some code from our plugin that depends on having the Oculus plugin installed.
Note: The specifics of lighting a Unity scene is outside the scope of this tutorial, but Unity provides detailed documentation on this topic here. If you are working with a new scene, we suggest experimenting with a Point light, and having at least one Directional light in the scene for shadows.
Go to File -> Build Settings to open up a new menu. If you haven’t yet done this for your current project, you’ll have to add the scene to the Scenes In Build section by clicking “Add Open Scenes.”
Now, with your target scene open, go into the ZED -> Examples -> GreenScreen -> Prefabs folder and drag the ZED_GreenScreen prefab into your scene.
Before we go further, the ZED_GreenScreen object has a component that’s worth exploring. Select ZED_GreenScreen, and in the Inspector, take a look at ZED Manager (ZEDManager.cs).
Oculus Touch Controller: If you don’t already have one in your scene, go to OVR ->Prefabs in the Project window, and drag an OVRCameraRig into your Inspector. Expand the new object, and expand the TrackingSpace object that’s been parented to it. The virtual object you will be using is either LeftHandAnchor or RightHandAnchor, depending on which controller you will be using.
Tip: The [CameraRig] prefab in SteamVR -> Prefabs provides an easy way to manage your headset and first two controllers, visualize your bounds, and a few other features. It also intelligently assigns device numbers to your controllers, and tracked objects added according to Unity3D College. It’s recommended to use this prefab if it does not conflict with your project’s existing setup.
Run the scene. If you’re using Oculus, you’ll note the improvement in delay now that you’ve got the script added. Either way, slide the Latency Compensation slider around to adjust the delay, and test it until the controllers stay aligned even when you move them quickly.
Before erosion
After erosion
Before white clip
After white clip
Before despill
After despill
