PositionalTrackingParameters Class Reference
Structure containing a set of parameters for the positional tracking module initialization. More...
 PositionalTrackingParameters (Transform init_position_=Transform(), bool enable_memory_=true, bool enable_pose_smoothing_=false, String area_path_=String(), bool set_floor_as_origin_=false, bool enable_imu_fusion_=true, bool set_as_static_=false, float depth_min_range=-1.f, bool set_gravity_as_origin_=true, POSITIONAL_TRACKING_MODE mode=POSITIONAL_TRACKING_MODE::GEN_1)
 Default constructor. More...
bool save (String filename, SERIALIZATION_FORMAT format=SERIALIZATION_FORMAT::LEGACY) const
bool load (String filename, SERIALIZATION_FORMAT format=SERIALIZATION_FORMAT::AUTO)
bool operator== (const PositionalTrackingParameters &param1) const
bool operator!= (const PositionalTrackingParameters &param1) const
Attributes
Transform initial_world_transform
 Position of the camera in the world frame when the camera is started. More...
bool enable_area_memory
 Whether the camera can remember its surroundings. More...
 Whether to enable smooth pose correction for small drift correction. More...
 Initializes the tracking to be aligned with the floor plane to better position the camera in space. More...
String area_file_path
 Path of an area localization file that describes the surroundings (saved from a previous tracking session). More...
 Whether to enable the IMU fusion. More...
bool set_as_static
 Whether to define the camera as static. More...
 Minimum depth used by the ZED SDK for positional tracking. More...
 Whether to override 2 of the 3 rotations from initial_world_transform using the IMU gravity. More...
 Positional tracking mode used. More...
bool enable_light_computation_mode = false
 Should enable light computation mode. More...
Note
Constructor and Destructor
◆ PositionalTrackingParameters()
PositionalTrackingParameters ( Transform  init_position_ = Transform(),
bool  enable_memory_ = true,
bool  enable_pose_smoothing_ = false,
String  area_path_ = String(),
bool  set_floor_as_origin_ = false,
bool  enable_imu_fusion_ = true,
bool  set_as_static_ = false,
float  depth_min_range = -1.f,
bool  set_gravity_as_origin_ = true,
POSITIONAL_TRACKING_MODE  mode = POSITIONAL_TRACKING_MODE::GEN_1
Sets all parameters to their default and optimized values.
◆ save()
bool save ( String  filename,
SERIALIZATION_FORMAT  format = SERIALIZATION_FORMAT::LEGACY
) const
Parameters
Returns
Warning
◆ load()
bool load ( String  filename,
SERIALIZATION_FORMAT  format = SERIALIZATION_FORMAT::AUTO
Parameters
Returns
◆ encode()
) const
Parameters
Returns
◆ decode()
Parameters
Returns
◆ operator==()
bool operator== ( const PositionalTrackingParameters &  param1) const
Comparison operator ==
Parameters
PositionalTrackingParametersto compare
Returns
◆ operator!=()
bool operator!= ( const PositionalTrackingParameters &  param1) const
Comparison operator !=
Parameters
Returns
Variables
◆ initial_world_transform
Use this sl::Transform to place the camera frame in the world frame.
Default: Identity matrix.
Note
The camera frame (which defines the reference frame for the camera) is by default positioned at the world frame when tracking is started.
◆ enable_area_memory
This helps correct positional tracking drift and can be helpful for positioning different cameras relative to one other in space.
Default: true
Warning
This mode requires more resources to run, but greatly improves tracking accuracy.
We recommend leaving it on by default.
◆ enable_pose_smoothing
Default: false
◆ set_floor_as_origin
Default: false
Note
This launches floor plane detection in the background until a suitable floor plane is found.
The tracking will start in sl::POSITIONAL_TRACKING_STATE::SEARCHING state.
Warning
This features does not work with sl::MODEL::ZED since it needs an IMU to classify the floor.
The camera needs to look at the floor during initialization for optimum results.
◆ area_file_path
Default: (empty)
Note
Loading an area file will start a search phase, during which the camera will try to position itself in the previously learned area.
Warning
The area file describes a specific location. If you are using an area file describing a different location, the tracking function will continuously search for a position and may not find a correct one.
The '.area' file can only be used with the same depth mode (sl::DEPTH_MODE) as the one used during area recording.
◆ enable_imu_fusion
When set to false, only the optical odometry will be used.
Default: true
Note
This setting has no impact on the tracking of a camera.
sl::MODEL::ZED does not have an IMU.
◆ set_as_static
bool set_as_static
If true, it will not move in the environment. This allows you to set its position using initial_world_transform.
All ZED SDK functionalities requiring positional tracking will be enabled without additional computation.
sl::Camera::getPosition() will return the value set as initial_world_transform.
Default: false
◆ depth_min_range
It may be useful for example if any steady objects are in front of the camera and may perturb the positional tracking algorithm.
Default: -1 (no minimum depth)
◆ set_gravity_as_origin
Default: true
Note
This parameter does nothing on sl::ZED::MODEL since it does not have an IMU.
◆ mode
Can be used to improve accuracy in some types of scene at the cost of longer runtime.
Default: sl::POSITIONAL_TRACKING_MODE::GEN_1
◆ enable_light_computation_mode
If enabled the tracking will just run the part needed by Fusion and nothing more. This parameter will degrade accuracy if positional tracking module is used alone without Fusion. This parameter works only with GEN_2 module.
