The Mat class can handle multiple matrix format from 1 to 4 channels, with different value types (float or uchar), and can be stored CPU and/or GPU side. More...
General Functions | |
| Mat () | |
| empty Mat default constructor. More... | |
| Mat (size_t width, size_t height, MAT_TYPE mat_type, MEM memory_type=MEM_CPU) | |
| Mat constructor. More... | |
| Mat (size_t width, size_t height, MAT_TYPE mat_type, sl::uchar1 *ptr, size_t step, MEM memory_type=MEM_CPU) | |
| Mat constructor from an existing data pointer. More... | |
| Mat (size_t width, size_t height, MAT_TYPE mat_type, sl::uchar1 *ptr_cpu, size_t step_cpu, sl::uchar1 *ptr_gpu, size_t step_gpu) | |
| Mat constructor from two existing data pointers, CPU and GPU. More... | |
| Mat (Resolution resolution, MAT_TYPE mat_type, MEM memory_type=MEM_CPU) | |
| Mat (Resolution resolution, MAT_TYPE mat_type, sl::uchar1 *ptr, size_t step, MEM memory_type=MEM_CPU) | |
| Mat (Resolution resolution, MAT_TYPE mat_type, sl::uchar1 *ptr_cpu, size_t step_cpu, sl::uchar1 *ptr_gpu, size_t step_gpu) | |
| Mat (const Mat &mat) | |
| Mat constructor by copy (shallow copy). More... | |
| void | alloc (size_t width, size_t height, MAT_TYPE mat_type, MEM memory_type=MEM_CPU) |
| Allocates the Mat memory. More... | |
| void | alloc (Resolution resolution, MAT_TYPE mat_type, MEM memory_type=MEM_CPU) |
| ~Mat () | |
| Mat destructor. This function calls free to release owned memory. More... | |
| void | free (MEM memory_type=MEM_CPU|MEM_GPU) |
| Free the owned memory. More... | |
| Mat & | operator= (const Mat &that) |
| Performs a shallow copy. More... | |
| ERROR_CODE | updateCPUfromGPU () |
| Downloads data from DEVICE (GPU) to HOST (CPU), if possible. More... | |
| ERROR_CODE | updateGPUfromCPU () |
| Uploads data from HOST (CPU) to DEVICE (GPU), if possible. More... | |
| ERROR_CODE | copyTo (Mat &dst, COPY_TYPE cpyType=COPY_TYPE_CPU_CPU) const |
| Copies data an other Mat (deep copy). More... | |
| ERROR_CODE | setFrom (const Mat &src, COPY_TYPE cpyType=COPY_TYPE_CPU_CPU, cudaStream_t stream=0) |
| Copies data from an other Mat (deep copy). More... | |
| ERROR_CODE | read (const String &filePath) |
| Reads an image from a file (only if MEM_CPU is available on the current Mat). More... | |
| ERROR_CODE | write (const String &filePath) |
| Writes the Mat (only if MEM_CPU is available) into a file as an image. More... | |
| template<typename T > | |
| ERROR_CODE | setTo (T value, MEM memory_type=MEM_CPU) |
| Fills the Mat with the given value. More... | |
| template<typename N > | |
| ERROR_CODE | setValue (size_t x, size_t y, N value, MEM memory_type=MEM_CPU) |
| Sets a value to a specific point in the matrix. More... | |
| ERROR_CODE | getValue (size_t x, size_t y, N *value, MEM memory_type=MEM_CPU) const |
| Returns the value of a specific point in the matrix. More... | |
| size_t | getWidth () const |
| Returns the width of the matrix. More... | |
| size_t | getHeight () const |
| Returns the height of the matrix. More... | |
| Resolution | getResolution () const |
| Returns the resolution (width and height) of the matrix. More... | |
| size_t | getChannels () const |
| Returns the number of values stored in one pixel. More... | |
| MAT_TYPE | getDataType () const |
| Returns the format of the matrix. More... | |
| MEM | getMemoryType () const |
| Returns the type of memory (CPU and/or GPU). More... | |
| N * | getPtr (MEM memory_type=MEM_CPU) const |
| Returns the CPU or GPU data pointer. More... | |
| size_t | getStepBytes (MEM memory_type=MEM_CPU) const |
| Returns the memory step in Bytes (the Bytes size of one pixel row). More... | |
| size_t | getStep (MEM memory_type=MEM_CPU) const |
| Returns the memory step in number of elements (the number of values in one pixel row). More... | |
| size_t | getPixelBytes () const |
| Returns the size in bytes of one pixel. More... | |
| size_t | getWidthBytes () const |
| Returns the size in bytes of a row. More... | |
| String | getInfos () |
| Return the informations about the Mat into a String. More... | |
| bool | isInit () const |
| Defines whether the Mat is initialized or not. More... | |
| bool | isMemoryOwner () const |
| Returns whether the Mat is the owner of the memory it access. More... | |
| ERROR_CODE | clone (const Mat &src) |
| Duplicates Mat by copy (deep copy). More... | |
| ERROR_CODE | move (Mat &dst) |
| Moves Mat data to another Mat. More... | |
Static Functions | |
| static void | swap (Mat &mat1, Mat &mat2) |
| Swaps the content of the provided Mat (only swaps the pointers, no data copy). More... | |
Attributes | |
| String | name = "n/a" |
| bool | verbose = false |
| timeStamp | timestamp = 0 |
Mat is defined in a row-major order, it means that, for an image buffer, the entire first row is stored first, followed by the entire second row, and so on.
The CPU and GPU buffer aren't automatically synchronized for performance reasons, you can use updateCPUfromGPU / updateGPUfromCPU to do it. If you are using the GPU side of the Mat object, you need to make sure to call free before destroying the sl::Camera object. The destruction of the sl::Camera object delete the CUDA context needed to free the GPU Mat memory.
Mat constructor.
This function directly allocates the requested memory. It calls alloc.
| width | : width of the matrix in pixels. |
| height | : height of the matrix in pixels. |
| mat_type | : the type of the matrix (MAT_TYPE_32F_C1, MAT_TYPE_8U_C4...). |
| memory_type | : defines where the buffer will be stored. (MEM_CPU and/or MEM_GPU). |
| Mat | ( | size_t | width, |
| size_t | height, | ||
| MAT_TYPE | mat_type, | ||
| sl::uchar1 * | ptr, | ||
| size_t | step, | ||
| MEM | memory_type = MEM_CPU |
This function doesn't allocate the memory.
| ptr | : pointer to the data array. (CPU or GPU). |
| step | : step of the data array. (the Bytes size of one pixel row). |
| sl::uchar1 * | ptr_cpu, | ||
| size_t | step_cpu, | ||
| sl::uchar1 * | ptr_gpu, | ||
| size_t | step_gpu | ||
| ptr_cpu | : CPU pointer to the data array. |
| step_cpu | : step of the CPU data array (the Bytes size of one pixel row). |
| ptr_gpu | : GPU pointer to the data array. |
| step_gpu | : step of the GPU data array (the Bytes size of one pixel row). |
| Mat | ( | Resolution | resolution, |
Mat constructor.
| resolution | : the size of the matrix in pixels. |
| memory_type | : defines where the buffer will be stored (MEM_CPU and/or MEM_GPU). |
| size_t | step, | ||
| step | : step of the data array (the Bytes size of one pixel row). |
| void alloc | ( | Resolution | resolution, |
| mat_type | : the type of the matrix (sl::MAT_TYPE_32F_C1,sl::MAT_TYPE_8U_C4...). |
| memory_type | : defines where the buffer will be stored. (sl::MEM_CPU and/or sl::MEM_GPU). |
| ERROR_CODE updateCPUfromGPU | ( | ) |
| ERROR_CODE updateGPUfromCPU | ( | ) |
| ERROR_CODE copyTo | ( | Mat & | dst, |
| COPY_TYPE | cpyType = COPY_TYPE_CPU_CPU |
| ) | const |
| dst | : the Mat where the data will be copied. |
| cpyType | : specify the memories that will be used for the copy. |
| ERROR_CODE setFrom | ( | const Mat & | src, |
| COPY_TYPE | cpyType = COPY_TYPE_CPU_CPU, |
| cudaStream_t | stream = 0 |
| src | : the Mat where the data will be copied from. |
| cpyType | : specify the memories that will be used for the update. |
| ERROR_CODE read | ( | const String & | filePath | ) |
Supported input files format are PNG and JPEG.
| filePath | : file path including the name and extension. |
| ERROR_CODE write | ( | const String & | filePath | ) |
Supported output files format are PNG and JPEG.
| ERROR_CODE setTo | ( | T | value, |
| ERROR_CODE setValue | ( | size_t | x, |
| size_t | y, | ||
| N | value, | ||
| x | : specify the column. |
| y | : specify the row. |
| value | : the value to be set. |
| memory_type | : defines which memory will be updated. |
| ERROR_CODE getValue | ( | size_t | x, |
| size_t | y, | ||
| N * | value, | ||
| ) | const |
| x | : specify the column |
| y | : specify the row |
| memory_type | : defines which memory should be read. |
inline |
inline |
inline |
inline |
inline |
inline |
inline |
inline |
| String getInfos | ( | ) |
inline |
inline |
| ERROR_CODE clone | ( | const Mat & | src | ) |
| ERROR_CODE move | ( | Mat & | dst | ) |
| String name = "n/a" |
| bool verbose = false |
| timeStamp timestamp = 0 |
