Tutorials
Feb 2, 2018.
How to Make Mixed Reality VR Videos in Unity
Part 1: Introduction
Table of Contents
  • 1 – Introduction
  • 2 – Installing the ZED Plugin
  • 3 – Positioning the Camera
  • 4 – Calibration
  • 5 – Controller Delay
  • 6 – Background Subtraction
  • 7 – Virtual Lighting
  • 8 – Final Output
What you’ll need
Required:
  • ZED depth camera (order here) or ZED mini (order here)
  • VR-capable, ZED-compatible PC (requires NVIDIA GPU and a USB 3.0 port)
  • HTC Vive or Oculus Rift
  • ZED SDK and Unity plugin (downloads here)
  • Unity 5.6 or greater (download here)
  • OBS, an open-source video capture program (download here)
  • Access to the game/app’s source code/Unity project
Optional:
  • Vive Tracker (purchase from HTC or Amazon) or extra Vive controller
  • USB extension cables (see our preferred choices here)
How mixed reality works
“Standard” mixed reality composites three layers: the VR stuff in back, the real stuff, and the VR stuff in front.
Notes before we start
  • This is a detailed, step-by-step tutorial. If you’re comfortable implementing mixed reality on your own and just need a quick reference, our documentation is far less verbose.
  • “Mixed reality” means different things to different people. In this tutorial, we’re talking about filming someone in front of a greenscreen to show them inside a virtual world.
  • We refer to our ZED camera here, but our new camera, the ZED mini, supports all the features listed here and can be used equally well.
  • This guide requires adding our plugin to a game’s Unity project, so it doesn’t apply if you have bought a VR game on Steam and want to make a mixed reality video. However, you can still use the ZED as a normal camera in the standard ways of implementing mixed reality, which will let you use our calibration program.
  • Oculus has added native ZED integration to the mixed reality part of their SDK. If you are only building for the Oculus Rift, you may consider using their implementation instead. They offer a guide here. This implementation does not include per-pixel occlusion, but does offer similar lighting effects and adds a useful “virtual greenscreen” that our own plugin doesn’t currently implement. It is also currently the only way to use a third controller to track your camera when using a Rift.
  • This guide was written based on v2.3 of the ZED SDK and Unity plugins. Small details may change in the future.
Part 2: Installing the ZED Plugin
The SDK installation ends by restarting your computer. Once you’re back in Windows, download the (ZED Unity plugin, open up your Unity project and import the plugin. To do this, go to Assets -> Import Package -> Custom Package.
Note: One way to get a feel for the ZED is to import the package into a new Unity project and open the example scene in the ZED -> Examples -> Greenscreen -> Scenes folder. The prefab is already set up and there are several objects for playing around and testing occlusion. This tutorial focuses on adding a ZED to an existing project, and assumes that you either have an existing scene populated with other gameobjects, or that you’ll be building one in the same scene after finishing the tutorial.
Now, with your target scene open, go into the ZED -> Examples -> GreenScreen -> Prefabs folder and drag the ZED_GreenScreen prefab into your scene.
Before we go further, the ZED_GreenScreen object has a component that’s worth exploring. Select ZED_GreenScreen, and in the Inspector, take a look at ZED Manager (ZEDManager.cs).
  • Resolution: The input resolution from the camera, at 16:9. Note that the higher the resolution, the lower the FPS, even with a powerful computer; bigger images mean we can fit fewer of them through the USB 3.0 cable. The options are 480p (VGA) at 100FPS, 720p at 60FPS, 1080p at 30FPS, and 2k at 15FPS. Typically, 1080p30 is the best mix of resolution and frame rate for mixed reality.
  • Depth Mode: The quality of the depth map. Turning it up will make all of the effects more accurate, but will cost performance. ULTRA is recommended if your computer can handle it as it provides a substantial improvement over the next best level (QUALITY).
  • Enable Tracking: You can have the ZED track its own position on its own without attaching it to a tracked object. We’ll get into that more in the next section.
  • Enable Spatial Memory: If using the ZED’s tracking feature, this will remember features it sees as it moves around the room to help it reposition itself later.
  • Path Spatial Memory: Where you save the spatial memory file, if using it.
  • Everything else: The rest should remain unchanged for greenscreen-style mixed reality (unless you want to turn down the camera’s brightness).
Troubleshooting
  • If you are getting errors that the ZED plugin cannot find required files, it’s likely that either your Unity plugin version doesn’t match the ZED SDK plugin, or that something went wrong when you installed the ZED SDK or CUDA. To test the first, check the versions of the SDK and your plugin to ensure they match. To check the second, try running one of the apps included in the ZED SDK, like ZED Depth Viewer.
  • If you only see the view from an existing virtual camera, such as the one your VR headset sees, but the ZED’s blue light is on and you’ve given it time to initialize, check the Depth value of the existing virtual camera. That number needs to be lower than the ZED rig’s Depth value, which is 0 by default. Changing the virtual camera’s Depth to -1 should fix this.
Part 3: Positioning the Camera
  • Fixed Position: The ZED remains fixed in one place. You measure where this is in relation to the VR world, place the virtual camera there, and never move either. This is the simplest method, but the least flexible.
  • ZED Positional Tracking: The ZED starts in the same place each time, but uses its own inside-out tracking to keep the virtual camera in sync with the real one. This gives more flexibility, but requires you to return the camera to the exact same place each time you start the scene, which can be difficult.
  • Vive Tracker or Controller: The ZED is attached to an object tracked by Oculus’ Constellation or OpenVR’s Lighthouse systems, such as a Vive Tracker. This requires either extra hardware or sacrificing one of your existing controllers, and a more involved setup. But once configured, it’s the most flexible and reliable solution.
Note: This section will help you keep the real and virtual cameras in sync, but they won’t be perfectly aligned until you calibrate them in the next section. Keep this in mind as you run tests in this section. It may be best to use the Scene view, rather than the Game view, to validate your work.
Fixed Position
  • If laying the ZED on a flat surface, it’s best not to use the mini tripod that came with the ZED as it’s hard to keep track of all three rotational axes. Use tape to outline its starting position.
  • If you must use the mini tripod, find some way to mark all three axes, such as a piece of clay placed and shaped such that an edge of the ZED can rest on it.
  • If using a (regular) tripod, put small pieces of tape under each leg of the tripod.
  • If you plan on rotating the ZED on the tripod, mark on the floor the exact direction the ZED was facing at start. If you don’t plan on doing this, minimize the ZED’s ability to rotate on its own by rotating it clockwise as far as you can on the ¼” screw, and tighten any knobs on the tripod itself that may allow it to spin freely if loose.
  • If you plan on adjusting the height of the tripod, wrap pieces of tape at the bottom of each rod segment where it enters the one beneath it.
Vive Tracker or Extra Controller
Oculus Touch Controller: If you don’t already have one in your scene, go to OVR ->Prefabs in the Project window, and drag an OVRCameraRig into your Inspector. Expand the new object, and expand the TrackingSpace object that’s been parented to it. The virtual object you will be using is either LeftHandAnchor or RightHandAnchor, depending on which controller you will be using.
Tip: The [CameraRig] prefab in SteamVR -> Prefabs provides an easy way to manage your headset and first two controllers, visualize your bounds, and a few other features. It also intelligently assigns device numbers to your controllers, and tracked objects added according to Unity3D College. It’s recommended to use this prefab if it does not conflict with your project’s existing setup.
Finishing up your tracked object
Part 4: Calibration
  • Choose None if you are not tracking the ZED or using the ZED’s own tracking.
  • Choose Vive Tracker if, well, you guessed it.
  • Choose Pad if you are using an Oculus Touch controller or a Vive Controller.
  • A 2D screen floating in front of you showing video feed from the ZED. Look closely and you’ll see that there are virtual versions of your controllers on your screen as well. They move when you move the real ones, but are likely not lined up with their real counterparts. That’s what you’re here to fix.
  • A small UI floating above one of your controllers, with a list of positions and rotations similar to the one you often see at the top of the inspector. Also, the controller this box is floating above is blue.
  • A 3D “point cloud” of what the ZED sees. It may be behind you. Notice that you’re there, as well!
Part 5: Controller Delay
Also if using Oculus, you’ll also have to add a custom precompiler directive to your project, which is easier than it sounds. Go to Edit -> Project Settings -> Player. In the Inspector, open Other Settings and under Scripting Define Symbols, add “ZED_OCULUS.” This tells Unity that it’s safe to use some code from our plugin that depends on having the Oculus plugin installed.
Run the scene. If you’re using Oculus, you’ll note the improvement in delay now that you’ve got the script added. Either way, slide the Latency Compensation slider around to adjust the delay, and test it until the controllers stay aligned even when you move them quickly.
Part 6: Background Subtraction
Before erosion
After erosion
Before white clip
After white clip
Before despill
After despill
Part 7: Virtual Lighting
  • You can have a maximum of 8 lights set to work on the real world at the same time
  • Only Directional lights can cast shadows – we recommend exactly one per scene to get the desired effect
  • This only works on Point, Spot and Directional lights. Area lights, emissive materials and lights instantiated by a particle system aren’t supported.
Note: The specifics of lighting a Unity scene is outside the scope of this tutorial, but Unity provides detailed documentation on this topic here. If you are working with a new scene, we suggest experimenting with a Point light, and having at least one Directional light in the scene for shadows.
Matching Virtual and Real Lights
Part 8: Final Output
Building your Project
Go to File -> Build Settings to open up a new menu. If you haven’t yet done this for your current project, you’ll have to add the scene to the Scenes In Build section by clicking “Add Open Scenes.”
Configuring OBS
  • General: Preferences for OBS itself. Not related to the output.
  • Stream: Some settings you’ll have to provide before the “Start Streaming” button on the main window will do anything. Setting it up is different depending on your platform, so you should seek out a different tutorial specific for that platform – many make use of OBS.
  • Output: Quality and formatting settings for both streaming and recording, along with some miscellaneous settings. This is also where you set the path that recorded files are saved in. If you’re recording, note that the default recording format is .flv, which is less portable than other file formats like .mp4, so consider changing it before recording.
  • Audio: Quality settings for your sound, along with optional hotkey settings if you want to quickly enable/disable an input device mid-stream (push-to-talk).
  • Video: The resolution of the output. Note that the settings are separate for the Canvas (the preview window) and the actual output. Ideally, you should make these resolutions the same. But if you can’t, at least make sure they’re the same aspect ratio or else your output will get cropped and/or distorted.
  • Hotkeys: Exactly what you’d expect.
  • Advanced: Non-critical but useful functions (such as adding a delay to your stream) and settings for experts (like color formats).
