  • Updates
    Jun 11, 2018.
    ZED SDK 2.4 is Now Available
    New Firmware Update
    Multi-Camera Support
    Instant Plane Detection
    Improved Positional Tracking
    Faster SVO Recording
    Recording uncompressed stereo video at up to 60FPS in 2560×720 resolution is a challenge for many platforms. To reduce the load on your hard drive, we provide two compression modes: Lossless and Lossy. These two modes now perform compression in parallel with I/O operations, improving throughput by 40-50%.
    Jetson Made Faster, Better
    Other New Features and Fixes
    • Updated the video capture pipeline to improve USB 3.0 capture on Windows 10 and make it significantly more reliable. All recent laptops should now be able to run the ZED without dropping or skipping frames.
    • Reduced video capture latency on Linux.
    • Added new Floor Detection feature.
    • Added new Plane Detection at HIT feature. It allows to find a plane at a selected position in the scene.
    • Improved open() function to allow SDK, tools and plugins to open a camera 0.5s faster.
    • Reduced SVO compression ratio in Lossy mode to improve image quality.
    • Improved detail and stability of depth map in PERFORMANCE and ULTRA modes.
    • Updated depth confidence maps.
    • Added samples to show how to use multi-camera and plane detection.
    • Added sample for native capture on OpenCV.
    • Updated to JetPack 3.2 for Jetson TX1 and TX2.
    • Added Ubuntu installer compiled with CUDA 9 for better TensorFlow compatibility.
    • Moved Unity plugin to GitHub. Source code and release notes will be posted directly on GitHub starting with 2.4.
    • Fixed various bugs related to SVO playback and IMU tracking.
    Download 2.4.1 Today!
    Feedback
    -The ZED Team
