StreamingParameters Struct Reference
Structure containing the options used to stream with the ZED SDK. More...
 StreamingParameters (STREAMING_CODEC codec_=STREAMING_CODEC::H265, unsigned short port_=30000, unsigned int bitrate_=0, int gop_size_=-1, bool adaptative_bitrate_=false, unsigned short chunk_size_=16084, unsigned int target_framerate_=0)
 Default constructor. More...
bool operator== (const StreamingParameters &param1) const
bool operator!= (const StreamingParameters &param1) const
Attributes
STREAMING_CODEC codec = STREAMING_CODEC::H265
 Encoding used for streaming. More...
unsigned short port = 30000
 Port used for streaming. More...
unsigned int bitrate = 0
 Streaming bitrate (in Kbits/s) used for streaming. More...
int gop_size = -1
 GOP size in number of frames. More...
bool adaptative_bitrate = false
 Defines whether the adaptive bitrate is enable. More...
unsigned short chunk_size = 16084
 Size of a single chunk. More...
unsigned int target_framerate = 0
 Framerate for the streaming output. More...
Note
Constructor and Destructor
◆ StreamingParameters()
StreamingParameters ( STREAMING_CODEC  codec_ = STREAMING_CODEC::H265,
unsigned short  port_ = 30000,
unsigned int  bitrate_ = 0,
int  gop_size_ = -1,
bool  adaptative_bitrate_ = false,
unsigned short  chunk_size_ = 16084,
unsigned int  target_framerate_ = 0
All the parameters are set to their default values.
◆ save()
bool save ( String  filename,
) const
Parameters
Returns
Warning
◆ load()
bool load ( String  filename,
Parameters
Returns
◆ encode()
) const
Parameters
Returns
◆ decode()
Parameters
Returns
◆ operator==()
bool operator== ( const StreamingParameters &  param1) const
Comparison operator ==
Parameters
StreamingParametersto compare
Returns
◆ operator!=()
bool operator!= ( const StreamingParameters &  param1) const
Comparison operator !=
Parameters
Returns
Variables
◆ codec
◆ port
Warning
Port must be an even number. Any odd number will be rejected.
Port must be opened.
◆ bitrate
sl::STREAMING_CODEC sl::RESOLUTION FPS Bitrate (kbps)
H264 HD2K 15 8500
H264 HD1080 30 12500
H264 HD720 60 7000
H265 HD2K 15 7000
H265 HD1080 30 11000
H265 HD720 60 6000
Default: 0 (it will be set to the best value depending on your resolution/FPS)
Note
Available range: [1000 - 60000]
◆ gop_size
int gop_size = -1
Default: -1 (the GOP size will last at maximum 2 seconds, depending on camera FPS)
Note
The GOP size determines the maximum distance between IDR/I-frames. Very high GOP size will result in slightly more efficient compression, especially on static scenes. But latency will increase.
Maximum value: 256
◆ adaptative_bitrate
Default: false
Note
Bitrate will be adjusted depending the number of packet dropped during streaming.
If activated, the bitrate can vary between [bitrate/4, bitrate].
Warning
Currently, the adaptive bitrate only works when "sending" device is a NVIDIA Jetson (X1, X2, Xavier, Nano).
◆ chunk_size
Default: 16084
Note
Stream buffers are divided into X number of chunks where each chunk is chunk_size bytes long.
You can lower chunk_size value if network generates a lot of packet lost: this will generates more chunk for a single image, but each chunk sent will be lighter to avoid inside-chunk corruption.
Increasing this value can decrease latency.
Note
Available range: [1024 - 65000]
◆ target_framerate
Default: 0 (camera framerate will be taken)
Warning
This framerate must be below or equal to the camera framerate.
Allowed framerates are 15, 30, 60 or 100 if possible.
Any other values will be discarded and camera FPS will be taken.
