SpatialMappingParameters Class Reference
Structure containing a set of parameters for the spatial mapping module. More...
Types
enum class  SPATIAL_MAP_TYPE
 Lists the types of spatial maps that can be created. More...
enum class  MAPPING_RESOLUTION
 Lists the spatial mapping resolution presets. More...
enum class  MAPPING_RANGE
 Lists the spatial mapping depth range presets. More...
typedef std::pair< float, float > interval
 Float pair defining an interval. More...
 SpatialMappingParameters (MAPPING_RESOLUTION resolution=MAPPING_RESOLUTION::MEDIUM, MAPPING_RANGE range=MAPPING_RANGE::AUTO, int max_memory_usage_=2048, bool save_texture_=false, bool use_chunk_only_=false, bool reverse_vertex_order_=false, SPATIAL_MAP_TYPE map_type=SPATIAL_MAP_TYPE::MESH, int stability_counter=0, float disparity_std=0.3f, float decay=1.f, bool enable_forget_past=false)
 Default constructor. More...
void set (MAPPING_RESOLUTION mapping_resolution=MAPPING_RESOLUTION::MEDIUM)
 Sets the resolution to a sl::SpatialMappingParameters::MAPPING_RESOLUTION preset. More...
void set (MAPPING_RANGE mapping_range=MAPPING_RANGE::MEDIUM)
 Sets the range to a sl::SpatialMappingParameters::MAPPING_RANGE preset. More...
bool save (String filename, SERIALIZATION_FORMAT format=SERIALIZATION_FORMAT::LEGACY) const
bool load (String filename, SERIALIZATION_FORMAT format=SERIALIZATION_FORMAT::AUTO)
bool operator== (const SpatialMappingParameters &param1) const
bool operator!= (const SpatialMappingParameters &param1) const
Static Functions
static float get (MAPPING_RESOLUTION mapping_resolution=MAPPING_RESOLUTION::MEDIUM)
 Returns the value corresponding to a sl::SpatialMappingParameters::MAPPING_RESOLUTION preset in meters. More...
static float get (MAPPING_RANGE mapping_range=MAPPING_RANGE::MEDIUM)
 Returns the value corresponding to a sl::SpatialMappingParameters::MAPPING_RANGE preset in meters. More...
static float getRecommendedRange (MAPPING_RESOLUTION mapping_resolution, Camera &camera)
 Returns the recommended maximum depth value corresponding to a sl::SpatialMappingParameters::MAPPING_RESOLUTION preset. More...
static float getRecommendedRange (float resolution_meters, Camera &camera)
 Returns the recommended maximum depth value for the given resolution in meters. More...
Attributes
float resolution_meter = 0.05f
 Spatial mapping resolution in meters. More...
float range_meter = 0.f
 Depth range in meters. More...
bool save_texture = false
 Whether to save the texture. More...
bool use_chunk_only = false
 Whether to only use chunks. More...
int max_memory_usage = 2048
 The maximum CPU memory (in MB) allocated for the meshing process. More...
bool reverse_vertex_order = false
 Whether to inverse the order of the vertices of the triangles. More...
SPATIAL_MAP_TYPE map_type = SPATIAL_MAP_TYPE::MESH
 The type of spatial map to be created. More...
int stability_counter = 0
 Control the integration rate of the current depth into the mapping process. More...
float disparity_std = 0.3
 Control the disparity noise (standard deviation) in px. set a very small value (<0.1) if the depth map of the scene is accurate. set a big value (>0.5) if the depth map is noisy. More...
float decay = 1
 Adjust the weighting factor for the current depth during the integration process. By default, the value is set to 1, which results in the complete integration and fusion of the current depth with the previously integrated depth. Setting it to 0 discards all previous data and solely integrates the current depth. More...
bool enable_forget_past = false
 This parameter enables the forgetting of the previous map to limit memory and drift issues. It enables a local spatial mapping that only keeps a mapped scene around the current camera position. The distance threshold is set to be equal to 1.5 x the range of the spatial mapping. More...
Static Attributes
static const interval allowed_resolution
 The resolution allowed by the spatial mapping: More...
static const interval allowed_range
 The maximum depth allowed by spatial mapping: More...
Note
Member Typedef Documentation
◆ interval
typedef std::pair<float, float> interval
Constructor and Destructor
◆ SpatialMappingParameters()
SpatialMappingParameters ( MAPPING_RESOLUTION  resolution = MAPPING_RESOLUTION::MEDIUM,
MAPPING_RANGE  range = MAPPING_RANGE::AUTO,
int  max_memory_usage_ = 2048,
bool  save_texture_ = false,
bool  use_chunk_only_ = false,
bool  reverse_vertex_order_ = false,
SPATIAL_MAP_TYPE  map_type = SPATIAL_MAP_TYPE::MESH,
int  stability_counter = 0,
float  disparity_std = 0.3f,
float  decay = 1.f,
Sets all parameters to their default and optimized values.
◆ get() [1/2]
static float get ( MAPPING_RESOLUTION  mapping_resolution = MAPPING_RESOLUTION::MEDIUM)
static
Parameters
mapping_resolutionThe desired MAPPING_RESOLUTION. Default: MAPPING_RESOLUTION::MEDIUM
Returns
The value of mapping_resolution in meters.
◆ set() [1/2]
void set ( MAPPING_RESOLUTION  mapping_resolution = MAPPING_RESOLUTION::MEDIUM)
Parameters
◆ get() [2/2]
static float get ( MAPPING_RANGE  mapping_range = MAPPING_RANGE::MEDIUM)
static
Parameters
mapping_rangeThe desired MAPPING_RANGE. Default: MAPPING_RANGE::MEDIUM
Returns
The value of mapping_range in meters.
◆ set() [2/2]
void set ( MAPPING_RANGE  mapping_range = MAPPING_RANGE::MEDIUM)
Parameters
◆ getRecommendedRange() [1/2]
static float getRecommendedRange ( MAPPING_RESOLUTION  mapping_resolution,
Camera &  camera
static
Parameters
cameraThe Camera object that will run the spatial mapping.
Returns
The maximum value of the depth in meters.
◆ getRecommendedRange() [2/2]
static float getRecommendedRange ( float  resolution_meters,
Camera &  camera
static
Parameters
resolution_metersThe desired resolution in meters.
Returns
◆ save()
bool save ( String  filename,
SERIALIZATION_FORMAT  format = SERIALIZATION_FORMAT::LEGACY
) const
Parameters
Returns
Warning
◆ load()
bool load ( String  filename,
SERIALIZATION_FORMAT  format = SERIALIZATION_FORMAT::AUTO
Parameters
Returns
◆ encode()
) const
Parameters
Returns
◆ decode()
Parameters
Returns
◆ operator==()
bool operator== ( const SpatialMappingParameters &  param1) const
Comparison operator ==
Parameters
SpatialMappingParametersto compare
Returns
◆ operator!=()
bool operator!= ( const SpatialMappingParameters &  param1) const
Comparison operator !=
Parameters
Returns
Variables
◆ resolution_meter
Note
It should fit allowed_resolution.
◆ allowed_resolution
static
  • allowed_resolution.first is the minimum value allowed
  • allowed_resolution.second is the maximum value allowed
◆ range_meter
Can be different from the value set by sl::InitParameters::depth_maximum_distance.
Note
Set to 0 by default. In this case, the range is computed from resolution_meter and from the current internal parameters to fit your application.
◆ allowed_range
static
  • allowed_range.first is the minimum value allowed
  • allowed_range.second is the maximum value allowed
◆ save_texture
If set to true, you will be able to apply the texture to your mesh after it is created.
Note
This option will consume more memory.
This option is only available for sl::SpatialMappingParameters::SPATIAL_MAP_TYPE::MESH.
◆ use_chunk_only
If set to false, you will ensure consistency between the mesh and its inner chunk data.
Note
Updating the mesh is time-consuming.
Setting this to true results in better performance.
◆ max_memory_usage
◆ reverse_vertex_order
If your display process does not handle front and back face culling, you can use this to correct it.
Note
◆ map_type
This dictates the format that will be used for the mapping (e.g. mesh, point cloud).
See sl::SpatialMappingParameters::SPATIAL_MAP_TYPE.
◆ stability_counter
This parameter controls how many times a stable 3D points should be seen before it is integrated into the spatial mapping.
Default: 0 (this will define the stability counter based on the mesh resolution, the higher the resolution, the higher the stability counter)
◆ disparity_std
◆ decay
float decay = 1
◆ enable_forget_past
