This is the complete list of members for SpatialMappingParameters, including all inherited members.
| allowed_range | SpatialMappingParameters | static |
| allowed_resolution | SpatialMappingParameters | static |
| decay | SpatialMappingParameters | |
| decode(const String &serialized_content, SERIALIZATION_FORMAT format=SERIALIZATION_FORMAT::JSON) | SpatialMappingParameters | |
| disparity_std | SpatialMappingParameters | |
| enable_forget_past | SpatialMappingParameters | |
| encode(String &serialized_content, SERIALIZATION_FORMAT format=SERIALIZATION_FORMAT::JSON) const | SpatialMappingParameters | |
| get(MAPPING_RESOLUTION mapping_resolution=MAPPING_RESOLUTION::MEDIUM) | SpatialMappingParameters | static |
| get(MAPPING_RANGE mapping_range=MAPPING_RANGE::MEDIUM) | SpatialMappingParameters | static |
| getRecommendedRange(MAPPING_RESOLUTION mapping_resolution, Camera &camera) | SpatialMappingParameters | static |
| getRecommendedRange(float resolution_meters, Camera &camera) | SpatialMappingParameters | static |
| interval typedef | SpatialMappingParameters | |
| load(String filename, SERIALIZATION_FORMAT format=SERIALIZATION_FORMAT::AUTO) | SpatialMappingParameters | |
| map_type | SpatialMappingParameters | |
| MAPPING_RANGE enum name | SpatialMappingParameters | |
| MAPPING_RESOLUTION enum name | SpatialMappingParameters | |
| max_memory_usage | SpatialMappingParameters | |
| operator!=(const SpatialMappingParameters ¶m1) const | SpatialMappingParameters | |
| operator==(const SpatialMappingParameters ¶m1) const | SpatialMappingParameters | |
| range_meter | SpatialMappingParameters | |
| resolution_meter | SpatialMappingParameters | |
| reverse_vertex_order | SpatialMappingParameters | |
| save(String filename, SERIALIZATION_FORMAT format=SERIALIZATION_FORMAT::LEGACY) const | SpatialMappingParameters | |
| save_texture | SpatialMappingParameters | |
| set(MAPPING_RESOLUTION mapping_resolution=MAPPING_RESOLUTION::MEDIUM) | SpatialMappingParameters | |
| set(MAPPING_RANGE mapping_range=MAPPING_RANGE::MEDIUM) | SpatialMappingParameters | |
| SPATIAL_MAP_TYPE enum name | SpatialMappingParameters | |
| SpatialMappingParameters(MAPPING_RESOLUTION resolution=MAPPING_RESOLUTION::MEDIUM, MAPPING_RANGE range=MAPPING_RANGE::AUTO, int max_memory_usage_=2048, bool save_texture_=false, bool use_chunk_only_=false, bool reverse_vertex_order_=false, SPATIAL_MAP_TYPE map_type=SPATIAL_MAP_TYPE::MESH, int stability_counter=0, float disparity_std=0.3f, float decay=1.f, bool enable_forget_past=false) | SpatialMappingParameters | |
| stability_counter | SpatialMappingParameters | |
| use_chunk_only | SpatialMappingParameters |
