SpatialMappingFusionParameters Class Reference
Sets the spatial mapping parameters. More...
void set (SpatialMappingParameters::MAPPING_RESOLUTION mapping_resolution=SpatialMappingParameters::MAPPING_RESOLUTION::MEDIUM)
 Sets the resolution corresponding to the given MAPPING_RESOLUTION preset. More...
void set (SpatialMappingParameters::MAPPING_RANGE mapping_range=SpatialMappingParameters::MAPPING_RANGE::MEDIUM)
 Sets the maximum value of the depth corresponding to the given MAPPING_RANGE preset. More...
bool operator== (const SpatialMappingFusionParameters &param1) const
bool operator!= (const SpatialMappingFusionParameters &param1) const
Attributes
float resolution_meter = 0.05f
 Spatial mapping resolution in meters. Should fit allowed_resolution. More...
float range_meter = 0.f
 Depth range in meters. Can be different from the value set by sl::InitParameters::depth_maximum_distance.
Set to 0 by default. In this case, the range is computed from resolution_meter and from the current internal parameters to fit your application. More...
bool use_chunk_only = false
 Set to false if you want to ensure consistency between the mesh and its inner chunk data. More...
int max_memory_usage = 2048
 The maximum CPU memory (in MB) allocated for the meshing process. More...
float disparity_std = 0.3
 Control the disparity noise (standard deviation) in px. set a very small value (<0.1) if the depth map of the scene is accurate. set a big value (>0.5) if the depth map is noisy. More...
float decay = 1
 Adjust the weighting factor for the current depth during the integration process. By default, the value is set to 1, which results in the complete integration and fusion of the current depth with the previously integrated depth. Setting it to 0 discards all previous data and solely integrates the current depth. More...
bool enable_forget_past = false
int stability_counter = 0
 Control the integration rate of the current depth into the mapping process. This parameter controls how many times a stable 3D points should be seen before it is integrated into the spatial mapping. Default value is 0, this will define the stability counter based on the mesh resolution, the higher the resolution, the higher the stability counter. More...
SpatialMappingParameters::SPATIAL_MAP_TYPE map_type = SpatialMappingParameters::SPATIAL_MAP_TYPE::MESH
 The type of spatial map to be created. This dictates the format that will be used for the mapping(e.g. mesh, point cloud). See SPATIAL_MAP_TYPE. More...
Instantiating with the default constructor will set all parameters to their default values.
You can customize these values to fit your application, and then save them to a preset to be loaded in future executions.
Note
Users can adjust these parameters as they see fit.
◆ set() [1/2]
Parameters
mapping_resolutionThe desired MAPPING_RESOLUTION. Default: MAPPING_RESOLUTION::MEDIUM.
◆ set() [2/2]
Parameters
mapping_rangeThe desired MAPPING_RANGE. Default: MAPPING_RANGE::MEDIUM.
◆ save()
bool save ( String  filename,
) const
Parameters
Returns
Warning
◆ load()
bool load ( String  filename,
Parameters
Returns
◆ encode()
) const
Parameters
Returns
◆ decode()
Parameters
Returns
◆ operator==()
bool operator== ( const SpatialMappingFusionParameters &  param1) const
Parameters
SpatialMappingParametersto compare
Returns
◆ operator!=()
bool operator!= ( const SpatialMappingFusionParameters &  param1) const
Parameters
Returns
Variables
◆ resolution_meter
◆ range_meter
◆ use_chunk_only
Note
Updating the mesh is time-consuming. Setting this to true results in better performance.
◆ max_memory_usage
◆ disparity_std
◆ decay
float decay = 1
◆ enable_forget_past
◆ stability_counter
◆ map_type
