RecordingParameters Struct Reference
Structure containing the options used to record. More...
 RecordingParameters (String video_filename_="myRecording.svo2", SVO_COMPRESSION_MODE compression_mode_=SVO_COMPRESSION_MODE::H264, unsigned int target_framerate_=0, unsigned int bitrate_=0, bool transcode_streaming_input_=false)
 Default constructor. More...
bool operator== (const RecordingParameters &param1) const
bool operator!= (const RecordingParameters &param1) const
Attributes
 Filename of the file to save the recording into. More...
SVO_COMPRESSION_MODE compression_mode = SVO_COMPRESSION_MODE::H264
 Compression mode the recording. More...
unsigned int bitrate = 0
 Overrides the default bitrate of the SVO file, in kbits/s. More...
unsigned int target_framerate = 0
 Framerate for the recording file. More...
bool transcode_streaming_input = false
 Defines whether to decode and re-encode a streaming source. More...
Note
Constructor and Destructor
◆ RecordingParameters()
RecordingParameters ( String  video_filename_ = "myRecording.svo2",
SVO_COMPRESSION_MODE  compression_mode_ = SVO_COMPRESSION_MODE::H264,
unsigned int  target_framerate_ = 0,
unsigned int  bitrate_ = 0,
bool  transcode_streaming_input_ = false
All the parameters are set to their default values.
◆ save()
bool save ( String  filename,
) const
Parameters
Returns
Warning
◆ load()
bool load ( String  filename,
Parameters
Returns
◆ encode()
) const
Parameters
Returns
◆ decode()
Parameters
Returns
◆ operator==()
bool operator== ( const RecordingParameters &  param1) const
Comparison operator ==
Parameters
RecordingParametersto compare
Returns
◆ operator!=()
bool operator!= ( const RecordingParameters &  param1) const
Comparison operator !=
Parameters
Returns
Variables
◆ video_filename
◆ compression_mode
Default: sl::SVO_COMPRESSION_MODE::H264
◆ bitrate
Default: 0 (the default values associated with the resolution)
Note
Only works if compression_mode is H264 or H265.
Available range: 0 or [1000 - 60000]
◆ target_framerate
Default: 0 (camera framerate will be taken)
Warning
This framerate must be below or equal to the camera framerate and camera framerate must be a multiple of the target framerate.
It means that it must respect camera_frameratetarget_framerate == 0.
Allowed framerates are 15,30, 60 or 100 if possible.
Any other values will be discarded and camera FPS will be taken.
◆ transcode_streaming_input
Default: false
Note
If set to false, it will avoid decoding/re-encoding and convert directly streaming input into a SVO file.
This saves a encoding session and can be especially useful on NVIDIA Geforce cards where the number of encoding session is limited.
compression_mode, target_framerate and bitrate will be ignored in this mode.
