CustomObjectDetectionRuntimeParameters Class Reference
Structure containing a set of runtime parameters for the object detection module using your own model ran by the SDK. More...
 CustomObjectDetectionRuntimeParameters (const CustomObjectDetectionProperties &object_detection_properties=CustomObjectDetectionProperties{}, const std::unordered_map< int, CustomObjectDetectionProperties > &object_class_detection_properties=std::unordered_map< int, CustomObjectDetectionProperties >{})
 Default constructor. More...
bool save (const String &filename, SERIALIZATION_FORMAT format=SERIALIZATION_FORMAT::JSON) const
bool load (const String &filename, SERIALIZATION_FORMAT format=SERIALIZATION_FORMAT::JSON)
bool operator== (const CustomObjectDetectionRuntimeParameters &params) const
bool operator!= (const CustomObjectDetectionRuntimeParameters &params) const
Attributes
CustomObjectDetectionProperties object_detection_properties
 Global object detection properties. More...
std::unordered_map< int, CustomObjectDetectionProperties > object_class_detection_properties
 Per class object detection properties. More...
Note
Constructor and Destructor
◆ CustomObjectDetectionRuntimeParameters()
CustomObjectDetectionRuntimeParameters ( const CustomObjectDetectionProperties &  object_detection_properties = CustomObjectDetectionProperties{},
const std::unordered_map< int, CustomObjectDetectionProperties > &  object_class_detection_properties = std::unordered_map< int, CustomObjectDetectionProperties >{}
Parameters
object_detection_propertiesGlobal object properties, when not specified in object_class_detection_properties.
object_class_detection_propertiesObject properties per classes.
◆ save()
bool save ( const String &  filename,
) const
Parameters
Returns
Warning
◆ load()
bool load ( const String &  filename,
Parameters
Returns
◆ encode()
) const
Parameters
Returns
◆ decode()
Parameters
Returns
◆ operator==()
bool operator== ( const CustomObjectDetectionRuntimeParameters &  params) const
Comparison operator ==
Parameters
paramsCustomObjectDetectionRuntimeParameters to compare
Returns
◆ operator!=()
bool operator!= ( const CustomObjectDetectionRuntimeParameters &  params) const
Comparison operator !=
Parameters
Returns
Variables
◆ object_detection_properties
Note
object_detection_properties is used as a fallback when sl::CustomObjectDetectionRuntimeParameters.object_class_detection_properties is partially set.
◆ object_class_detection_properties
std::unordered_map<int , CustomObjectDetectionProperties> object_class_detection_properties
