CustomObjectDetectionProperties Class Reference
Structure containing a set of runtime properties of a certain class ID for the object detection module using a custom model. More...
 CustomObjectDetectionProperties (const bool enabled=true, const float detection_confidence_threshold=20.f, const bool is_grounded=true, const bool is_static=false, const float tracking_timeout=-1.f, const float tracking_max_dist=-1.f, const float max_box_width_normalized=-1.f, const float min_box_width_normalized=-1.f, const float max_box_height_normalized=-1.f, const float min_box_height_normalized=-1.f)
bool save (const String &filename, SERIALIZATION_FORMAT format=SERIALIZATION_FORMAT::JSON) const
bool load (const String &filename, SERIALIZATION_FORMAT format=SERIALIZATION_FORMAT::JSON)
bool operator== (const CustomObjectDetectionProperties &props) const
bool operator!= (const CustomObjectDetectionProperties &props) const
Attributes
bool enabled
 Whether the object object is kept or not. More...
 Confidence threshold. More...
bool is_grounded
 Provide hypothesis about the object movements (degrees of freedom or DoF) to improve the object tracking. More...
bool is_static
 Provide hypothesis about the object staticity to improve the object tracking. More...
 Maximum tracking time threshold (in seconds) before dropping the tracked object when unseen for this amount of time. More...
 Maximum tracking distance threshold (in meters) before dropping the tracked object when unseen for this amount of meters. More...
 Maximum allowed width normalized to the image size. More...
 Minimum allowed width normalized to the image size. More...
 Maximum allowed height normalized to the image size. More...
 Minimum allowed height normalized to the image size. More...
Note
Constructor and Destructor
◆ CustomObjectDetectionProperties()
CustomObjectDetectionProperties ( const bool  enabled = true,
const float  detection_confidence_threshold = 20.f,
const bool  is_grounded = true,
const bool  is_static = false,
const float  tracking_timeout = -1.f,
const float  tracking_max_dist = -1.f,
const float  max_box_width_normalized = -1.f,
const float  min_box_width_normalized = -1.f,
const float  max_box_height_normalized = -1.f,
const float  min_box_height_normalized = -1.f
◆ save()
bool save ( const String &  filename,
) const
Parameters
Returns
Warning
◆ load()
bool load ( const String &  filename,
Parameters
Returns
◆ encode()
) const
Parameters
Returns
◆ decode()
Parameters
Returns
◆ operator==()
bool operator== ( const CustomObjectDetectionProperties &  props) const
Comparison operator ==
Parameters
propsCustomObjectDetectionProperties to compare
Returns
◆ operator!=()
bool operator!= ( const CustomObjectDetectionProperties &  props) const
Comparison operator !=
Parameters
Returns
Variables
◆ enabled
bool enabled
◆ detection_confidence_threshold
From 1 to 100, with 1 meaning a low threshold, more uncertain objects and 99 very few but very precise objects.
Default: 20.f
Note
If the scene contains a lot of objects, increasing the confidence can slightly speed up the process, since every object instance is tracked.
◆ is_grounded
bool is_grounded
  • true: 2 DoF projected alongside the floor plane. Case for object standing on the ground such as person, vehicle, etc.
    The projection implies that the objects cannot be superposed on multiple horizontal levels.
  • false: 6 DoF (full 3D movements are allowed).
Note
This parameter cannot be changed for a given object tracking id.
It is advised to set it by labels to avoid issues.
◆ is_static
bool is_static
  • true: the object will be assumed to never move nor being moved.
  • false: the object will be assumed to be able to move or being moved.
◆ tracking_timeout
By default, let the tracker decide internally based on the internal sub class of the tracked object. Only valid for static object.
◆ tracking_max_dist
By default, do not discard tracked object based on distance. Only valid for static object.
◆ max_box_width_normalized
Any prediction bigger than that will be filtered out. Default: -1 (no filtering)
◆ min_box_width_normalized
Any prediction smaller than that will be filtered out. Default: -1 (no filtering)
◆ max_box_height_normalized
◆ min_box_height_normalized
